So. Cal.
Additional theory and empirical data basis for the calculator is contained in the data thread. Specifically, post #3 has pertinent information:
http://www.rcgroups.com/forums/showp...85&postcount=3 Mark |
>> I am finding some have started to puff ... not capable of meeting my requirements
Like it or not, this insight is a result of flight tests ![]() Before you make the big leap from "not capable of meeting my requirements" to "been ripped off", you should have a very careful look at your setup and the history of those packs. True, there are some rotten packs out there also by big names (which brand has all those single-cell-failures?) But a lot of what's written on the web about problems with their "2 liter car that has been found by scientific methods to have only a 1.8 liter engine" comes from people who think the car vendor put it into 2nd gear, he knows best and you aren't supposed to change that... |
United States, NJ, Clayton
Joined Aug 2010
I'm sure it's outside the scope of this tool to predict a 'puffing tendency', but I'm convinced that puffing is not just down to how the battery is used and feel it must be telling us something about the quality of the cells - or should we just not worry about it? |
>> be hyperion would it
not in my experience, but I only own two packs per heli, one charges, one flies. Those Hyperion packs I've killed died in balance What can help is to strap the LiPos in tight, to hold the layers together and prevent puffing under load. It's a vicious cycle, as a puffed cell runs less efficiently, causes more heat, which causes more puffing (and common sense tells me, the harder I make them work, the better I should be prepared for a fire). Typical causes under the control of the user are overcurrent (overloaded motor), and too high operating temperature. |
Joined Mar 2012
I purchased a lipo with a stated C rating that should of been capable of supplying the current required for my application. After little use I find the pack has started to puff.
I then find rcgroups and see that people who have tested packs have seen a correlation between what a pack or cell is capable of and its IR or as Wayne calls it ESR. I have rightly or wrongly assumed based on their work that if my pack is to perform as stated it then should also have a certain IR. Like you though I have similar packs performing in a similar way. One thing I note though and that is just because a pack doesn't meet its marked c rating doesn't mean it will not fly your model as you want to fly it. I have been able to log that although at the end of a flight a pack has not been over-discharged it also at some point was not capable of holding its voltage under load which I believe is related to its IR. Either that or it was a lie by the manufacturer that in fact I got a 15C pack and not a 25C pack. |
United States, MD, Ellicott City
Joined Feb 2010
So I am pretty interested on the IR state of my batteries and testing it with my tricopter performance. My icharge gave me about 10mohm. Since the spread sheet script is protected I looked around different posts for a linear approx between True C and max AMPs. I realize that this is a non-linear relationship. I then got the Specs of my eflite motors, park 450s, and the weight of my tricopter to figure its performance ie WATTs/LBS and what each arm was seeing. I them tested it on my battery I pulled a total of 375 watts with a max amp of 36.75. I calculated a c rating of 16.75. By the way this is a 2200 nano tech 3s 25-50c. I know temp plays big in the calculations. I back calculated my IR to be about 8.0 mohm. I placed that into my other equation and figured that I have about 25watts due to total IR^2 losses which sound about right for eff of 92%.
Although this has a FOM of 0.774 it still delivers enough performance to fly my tricopter very nicely. 147.33 Watts/LBs is near the range which could be used for unlimited 3d performace IAW eflite. Maybe C-rating is really quite lower then on the packs or my cals are justed totally hosed, but the program on this thread sees to be working better then a thumb rule. if you account for losses it may very well be spot on. In playing with the numbers an FOM of 0.4196 would still get me about 100 watts/lbs which will still fly a tricopter ok or can be graduated to flying parkflyers with less power demands. |
Atlanta, GA
Joined Nov 2010
I am looking for a charger for my batteries (the link below is the batteries I have)
http://www.hobbyking.com/hobbyking/s...dProduct=11911 I want it to be able to charge 2-3 batteries at a time both from a wall plug and a car outlet. Any ideas??? |
Striker you are in the wrong thread.
Try posting in this one. http://www.rcgroups.com/forums/showt...356436&page=10 |
Joined Jan 2012
This is why I think the FOM as it stands is not very useful. It arbitrarily sets a good battery at 22C. It's not adjusted for what you actually need. Also, if I buy a 65C battery and the "real" C comes out to 25C, the FOM will rate it as a great battery just the same as a 25C rated battery with a "real" C of 25C. That doesn't make sense... at least in my brain.
So. Cal.
The lesson here is that the end-user must understand the demands of his particular application and choose packs that will meet this application. IMO, FOM is an excellent tool in helping to make this determination. Quote:
Mark |
Rugby, UK
Joined Feb 2007
I agree Mark. The whole point of the calculator and FOM is to tell the user the truth about the Lipo. The C rating written on the side of the pack is irrelevant as it has generally proven to be fiction.
Surely the user wants to know what the Lipo is really capable of - the calculator and FOM does that and the label does not. ToBeFrank, I wouldn't call a 25C Lipo a 'great' battery, but the genuine 25C pack is equal to the 65C marked pack in your example and surely that is what we want to know and makes sense. This is the 'raison d'être' for the calculator , and for the FOM. Wayne |
| Thread Tools | |
| New Product Cell Internal Resistance Meter - more useful than 'C' ratings - Now available. | PLD | Batteries and Chargers | 468 | Oct 05, 2012 10:02 PM |
| Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? | Merlin45 | Batteries and Chargers | 18 | Apr 03, 2010 04:45 PM |
| Idea Proposal for simple lipo performance figures of merit | kgfly | Batteries and Chargers | 8 | Oct 29, 2009 05:55 PM |
| Question What is the formula for lipo discharge amps? C ratings and such? | skid_68 | Batteries and Chargers | 6 | Nov 10, 2005 08:10 AM |
| LiPo "C" Ratings: Useful? | RD Blakeslee | Batteries and Chargers | 121 | Mar 17, 2005 10:02 PM |
