Old Jan 20, 2012, 08:26 PM
rustytoolss is offline
Find More Posts by rustytoolss
rustytoolss's Avatar
United States, OH, Barberton
Joined Dec 2011
Water cooling information needed
New to boats...got a question about water cooling. I bought a used brushless boat that has no motor water cooling. also the ESC has no cooling. I'm planning to do the coiled tubing around the motor. And put some coils on the ESC also. Now my questions....is it better to cool the motor first/ or the ESC...does it matter ?? . And how would you attach cooling tube to the ESC ? zip ties ??
rustytoolss is offline Find More Posts by rustytoolss
Old Jan 21, 2012, 05:46 AM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi RT,
Do you have some pictures of the items in question?
It may be very well possible, the components are selected to be able to work without watercooling...
If that is the case, adding watercooling is an extra, but also means extra weight, reducing speed and runtime.
If you do need to install watercooling, I'd use a home made (also commercially available) cooler like this for the ESC:
A coil around a brushless motor is generally speaking not very effective, unless it's wound tightly, pushed onto the can using heatconductive paste and secured in place with a piece of shrinkwrap, which also shields the paste, which is nasty stuff, specially on cloths and skin (don't ask...)
Much better is a cooling jacket, where the water runs directly on the motorcan like this:
With a single inlet, the water goes to the ESC first, than to the motor.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Jan 21, 2012, 06:04 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Water Cooling
If the boat didn't have it from the factory, is there some reason you think it's needed now? These factory set-ups, are usually pretty well engineered. CaptCB
CaptCB is offline Find More Posts by CaptCB
Old Jan 21, 2012, 12:29 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
..and be very careful using a piece of metal tubing touching the tops of the mosfets. Doing that to some of the older esc's will fry the controller. And is the motor a brushless outrunner?
I second what CaptCB says. If it didn't have it before, why add it?
Dave
boater_dave is offline Find More Posts by boater_dave
Old Jan 21, 2012, 01:23 PM
Joined Dec 2011
Dave
The boat is a Aquacraft Mini Thunder, that has been modified with a brushless 2435 4400Kv inrunner motor, ands the ESC ic a HobbyKing 50Amp. Because of the way the motor mounts (strap over the center) I don't think a water jacket will work. Also have not found any 24mm jackets. The orignial motor was a brushed 380.
Old Jan 21, 2012, 02:36 PM
Sneek, Netherlands.
Joined May 2004
Originally Posted by rustytoolss View Post
The boat is a Aquacraft Mini Thunder, that has been modified with a brushless 2435 4400Kv inrunner motor, ands the ESC is a HobbyKing 50Amp. Because of the way the motor mounts (strap over the center) I don't think a water jacket will work. Also have not found any 24mm jackets. The original motor was a brushed 380.
Hi RT,
The stock motor had a rudimetal watercooling bolted onto the front (see the picture on the Aquacraft site), I assume that wasn't used when the brushless motor was installed?
If so, does it cool enough (probably not...)?
Strapping a motor down in a fast electric that way should have been forbidden from day one, as it makes it harder to replace it with something that does need a functional cooling jacket.
If it were my boat, I'd remove the plastic parts forming the motormount, close the holes with ABS card so the tub is one piece again and use a proper motormount (angled aluminum) so you have room for a coil.
Make sure to use heatconductive past and cover the coil with heatshrink:
Regards, Jan.
Old Jan 21, 2012, 04:13 PM
Kcal is offline
Find More Posts by Kcal
Joined Jul 2008
Cooling water always goes to the ESC first and the motor second, I also second improving the motor mount and changing to a cooling jacket if you are able to.
Kcal is offline Find More Posts by Kcal
Help! Pro boat stiletto 29 cooling water pimbo Racing Boats - Electric 6 Oct 03, 2011 01:01 PM
Discussion water cooling for bec ? mortonj69 Racing Boats - Electric 1 Jun 25, 2011 11:19 AM
Discussion Large Motor Water Cooling Msioni Racing Boats - Electric 7 Jun 10, 2011 07:18 AM
Discussion Adding water cooling to an esc ! mortonj69 Racing Boats - Electric 9 Apr 29, 2011 07:14 PM
Discussion Help Needed With Arrow Shark - Flying Dragon Water Cooling Pipe Setup richclausen Racing Boats - Internal Combustion 4 Dec 10, 2008 07:23 PM
