Old Apr 17, 2012, 11:50 AM
microwave is offline
Find More Posts by microwave
microwave's Avatar
lac superieur - chemin le pointe croix
Joined Apr 2008
Originally Posted by gravityKills View Post
As the German proverb goes "wer viel misst, misst viel Mist" (he who measures a lot measures a lot of BS).
This threads previous 15th page is again just another ongoing example that there is more complexity surrounding John's SimpleTool that can do as much to confuse the "average modeller" (John) as well as the "relatively advanced hobbyist" (Wayne) than help him get the best performance/usability from his lottery packs. For all their notable good efforts the time spent with all this figuring isn't practical or necessary. A thorough pre-flight conditioning of any LiPo lottery pack will quickly determine its usability with a good balancing charger ... without the need for an ESR and having to determine the FOM of a questionable lottery pack.
Then it’s up to the average modeler and the relatively advanced hobbyist to properly utilize/care for their packs, whether they be lipos more like some of Wayne’s lottery packs from a leading Chinese distributor or Li-Polys more like some of Charles’ packs from a leading American distributor.
Wayne, John, and Mark may thrive on the challenging calculated complexity for finaling arriving at a pack's truly meaningful IR calculation ... assuming it's all being done well and good to some agreed upon industry standard OR John and Wayne's agreed upon standard. It's possible that Charles finds all this figuring, figuring, figuring to be just a little too much to expect from your average modellers as well as your relatively advanced hobbyist and therefore not really as necessary as some here may/are being led to believe.
So, the real party guilty of any possible "nit-pickin" isn't Gitchee Gumee, but more like WJM.
microwave is offline Find More Posts by microwave
Old Apr 17, 2012, 12:21 PM
TreeDiver is offline
Find More Posts by TreeDiver
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
Microwave has a sneaky contribution to this thread, with a very low C rating
TreeDiver is offline Find More Posts by TreeDiver
Old Apr 17, 2012, 12:37 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
Thank you, RCG, for the "Ignore List" function.
And thank you again Mark, Wayne, John, and others for your invaluable contributions.
Harry D is offline Find More Posts by Harry D
Old Apr 17, 2012, 12:44 PM
H2SO4 is offline
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Originally Posted by Wayne Giles View Post
Apologies for posting an old plot again but if you look at :
http://www.rcgroups.com/forums/attac...mentid=3623546
You will see that different lipos have a different temperature coefficient.
From the graph we can assume that the change is linear over a small change so that at 20degC the change for pack B is 1.3%/degC but for packC it is 3.2%/degC so that we cannot use an exact factor.
If forced to estimate, I would guess that a reasonable approximation would be about 1.5 - 2%/degC at around the 20degC area ( about 1%/deg.F at around the 70degF area)
We are only estimating here so the errors are not massive provided you don't try to correct for a large temp difference ie >3degC
The most accurate way is to soak at the correct temperature for a couple of hours!
Wayne
Much appreciated, thank you Wayne. I find it quite fascinating that the gradient of the IR/temp curve should be so characteristic for a given pack/manufacturer, almost like a signature of the specific chemistry (?).
Is there a particular significance associated with 22'C, or is it an arbitrary temperature that was picked as a good average number on which to base reporting results?
Thanks again.
H2SO4 is offline Find More Posts by H2SO4
Old Apr 17, 2012, 01:02 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
22 deg C is entirely my fault.
It just so happens to be the controlled temperature of my laboratory (hobby room). It's also the recognized average temperature of indoor controlled environments (at least in the US) so it is expected to be easiest to achieve throughout the world.
For one's own tracking purposes, any temperature is fine as long as you are consistent. For broader comparative and database reporting purposes, the 22 deg C standard is required to ensure data integrity.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 17, 2012, 02:00 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
Originally Posted by TreeDiver View Post
yes indeed.
room temp should be the same, each time you measure
22degrees, to have values that can be shared with others:
It's not that simple.
First, the temperature coefficients are widely varying, the curves even cross. This alone should give you pause. The picture speaks a very clear language regarding the usefulness of IR as advocated here.
Second, with the plot in mind you'll want to control your temperature quite accurately, and it will take a long, long time before a big pack such as 6s5000mAh reaches a homogenous temperature.
Note, the overall cell resistance is not simply the average over the area. That would be too optimistic, since different areas of the cell are in parallel, not in series.
gravityKills is offline Find More Posts by gravityKills
Old Apr 17, 2012, 02:07 PM
like a rock!
Finland
Joined Oct 2007
some have a sneaky contribution to this thread, with a very low C rating
PS if you have to say something to somebody, why not say openly who you are addressing? Weasel words like "some" make at least me wonder, whether you are trying to dodge responsibility for your actions.
Old Apr 17, 2012, 02:22 PM
gbancrof is offline
Find More Posts by gbancrof
USA, CA, Huntington Beach
Joined Jun 2005
Great advice! There's one way to instantly improve an already great thread!
I know of at least two that will get the honor of being added to my ignore list. I have been waiting for them to add something worthwhile but it's been all drivel so far.
John, Mark, Wayne,
I have been using the tool and one of my iCharger 306B's to categorize my lipolys over the last few weeks and have been amazed at how accurately the tool predicts the actual performance of my packs. It has been a huge eye-opener. Best of all it's really quick and I don't have to worry about damaging my packs by "testing" in my planes and possibly pulling excessive current. Bravo!
I hope to have the time to give back by filling out the spreadsheet and posting in the database in the next few weeks. Need to make some labels too!
G$
gbancrof is offline Find More Posts by gbancrof
Old Apr 17, 2012, 02:27 PM
microwave's Avatar
Joined Apr 2008
You are aware that such directness is considered a flaming remark and not tolerated; whereas an indirect borderline kindling flame (like Wayne calling me a b.g.t) is apparently permissible ... a fine line not unlike the fine IR line that you and I, and others find rather elusive and at times can confuse the average modeller as well as some relatively advanced hobbyists.
Old Apr 17, 2012, 02:34 PM
JohnathanSwift is offline
Find More Posts by JohnathanSwift
Greenland
Joined Mar 2012
Ah, your grasp of archaic English is amazing viz, "weasel words." You just don't hear that phrase anymore....
JohnathanSwift is offline Find More Posts by JohnathanSwift
Reply With Quote  (Disabled)
BrainFart RC-Pilot
TreeDiver's Avatar
Echt, Netherlands
Joined Aug 2003
you are right , so I corrected and addressed
Rob
Old Apr 17, 2012, 02:37 PM
microwave's Avatar
Joined Apr 2008
Yes, you can KIS. The average modeller doesn't really need and ESR or even have to determine the FOM to assess the actual predictability of questionable lottery packs from a Chinese distributor and thereby their usefulness. So, hope WJM will stop nit-pickin about such over-exacting calculations that they may find intriquing, but aren't necessary as so aptly expressed by gbancrof.
All you really need is a good balancing charger like the PL 8 or the i306B ... http://www.ultimaterc.com/forums/sho...d.php?t=124013
this charger(i306b) works much like the imax, turnigy etc chargers...just with more options for everything...such as monitoring, cycling, internal resistance, foam cutter, and motor break in power
Old Apr 17, 2012, 03:49 PM
like a rock!
Finland
Joined Oct 2007
It's used in Wikipedia for "unsupported attribution" (WP:WEASEL).
Old Apr 17, 2012, 05:10 PM
Greenland
Joined Mar 2012
I've got some wonderful Finnish friends here, and I'm always amazed at how well they speak idiomatic American english.
Actually, when I used the phrase years ago, it meant the tactical use of ambiguous words, i.e., words which, in conjunction with one another, destroy all meaning, purposefully. Lawyers are often said to use them.
Old Apr 17, 2012, 06:00 PM
gbancrof is offline
Joined Jun 2005
Originally Posted by microwave View Post
Yes, you can KIS.
I agree! That's what I used (iCharger 306B) to get IR and then plugged it in to the tool. Way easy and it proved to be surprisingly accurate after I got the chance to actually use it. No more guessing games or inflated C ratings for me.
Really grateful to those who contributed to develop, test, and publish the Lipo tool!
G$
New Product Cell Internal Resistance Meter - more useful than 'C' ratings - Now available. Inflexo Batteries and Chargers 468 Oct 05, 2012 10:02 PM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Idea Proposal for simple lipo performance figures of merit kgfly Batteries and Chargers 8 Oct 29, 2009 05:55 PM
Question What is the formula for lipo discharge amps? C ratings and such? skid_68 Batteries and Chargers 6 Nov 10, 2005 08:10 AM
LiPo "C" Ratings: Useful? RD Blakeslee Batteries and Chargers 121 Mar 17, 2005 10:02 PM
