Old Jan 21, 2012, 12:20 PM
astronomer1 is offline
Find More Posts by astronomer1
United States, CO, Loveland
Joined Jan 2009
Tarno Carb. Working Adjustable Air Bleed For TD's
The 3 pictures show how I made an adjustable air bleed on my old Tarno carb. so it will run reliably and be safely used on an RC craft. The details are as follows to a disassembled carb.:
1.Original air bleed hole enlarged to appx. twice the original size and de-burred both inside and out. This whole size is not critical but keep it at around twice the original size.
2.Carefully flatten face of carb. using #400 wet /dry sand paper on a flat glass surface.
3.Drill and tap a hole on the front flat face of carb. for a
2 x 56 screw. Not a thru hole but appx. 3/16" deep. Requires two tap styles for threading. One a plug tap to start and finished with a bottoming tap. Exact position not measured, but was positioned by eye where shown in the pictures.
4.A small sliding/rotating "door" was fabricated from a scrap piece of aluminum, appx.3/32"x1/4"x3/8". The thickness is not critical except it probably should not be thinner than 1/16" so it can be made to have a flat face. One end was rounded and drilled for a tight 2x56 clearance hole for a 2x56 screw. The mating face of this little widget was carefully flattened using #400 on a glass surface. This was done to insure a good seal against the carb.face.
5.A 1/4" long 2x56 Pan Head Phillips screw and a lock washer secure the widget to the carb. and allow adjustment by slicing the bleed hole very precisely. This whole setup must have a low profile to avoid being hit by the prop. Unfortunately it can not be adjusted with the engine running. Screw must be well tightened to avoid loosing setting and hardware due to vibration.
Result: 7k to 18K at 5800' ASL., Hi-Comp head + 1 gasket, and Sig 25% fuel. My altitude may have had some effect on the results. The low enough idle, smooth transition and adequate full throttle resulted in good enough performance for 1/2A RC flying with 5x3 "Rubber Duckie" prop. The results are steady and repeatable which is contrary to what I was getting with an unmodified stock carb. In all, it now works as well as the latter day RC.05 carbs sold by Xenalook and X Model Engines.
Only major downsides to this modification are: New Tarno's are no longer available, carb is heavy, two taps and two drills are expensive, and stock carbs are hard to find and are usually quite expensive. Revisited RC.05 carbs. and "Dickybird" throttle sleeve/venturi modded engines work better in my opinion from my own experimentation.
Time permitting, I will try to make a followup post that explains why I think this modification works if anyone is interested.
astronomer1 is offline Find More Posts by astronomer1
Old Jan 21, 2012, 08:46 PM
Toysareforkids is offline
Find More Posts by Toysareforkids
Tn
Joined Jan 2011
I'm confused??? Where did everything go that was posted here?
Pat
Toysareforkids is offline Find More Posts by Toysareforkids
Old Jan 22, 2012, 06:02 AM
Joined Jan 2009
Confused/ Tarno Carb Airbleed
Pat, I don't understand your question.. What do you mean: Where did everything go that was posted here?
Old Jan 22, 2012, 06:29 AM
Tn
Joined Jan 2011
Well...I did say I was confused! You started the exact same thing on RCU on the 17th, and I posted on that one, along with others that did also. When I saw it here, I thought everything was gone. But Nope, Just the same thing, but different place.
Not good to confuse me, because then I have to go take my meds (Work on a plane) So now that you confused me, I have to go take my meds (work on a plane) Oh Wait!!! Thats a Good thing By see ya later, my DR-1 is waiting.!
Pat
Old Jan 22, 2012, 08:32 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
There are posts on the cox forum also, just to add to the confusion...
surfer_kris is offline Find More Posts by surfer_kris
Old Jan 23, 2012, 06:36 AM
hlsat is online now
Find More Posts by hlsat
hlsat's Avatar
Ελλάδα, Ανατολική Μακεδονία Θράκη, Βιστωνίδα
Joined Jul 2006
This old Tarno carb is good only for engines Cox Tee Dee .049 and .051.
Origin country of manufacture Canada.
hlsat is online now Find More Posts by hlsat
Old Jan 26, 2012, 07:28 AM
Joined Jan 2009
To all of you confused folks, I am also confused concerning posting the same writeup on multiple forums. Is there some sort of protocol that states that doing so is not permitted or is it just a community "No-No"?
In the past, I have posted same subject writeups on multiple forums without getting any flack. I have done this to reach readers on other forums that may not be subscribed or reading elsewhere. I don't want to stir up a hornets nest in one of the best and most informative forums on the Web.
Please let me know what the skinny is about this!
Old Jan 27, 2012, 11:06 PM
Jaspur_x is offline
Find More Posts by Jaspur_x
Somerset Pa
Joined Dec 2009
Astronomer1, its a huge no-no and now that you broke the never been written rule you have to post 9 flying videos in the next month...........just kidding,the more viewers the better I say,multiple forums or no.
Jaspur_x is offline Find More Posts by Jaspur_x
Old Jan 28, 2012, 05:58 AM
Joined Jan 2009
Jaspur_x,
I CONCUR!!
Sold Nip tarno carb for cox td .09 engines softlanding Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 26, 2010 11:26 PM
Wanted Air Bleed screw for OS #21 carb coloradoz Aircraft - Fuel - Engines and Accessories (FS/W) 5 Nov 22, 2007 12:35 PM
Tarno Carburetor-049 -1/2A Cox TD- pic -- ebay link TTT1111 1/2A Planes 18 May 04, 2005 07:11 PM
Tarno Carburetor-049 -1/2A Cox TD- pic -- ebay link TTT1111 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 27, 2005 12:03 AM
Alert O.S. 40 La Air Bleed Screw fldmshlschroe Engines 8 Feb 25, 2005 04:02 AM
