Old Jan 21, 2012, 05:41 AM
njwxyz is offline
Find More Posts by njwxyz
Posted with DragonLink
Norway, Hordaland, Ask°y
Joined Jan 2012
Can I control Guardian stabilizer with DX6i?
I'm new to RC and FPV, and am doing my homework before buying anything. I don't have a big budget, so I need to make sure that what I want to end up with later down the road, will work with what I'm starting with.
Essentially, I'm doing lots of research, but will have to add components little by little- paycheck by paycheck... OSD, Guardian, data logger, GPS, etc...
I have access to wide open spaces with uninterrupted line of sight, so am counting on my AR6210 RX with DX6i providing adequate range for now.
So anyway... I would really appreciate help with 2 questions...
1. Can I control the Guardian through my DX6i TX?
2. If I expect to lose range on DX6i before AV TX (due to high power AV TX), how can I configure my FS in such a way that the RTH will save me in the event of loss of signal or DX6i failure/power, etc...?
I have searched high and low and cannot seem to find answers to these questions. Thanks!!
njwxyz is offline Find More Posts by njwxyz
Old Jan 22, 2012, 04:42 AM
camship is offline
Find More Posts by camship
Resistance is Futile
camship's Avatar
United States, FL, Panama City Beach
Joined Oct 2001
Answer #1 yes, in theory. Answer #2 I am not familiar with the programing of the DX so I don't know how it handles failsafe but the ET system is pretty flexible so I would venture a hesitant, "yes".
The DX6i is a bad way to start FPV. That is why you can't find info because folks ditch the DX (any version) very quickly as it is useless for anything but putt putt park flyers. Get a different TX. Check the Video Piloting Forum. You will be glad you did.
Best of luck to you,
Rob
camship is offline Find More Posts by camship
Old Jan 22, 2012, 06:00 AM
EugeneFlorida is offline
Find More Posts by EugeneFlorida
KJ4YYJ
EugeneFlorida's Avatar
Saint Petersburg FL
Joined Jun 2009
I used the DX6i for over a year worked great!!!
I used AUX 1 and 2 on Gear and Flap switch the plane is a Easy Star no ailerons.
Guardian I used the box stick (center stick)
I have a small place to fly in only out 2700 feet. Never had FS come on when I was flying.
But, test worked great..
How I have Dragon Link.
Hope that help
EugeneFlorida is offline Find More Posts by EugeneFlorida
Old Jan 22, 2012, 08:23 AM
njwxyz is offline
Joined Jan 2012
Thanks for not beating around the bush, Camship!
I guess the old adage holds true..."Time spent on reconnaissance is seldom wasted."
Well I guess I saw that coming anyway, since the only available band in Norway (legal, and with a high enough power to be useful- many bands peak at max 50mW power allowed!!) is 4.5GHz (which has a few freqs allowed up to a whopping 2000mW power), so I guess I was going to have to do this anyway to avoid RC and AV competing for the same few available frequencies.
Oh well, guess I'll be sellin' my Spectrum after all (and whatever else of value I can find)...
Thanks again!
Old Jan 22, 2012, 03:30 PM
camship is offline
camship's Avatar
Joined Oct 2001
Thanks again!
Wow, 4.5GHz. Check the FPV forum. I know there is a small community of Norwegian FPV'ers that can fill you in.
Go for it!
Rob
Old Jan 23, 2012, 01:14 AM
njwxyz is offline
Joined Jan 2012
Go for it!
Rob
Uhhhh...I mean 2.4GHz... not 4.5. Cerebral gas-passing... ;-) or paralysis by analysis... time to stop researching and buy something!
Cheers, Rob.
Old May 02, 2013, 04:41 PM
wedreagle is offline
Find More Posts by wedreagle
Joined Mar 2008
Eclipse 7 transmitter
I also would like to know how to program the Guardian to a 3 way switch on my Eclipse 7 transmitter. I am at a loss!
wedreagle is offline Find More Posts by wedreagle
Old May 03, 2014, 08:19 PM
ldeboer112 is offline
Find More Posts by ldeboer112
Joined Apr 2014
Using the DX6i with Eagletree Guardian
Check out my youtube video
A simpler 3 positiion switch setup for Spektrum DX6i and the Eagletree Guardian (5 min 26 sec)
ldeboer112 is offline Find More Posts by ldeboer112
Old May 09, 2014, 07:13 PM
Uretek is offline
Find More Posts by Uretek
United States, NC, Greensboro
Joined Apr 2014
The video is a great idea! Works great, I just used gear for mode and flaps on off in mix
Uretek is offline Find More Posts by Uretek
Old Jun 02, 2014, 12:17 PM
CurrentDude is offline
Find More Posts by CurrentDude
Flying is Electrifying
United Kingdom, England, Macclesfield
Joined Jun 2011
With all respect to guys here, it might be worth visiting the following thread. Lots of helpful guys are there:
http://www.rcgroups.com/forums/showt...2#post28539470
CurrentDude is offline Find More Posts by CurrentDude
Discussion When to and How to use mixing control with DX6i TruSpeed Beginner Training Area (Aircraft-Electric) 10 Jun 21, 2012 09:14 AM
Help! Can't get Guardian to work Tony97 Eagle Tree Systems 1 Aug 30, 2011 10:36 PM
Wanted stabilizer control set Xilefchin Aircraft - Electric - Helis (FS/W) 0 Jun 28, 2011 11:20 AM
Question DX6i, mixed to control tank-like motors with single stick? marhar Beginner Training Area (Aircraft-Electric) 3 May 16, 2011 12:01 AM
Can you help me with stabilizer design? jdmartin8 Parkflyers 5 May 20, 2001 10:53 PM
