Old Oct 28, 2012, 10:43 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
New terrority here for me at this discharge rate...
I am testing a 2200 4S 65C pack for a buddy and after 6 easy cycles I went for around a 45C discharge and pulled 102 amps from it tonight; twice.
It was holding 3.5x and eventually down to around 3.43 when I cut power. Amps dropped too, from 102 down to around the mid 80's. Pack temp was under 130F even after a 5 mn warm up/cool down persiod.
My PL8 IR is reading 3.2 to 3.0 on all cells around 70F ambient. Using the calculator it should be around a 30C pack but the numbers on my wattmeter suggest a higher C.
What should I be expecting for cell voltages during a ~50C discharge?
Rick
rampman is offline Find More Posts by rampman
Latest blog entry: mean well S-210-12 power supply
Old Nov 01, 2012, 01:13 AM
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Originally Posted by mrforsyth View Post
It's generally easiest to track performance over time by being as absolutely consistent as possible with respect to measurement temperature. iCharger will be more than sufficient to tell you this, unless your packs are huge (>5000mAh).
Mark
Originally Posted by H2SO4 View Post
That would give them a FOM of 4.53, a max current rating of 126A, and a 48 'true' C. A record, I believe.
What are you using to measure IR?
Hello Gentlemen; I've been reading your discussions about IR. I have the i Charger 208B and recently started to keep a closer eye on my batteries. I have moved up to more expensive Planes.
I also have just one quick question;
At what point say on a 2700mah 4s 35c would IR be considered too high per cell? I'm just looking for a rule of thumb. Over 20 mOhm per cell? Thanks Bill
bonner is offline Find More Posts by bonner
Old Nov 01, 2012, 02:37 AM
Rugby, UK
Joined Feb 2007
Bill,
Thats a bit how long is piece of string but in practical terms you are probably about right.
If you put 20 milliohms and 2700mAh into the calculator. (http://www.jj604.com/LiPoTool/)
You will see that it gives a real C of 11 and a max current of 28A
This probably means that the pack is ok if you want to use it in a lazy model to just putter round. It would be overstressed if delivering more than 400W.
As it is a mid sized pack which should be capable of 20 or 25C, we would expect it to deliver about 900W powering a mid sized model in which its performance now would be disappointing.
If all the other cells are lower in IR and just one cell is 20 milliohms, then that is telling you that the pack is dying.
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Nov 01, 2012, 05:12 PM
That's a funny word
NE Ohio
Joined Apr 2003
Rick
3.4 volts would be expected (unless it finally falls on it's face. Are you picking the voltage from the same (discharge) lead OR from the balance taps?
At 130 and 3.5 volts they have just a bit more to give. (probably not much)
gulio is offline Find More Posts by gulio
Old Nov 02, 2012, 02:18 AM
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
Originally Posted by Wayne Giles View Post
Bill,
Wayne
Wayne; Thank you for the easy explanation. I'm too old to get into the technical stuff. I have however started reading this thread from page one. I find it very interesting even through their is a lot I don't understand. I'm not lazy but , I was looking for a value I could use and pass on to my fellow flyers, like typically a new 4s 2500 mah battery one would expect each cell at 72F to read approx 4 to5 m Ohm per cell and, a questionable battery might be reading 20mOhm or more per cell as it nears the end of it's useful life.If a human was measured in this way, I'll probably be reading a IR of 30 m Ohm per cell. LOL
Any way thanks for your answer in layman's terms. Bill
Old Nov 02, 2012, 07:01 AM
Trevorh's Avatar
Hampshire, U.K.
Joined Jun 2008
Bill, for what it's worth, I use mainly 3000mah batteries and my rules of thumb are:
i) Any single digit IR reading is good
ii) 10 - 20 milliohms is still perfectly useable
iii) Over 20milliohms: Whilst there are some who will say that these are useless and should be discarded, I identify strongly with your human analogy so prefer to take the view that they should undertake light duties only and certainly never be subject to any stress or abuse.
I hope that helps
Trevorh is offline Find More Posts by Trevorh
Old Nov 02, 2012, 08:47 PM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Thanks for responding. V was from taps.
Testing has stopped as I sucked the esc wires into the fan and grenaded it but the last cycle was still as impressive.
Old Nov 02, 2012, 09:12 PM
DonA's Avatar
Joined Feb 2006
Took my new Lipo Tool to the field today and and ran some curiosity tests with my friends on all sorts of packs from 3S 2000mah to 5S 5000mah packs. I asked my friends to arrange their packs of the same capacities in order of their perception of performance (if they had an opinion of that) and then we measured pack and cell IRs. As expected, the packs with good performance (relatively speaking) had cells that had more closely matched IRs. Most were surprised at the mismatch in cells and the effect it had on performance.
As expected some basically felt it was interesting, but felt it was 'too much information' and preferred to just fly and let the chips fall where they may..... ;-)
Don
DonA is offline Find More Posts by DonA
Old Nov 02, 2012, 11:58 PM
Tree Trimmer
bonner's Avatar
alex va.
Joined Oct 2008
I hope that helps
Another prefect answer for me, Just what I was looking for!!
Thanks much, Bill
Old Dec 05, 2012, 06:43 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
A post on why I like the meter, and some data on 2S 800mAh Turnigy packs.
Another example of "Don't believe the label".
http://www.rcgroups.com/forums/showp...&postcount=416
jj604 is online now Find More Posts by jj604
Old Dec 09, 2012, 05:12 PM
Joined Jun 2012
Hi,
I have made my own LiPo internal resistance tester. It has some inacurancies, but I think it is quite useable. The big advantage is that it is free, the disadvantage is that you have to make your own, I just give every plan I have for it.
http://cseb.hu/lipo_rin
Critical components (except the microcontroller) can be ordered as a free sample from the manufacturer. the microcontroller can be disassembled from a faulty ESC. :-)
Regards,
Csaba
cseb73 is offline Find More Posts by cseb73
Old Dec 10, 2012, 07:40 AM
Land O' Lakes, FL
Joined Aug 2003
I wish somebody would make one commercially! Now that you've posted the circuit, it's too late to sell it to a potential manufacturer!
Originally Posted by cseb73 View Post
Hi,
Regards,
Csaba
sailr is offline Find More Posts by sailr
Old Dec 10, 2012, 07:54 AM
Joined Aug 2011
Hi,
No point in making it commercial. You can buy it at HobbyKing for USD40. :-) It is a very simple circuit. No manufacturer would pay for it.
Regards,
Csaba
cseb is offline Find More Posts by cseb
Old Dec 10, 2012, 08:09 AM
JohnathanSwift's Avatar
Joined Mar 2012
Link to HK product?
JohnathanSwift is offline Find More Posts by JohnathanSwift
Old Dec 10, 2012, 09:05 AM
Joined Aug 2011
Originally Posted by JohnathanSwift View Post
Link to HK product?
http://www.hobbyking.com/hobbyking/s...ga_Meter_.html
New Product Cell Internal Resistance Meter - more useful than 'C' ratings - Now available. PLD Batteries and Chargers 468 Oct 05, 2012 10:02 PM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Idea Proposal for simple lipo performance figures of merit kgfly Batteries and Chargers 8 Oct 29, 2009 05:55 PM
Question What is the formula for lipo discharge amps? C ratings and such? skid_68 Batteries and Chargers 6 Nov 10, 2005 08:10 AM
LiPo "C" Ratings: Useful? RD Blakeslee Batteries and Chargers 121 Mar 17, 2005 10:02 PM
