Old Sep 06, 2012, 10:05 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Do you trust the IR readings from the PL-8 ? I'm not sure I do. How about this? It only takes one bad (high IR) cell to fall on it's face thus ending the discharge early. Is this possible or were you monitoring each cell's voltage during?
In any case, I think you paid too much.
gulio is offline Find More Posts by gulio
Old Sep 06, 2012, 10:38 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Rick,
You did not indicate the listed capacity of the packs but from the usable capacity deltas between 2A and 20A draw, I'm with gulio here and would say the reported IR numbers are way outta whack, at least at first analysis.
Were the IR measurements and discharge tests performed when the packs were at the same temperature? Do you have access to an iCharger for comparison?
Also, are you sure that the main discharge connectors have no issues and your charge lead on your PL8 is not super long or of small gauge? A lossy connector or a bad charge lead will show very poor performance in a discharge test but this will be masked by the IR test as the charge lead resistance is eliminated. This may mean that your packs are just fine and you have loss elsewhere in your setup.
In my experience, IR is an extremely accurate predictor of pack performance and your problem may be beyond the cells themselves.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 06, 2012, 11:15 PM
rampman is offline
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Sorry, I edited my post above. These are all 5000mah packs.
I was reading each cell separately on the discharge. Granted, some packs had one or two cells dipping a tenth lower than the others but the others were falling on their faces too.
Originally Posted by mrforsyth View Post
Rick,
Mark
A bad connection would have given me a hot spot on the leads/connectors. I am using 45A APP's crimped with the OEM APP tool. The wires and APP's on the OEM FMA PL8 lead were not even warm.
At the field two were very warm, the other two were ambient which was only around 103F.
Today I was at 75F during tests on all packs.
Mark
The fact that my FMA Corsair with an upgraded power system only went 1.25 laps around the flying field was my first hint that there was something wrong with the fully charged pack. The .25 of a lap was into a bush so, lucky for me, the plane suffered very little damage. [whew]
I guess my questions here is how I can have an IR that, at worse on the worse pack (I entered 7 for IR, 5000mah), is a true 13C rating but can't even hold a 20A draw for longer than a minute at most. I expected this to be, and it has proven such, more accurate.
Could it be a new chemistry in these newer 40C rated packs? [shrugs]
Rick
rampman is offline Find More Posts by rampman
Old Sep 06, 2012, 11:19 PM
So. Cal.
IMO, there's your answer my friend.
The negative temperature coefficient of lipolys will show dramatic difference in internal resistance at 103 vs. 75F.
Can you measure IR again at ~72F and report your findings?
Cheers,
Mark
Old Sep 07, 2012, 12:22 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Rick
Nope. Today i did all tests at 75F.
Old Sep 07, 2012, 12:26 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
I just put ky 12 light bulb discharger on the packs and the voltages fell off really fast again.
Someday these may end up as someones power pack to charge their 2200 and smaller packs.
Rick
Old Sep 07, 2012, 12:48 AM
So. Cal.
Ok, thanks for the update Rick. So, the reported IR's were taken at 75F and not 103F as I misinterpreted.
Puzzling indeed, especially the pack that had a worse case cell IR of 3.4mOhm yet only delivered 241mAh at 20A for a 5000mAh pack that was fully charged.
Given this, I would almost have to say that your PL8 is thoroughly confused and is not properly reporting internal resistance of extremely poor performing packs. I do not own a PL8 but have found that my iCharger 306B has been absolutely spot-on in all circumstances and has never given good numbers for a poor performing pack nor has it given bad numbers for a good performing pack.
Do you know any flying buddies that own iChargers who would let you borrow it for a few minutes? Wish I lived closer and I would loan you mine for a few days...
Mark
Old Sep 07, 2012, 11:19 AM
rampman is offline
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Yes. I think someone at my flying field has 1 that I can borrow at the field.
Up to this point my PL8 internal resistance measurements have seem to be pretty accurate.
Thanks to all for the inputs. Oh. I have some 3S and 4S 5000mah 40C Sky lipos for sale if anyone is interested.
Rick
Old Sep 07, 2012, 03:06 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Rick,
I have seen a similar reaction in testing a GensAce 2200 55c pack which I had measured IR at 3 mohms/ cell but decided that as it was claiming to be a 55C pack that I would run full discharge runs at 20C, 25C, 30C, 35C. .... etc up to 55C.
It survived the 30C run (just) but part way through the 35C discharge, the voltage suddenly collapsed below 9V. (3S pack) which automatically terminated the discharge at about 60% of the capacity. When the pack had cooled down it appeared OK but I measured the IRs and they had now increased to 11, 13 and 23 milliohms and remain there so that the high discharge had obviously permanently damaged the pack. Presumably the 23m.ohm cell was the one which suddenly 'let go' and then partially recovered.
When people say that there is another factor other than IR which affects lipo performance they are overlooking the fact that, by definition, it is the IR that dictates the performance of the lipo, but the 'effective IR' at THAT particular moment.
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Sep 10, 2012, 11:02 AM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
delete
Old Sep 10, 2012, 11:03 AM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
HK charger that measures IR of each cell according to pg 17 of manual. http://www.hobbyking.com/hobbyking/s...ph_Screen.html
(just in case Mark needs another charger)
Old Sep 10, 2012, 12:27 PM
So. Cal.
Haha. Yes, I am down to 10 lipoly chargers now, 7 of which are balancing chargers.
Would be curious to know how well the IR measurement works. Perhaps I'll order one after I whittle down my current collection...
Mark
Old Sep 11, 2012, 12:39 PM
mariano2cv is offline
Find More Posts by mariano2cv
In that would I measure the cells go? 3. 85v or 4.2? for I serve the data for the calculation of the web (Lipoly Objective Performance Calculation Tool )
mariano2cv is offline Find More Posts by mariano2cv
Old Sep 11, 2012, 10:24 PM
ParkJeff is offline
Find More Posts by ParkJeff
Birds do it, bees do it
ParkJeff's Avatar
Australia, WA, Perth
Joined Feb 2003
Hi Mark, JJ,
Any chance that the data in the Database thread could be put into one spreadsheet located in the first post? At the moment, we have to go through the entire thread (which I hope is going to get much longer as more data is posted) to find info which is relevant to our application.
I would volunteer to do the job if I wasn't so busy. Hopefully someone with more time will step up. I could help with some data entry if required.
Sorry to be so whiney especially when the data in there is already pretty helpful as is. I think it would be even more useful to have it nicely structured in a form we could sort by Name, True C, Capacity or any other field we choose.
Jeff
ParkJeff is offline Find More Posts by ParkJeff
Old Sep 11, 2012, 11:03 PM
So. Cal.
Hi Jeff,
I have already started to compile all of the data and hope to have it all on one spreadsheet in the next few weeks once I get a break from all of my work travel. As you see, I added a poll to the database thread to get a feel for whether fellow RCGroup members felt that the Performance Tool and Objective Database were useful.
I'm happy to see that many have responded to the poll and I'm even a little surprised that lipoly manufacturers and vendors have not voiced more displeasure that the flawed 'C' rating system that has no basis in reality is being exposed for what it is. Really glad that many find the tool and the information that it provides to be useful.
Thanks for the feedback and I hope to have it all in one place very soon.
Cheers,
Mark
New Product Cell Internal Resistance Meter - more useful than 'C' ratings - Now available. PLD Batteries and Chargers 468 Oct 05, 2012 10:02 PM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Idea Proposal for simple lipo performance figures of merit kgfly Batteries and Chargers 8 Oct 29, 2009 05:55 PM
Question What is the formula for lipo discharge amps? C ratings and such? skid_68 Batteries and Chargers 6 Nov 10, 2005 08:10 AM
LiPo "C" Ratings: Useful? RD Blakeslee Batteries and Chargers 121 Mar 17, 2005 10:02 PM
