Old Jan 21, 2012, 07:29 PM
Mrj3cub is offline
Find More Posts by Mrj3cub
Mrj3cub's Avatar
Joined Nov 2011
Build Log
My first KIT! It"s the SIG 1/4 scale cub!
So, here we go!
My first ever balsa KIT.
Have been looking at buildthreads and dowloading lots of pics latley, and I am feeling quite ready now.
Starting with the fuse formers as the plans say, and epoxied it together with lots of weight on it. Good tight fit! Man It is so much fun to cut and shape these balsa sticks!
More to come later!
Mrj3cub is offline Find More Posts by Mrj3cub
Old Jan 21, 2012, 10:04 PM
EJWash1 is offline
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
To me the essence of the hobby. Ever so decompressing!
All the luck with your build. Lots of help if you need it.
EJWash
EJWash1 is offline Find More Posts by EJWash1
Old Jan 22, 2012, 02:26 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
I really wanted the PA 18 supercub cowl and conversion, but because its my first build, I will stick to the plans from SIG and make it as simple it can be for me.
I will tough modify the door form Cubmans site.
I think the NE-1 scheme is cool and maybe this will be it.
It will be covered in Solartex. I have not decided what engine I will put in it, but the asp 160 twin is tempting because of the sound and scale look.
The Robart 1/4 scale cub gear is ordered.
I probably will be asking a lot of questions, but and hope a few will follow my build
Later!
Howard
Old Jan 22, 2012, 06:46 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
Welcome to the wonderful world of balsa dust. You will knick you fingers with knifes and pins, you will scratch your head and wonder why they did it that way. You will try something different and curse, you will also say hey that's neat ( share those with us).
When it is all done and over you will admire your work, think of things you will do better on the next one.
Then comes the inevitable, you will break it. Rest easy, you put it together the first time, you can do it again.
Enjoy the relaxation, ignore the fustration and don't glue you fingers together! ;<)
Joe
Thermaler is offline Find More Posts by Thermaler
Old Jan 22, 2012, 08:04 AM
Scaledown is online now
Find More Posts by Scaledown
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
Good on you for taking the plunge with kit building.
I would avoid using epoxy unless the instructions say so. Its the heaviest type of glue there is. Yellow carpenters wood glue (aliphatic resin) is a popular balsa glue.
Scaledown is online now Find More Posts by Scaledown
Old Jan 22, 2012, 08:17 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Yes! The inatructions say to epoxy the formers. For the other gluing i will be using Titebond orginal woodglue. Seems quite popular for building than the CA and all the health issues with that... Also then , have some good time to get the jointalignment perfect with Wood glue! My english is way out of line! Not my mothertounge
Old Jan 22, 2012, 08:25 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Joe
Thanks Joe! Dont say I will break it
I wont! Or?
Old Jan 22, 2012, 11:51 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Howard
Welcome to the Builders' CLub, and good luck with your project. I've built several Sig kits, including their 1/5th and 1/6th scale Cubs, and they all flew very well - so should your big Cub.
Take it slow and easy building your kit - think through things before gluing! Make sure your choice of engine, radio and that sprung undercarriage are all sorted out with regards to fitting into the model before you get too far along.
Sitting looking at a nearly finished and covered model wondering how you are going to fit rudder and elevator pushrods into the fuselage is not good, for one example that I have heard of before.
If you want to finish your model in a colour scheme other than 'Cub Yellow', Bob Banka has a very large range of alternates available from: http://bobsairdoc.com/ I've bought documentation packs from him before and had good service.
Good luck!
Dereck
Dereck is offline Find More Posts by Dereck
Old Jan 22, 2012, 05:59 PM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Originally Posted by Dereck View Post
Hi Howard
Good luck!
Dereck
Thanks Dereck! Many good advices!
Tonight I have finished the front and rear fuselage formers.
Have also used my new scroll saw to cut out the printed balsa sheets. Seems to do a decent job this saw.
This is awesome! Verry satisfying to se the bits come together.
Tomorrow i will start building the fuselage. If this is coming together as easy as the formers, it will be nice. NOT BAD for my first build i must say
I am very proud of myself
Old Jan 22, 2012, 06:30 PM
SunDevilPilot is offline
Find More Posts by SunDevilPilot
SunDevilPilot's Avatar
United States, AZ, Gilbert
Joined Jun 2008
Subscribed...
You have picked a great, but challenging kit. Take your time and you will end up with a great model. I am just about finished with mine. I just need to cover the fuselage and do the paint.
You look like you are off the a great start. I'm glad to see you enjoying the build process. There really is something about building that is addictive.
Here is my build thread, if you have not found it already.
http://www.rcuniverse.com/forum/m_8857500/tm.htm
SunDevilPilot
SunDevilPilot is offline Find More Posts by SunDevilPilot
Old Jan 22, 2012, 07:20 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
First build
Hi .welcome aboard.You speaking just fine!..you said 'build' and 'Cub' and that's all I needed to hear.
Enjoy the ride.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Jan 23, 2012, 07:55 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Originally Posted by SunDevilPilot View Post
Subscribed...
SunDevilPilot
Hey SunDevil!
Ye, have been studying pictures in your thread sideways,up, and down. Lots of great info and "buildlearning"
Nice to have you along!
Old Jan 23, 2012, 08:03 AM
Mrj3cub is offline
Mrj3cub's Avatar
Joined Nov 2011
Enjoy the ride.
Hey E.Earl!
Ye, there is something about these Cubs.. The way they fly.. its just so much fun to me! I started rc planes just six months ago. Have been building a few ARF`s these months. But there really is something about that what say " if you haven't build it yourself, its not really yours". I enjoy building maybe more than flying now.
Glad to have you in!
Old Jan 23, 2012, 02:32 PM
Mr_McGlue is offline
Find More Posts by Mr_McGlue
Mr_McGlue's Avatar
United States, CA, Long Beach
Joined Sep 2011
Good luck! Look forward to watching.
Mr_McGlue is offline Find More Posts by Mr_McGlue
For Sale New 46" SIG 1/4 SCALE CUB FLOAT KIT-STILL SEALED LCS Aircraft - Fuel - Airplanes (FS/W) 1 Dec 18, 2011 01:05 PM
Sold SIG 1/4 scale J3 cub kit unbuilt Free Shipping lesgilmer Aircraft - Fuel - Airplanes (FS/W) 4 Aug 18, 2011 12:44 AM
Sold Sig 1/4 Scale Clipped Wing Cub Kit, NIB - FREE Shipping! Johnny Angel Aircraft - Fuel - Airplanes (FS/W) 2 Jun 09, 2011 12:52 PM
Found Wanted Sig 1/4 scale J-3 Cub kit # RC48 Build2fly Aircraft - Fuel - Airplanes (FS/W) 1 May 20, 2011 04:35 AM
For Sale 1/4 Scale Piper Cub (Sig Kit) pcampjax Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2011 01:55 PM
