Old Jan 22, 2012, 06:42 AM
Twisted Realm is offline
Find More Posts by Twisted Realm
Twisted Realm's Avatar
United States, FL
Joined Aug 2008
Excellent Job Herc as always!!! She came out stunning.
Twisted Realm is offline Find More Posts by Twisted Realm
Site Sponsor
Old Jan 22, 2012, 07:11 AM
jetinteriorguy is offline
Find More Posts by jetinteriorguy
Burke, VA
Joined Sep 2009
Originally Posted by Azarr View Post
FWIW, I use dental floss in those positions to help stop breakout. Are the hinges top hinged foam like on the Telink Yak?
Azarr
How do you do this with dental floss? Do you cut a slit in the end end glue in a piece of floss? Or do you just glue it to the surface of the wing?
jetinteriorguy is offline Find More Posts by jetinteriorguy
Old Jan 22, 2012, 07:29 AM
cwojcik is offline
Find More Posts by cwojcik
Extremely Twisted
cwojcik's Avatar
United States, NH, Epping
Joined Oct 2005
I've had dental floss pull out after a while. It works better than nothing but after a few good tugs or lots of use it will separate from the glue.
The best hinge preserving method I've found is to cut a 1" square piece of Blenderm tape and put a coating of welder's on the sticky side, then put that at the end of the hinge. The adhesive in Blenderm won't stick to EPP, hence the welder's.
cwojcik is offline Find More Posts by cwojcik
Old Jan 22, 2012, 07:37 AM
psk560 is offline
Find More Posts by psk560
RC VIDEO ADDICT!
Georgia, USA
Joined Oct 2003
Stop when it catches on fire! Hilarious! Looking forward to my little crack yak!
Craig
psk560 is offline Find More Posts by psk560
Old Jan 22, 2012, 07:42 AM
Dan5.0 is offline
Find More Posts by Dan5.0
Joined Dec 2008
Great job Chris
Dan5.0 is offline Find More Posts by Dan5.0
Reply With Quote  (Disabled)
Old Jan 22, 2012, 08:01 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Great job Chris. Thats a lot of work you put in to this. Looks like the build is quite differant than the edge build.
Gravitycheat is offline Find More Posts by Gravitycheat
Old Jan 22, 2012, 08:15 AM
cbriggs11 is offline
Find More Posts by cbriggs11
Team Twisted!
cbriggs11's Avatar
United States, SC, Greenville
Joined Nov 2009
Awesome job. Way to get it done before first shipment u worked ur butt off
cbriggs11 is offline Find More Posts by cbriggs11
Old Jan 22, 2012, 11:18 AM
3drcparts is online now
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
I have torn the welders hinges on my 3dhs foamies so many times that I now just use blenderm on top of the welders, stick fine on dried welders so I will do the same here on the corners
3drcparts is online now Find More Posts by 3drcparts
Old Jan 22, 2012, 11:30 AM
Burke, VA
Joined Sep 2009
This has worked well for me as well, I had never heard of using dental floss and was curious how it worked.
Old Jan 22, 2012, 12:05 PM
hercdriver7777 is offline
Find More Posts by hercdriver7777
Team Extreme! Team Twisted!
hercdriver7777's Avatar
Columbia SC
Joined Feb 2005
You can just cut a thin strip of CA hinge and ad inlay it in the foam like we do on Telinks.
BTW, I just flew the Crack Yak production plane in my backyard and it is even better than the last prototype! Its been raining and windy all weekend but I could not resist a quick flight in the very confined and obstacle ridden yard.
I was curious to see if the added weight of paint and landing gear would change the plane. Specifically I was worried it would introduce coupling which was zero before. Well it did change the plane, for the better!! The added weight really did some good. This thing flies about as close as you can get with EPP to a competition indoor depron plane! I am totally stoked!!
hercdriver7777 is offline Find More Posts by hercdriver7777
Old Jan 22, 2012, 01:06 PM
7rider is offline
Find More Posts by 7rider
7rider's Avatar
USA, CA, Mountain View
Joined Dec 2007
Great build photos! Just a note that on my Windows machine, although the text adjusts to a variable width on IE and Chrome, on Firefox, the width needs a little bit more than 1920 pixels (my largest monitor).
7rider is offline Find More Posts by 7rider
Old Jan 22, 2012, 03:05 PM
tsilvers is offline
Find More Posts by tsilvers
Joined Dec 2011
Originally Posted by hercdriver7777 View Post
Yes, they are pre hinged and hinged very well with a laser cutter but if you dig a control surface into the ground it will tear it out. That is unless you put a thin beat of Welders at the inner and outermost parts of the hinge line. Not required but a good idea.
Herc.... Do u have a close up shot showing where u lay the glue bead?
tsilvers is offline Find More Posts by tsilvers
Old Jan 22, 2012, 03:11 PM
Columbia SC
Joined Feb 2005
http://static.rcgroups.net/forums/at...9-IMG_1097.jpg
Old Jan 23, 2012, 08:12 AM
cwojcik is offline
Extremely Twisted
cwojcik's Avatar
Joined Oct 2005
C'mon herc, give us some video! I'm shakin' here!
Mine should be here today. All my equipment is ready, gonna fly it indoors this weekend and probably outside in the snow before then (I'm impatient, especially with foamies!).
Old Jan 23, 2012, 08:25 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Yeah come'on herc !
Kris... is offline Find More Posts by Kris...
Build Log Twisted Hobbys - Telink 43" Yak 55 - Build, Fly, Vid hercdriver7777 3D Foamies 1007 May 21, 2015 03:02 PM
Build Log Twisted Hobbys - Telink 3D Buster EPP Bipe Build Thread, Flight Video just posted!!!! aerofundan 3D Foamies 578 Apr 21, 2015 04:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion Twisted Hobbys Crack Yak! hercdriver7777 3D Foamies 181 Sep 13, 2013 03:54 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
