Old Apr 14, 2012, 01:52 PM
Andy from Sandy is offline
Find More Posts by Andy from Sandy
Joined Mar 2012
According to Gerd Giese his test, their new 60C packs are real 45C packs.
A rhetorical question - why doesn't he sell them as 45C and not 60C if that is the case?
Andy from Sandy is offline Find More Posts by Andy from Sandy
Old Apr 14, 2012, 02:11 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Andy,
That is a misunderstanding, I think. Gerde Geise is the chap who tests and publishes results - he is not the maker or seller of lipos. The quote in shortened form is ambiguous.
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Apr 14, 2012, 02:24 PM
Joined Mar 2012
Sorry, a total mistake. Apologies to Gerde Geise.
So is it a case that Gens Ace have gone the way of other companies and started to get misleading with claimed C ratings?
Old Apr 14, 2012, 02:34 PM
gravityKills is offline
Find More Posts by gravityKills
like a rock!
gravityKills's Avatar
Finland
Joined Oct 2007
>> Real 60C packs
a friendly reminder from the reality department: "Real" 60 C puts your flight times in the one-minute range (one hour divided by 60) if you actually use it
My little 450 heli serves as a nice example. It's absurdly overpowered and would probably leave many people who tried to fly it with their hands shaking... To utilize a 60 C current, I'd have to replace the current 525 W motor with one that can handle 1300+ W. Common sense check, anybody?
gravityKills is offline Find More Posts by gravityKills
Old Apr 14, 2012, 03:27 PM
Rugby, UK
Joined Feb 2007
Not sure Andy, everyone who has tested seems to get the same results that the 25C packs re outstandingly good but higher ratings seem little if any improvement on them.
I did testing on the 25C and 55C and then compared IRs of 25,30,40 and 55C.
If you haven't seen it , you can see it at http://www.giantcod.co.uk/forum/view...p?f=121&t=7579
There is some off topic stuff but you can easily by pass it.
Wayne
Old Apr 14, 2012, 03:28 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
It would certainly appear as such Andy.
I lamented this fact a few days ago: http://www.rcgroups.com/forums/showp...&postcount=130
IMO, Gerd's 45C rating is extremely generous and I am highly doubtful that the Gens Ace 60C packs could even come close to sustaining multiple 45C discharges (80 seconds) to 100% DOD and survive, let alone hold a usable voltage under this load.
Hopefully, the days of manufacturers and vendors grossly overrating their lipolys are numbered as more consumers get fed up with their wild claims. We'll see...
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Apr 14, 2012, 03:32 PM
So. Cal.
Didn't mean to step on your toes there Wayne. It looks like we posted concurrently.
My apologies.
Mark
Old Apr 14, 2012, 04:09 PM
Joined Mar 2012
Wayne and Mark, Pure guess work that the marketing department has won out over the engineering department. lol.
There could be so many reasons for the bad performance of the 55C packs and the good performance of the 25C packs I can make many guesses. It will be interesting to see if new 25C packs in several months time perform as well as the ones being sold today.
Old Apr 14, 2012, 04:11 PM
So. Cal.
Originally Posted by gravityKills View Post
>> Real 60C packs
a friendly reminder from the reality department: "Real" 60 C puts your flight times in the one-minute range if you actually use it Common sense check, anybody?
An excellent point and one that is obviously lost on the manufacturers and those slapping ridiculously absurd ratings on their packs just to pump up sales. Far too many have bought into the C rating game and the time is ripe to put a stop to all of the nonsense.
If enough modelers speak out against these obviously shady rating practices, I'm hopeful that there will eventually be some improvement and consumers can have some confidence in where they're spending their money.
Fingers crossed...
Mark
Old Apr 14, 2012, 05:22 PM
microwave is offline
Find More Posts by microwave
microwave's Avatar
lac superieur - chemin le pointe croix
Joined Apr 2008
Fingers crossed...
Mark
Not So Fast ... Thunder Power lists EIGHTY-TWO(82) 65C Pro Power packs ranging from their smallest 65C 1S 325mAh to their largest 65C 10S 5000mAh and 6S 7700mAh packs. http://thunderpowerrc.com/html/G6Pro...sBatteries.htm
The "engineering department" at Thunder Power gives all 82 of these packs a maximum charge rating of 12C. We would have to assume that TPs engineers are able to support the following explanation by TPs "marketing department" ...
When your high-power EDF, 3D helicopter or other applications demands nothing but the best, G6 Pro Power 65C series batteries deliver up to 60% more power than previous generation LiPo batteries and up to an incredible 600+ cycles. Their ultra-low internal resistance (IR) also allows them to be capable of ultra-fast charge rates up to a technology-leading 12C* for charge times of 5 minutes or less.
*Max charge rate is possible when using approved charger and balancer combinations ONLY. Max charge rate is 2C when using all other combinations and 1C when charging without a balancer.
microwave is offline Find More Posts by microwave
Old Apr 14, 2012, 05:38 PM
So. Cal.
A link to manufacturer advertising is incredibly underwhelming and an excellent example of ridiculous ratings.
Here's one that's even more ridiculous (True 150C!!): http://maxamps.com/proddetail.php?pr...74-Pack&cat=46
Now produce a link where the 65C packs have been tested and demonstrated to sustain multiple 55 second (65C) discharges to 100% DOD while maintaining a usable voltage throughout the discharge, delivered a good portion (90+%) of rated capacity, and did not experience a damaging temperature rise.
We will wait.
Old Apr 14, 2012, 06:02 PM
microwave's Avatar
Joined Apr 2008
We will wait.
So are you suggesting that the excellent engineers at TP are in cahoots by colluding and conspiring with TPs marketing gurus? If you are REALLY that concerned about TP engineers adapting their scientific calculations to satisfy your truer, honester, and more accurate figures then ... WHY don't you contact an industry leader like Thunder Power and find out exactly how they scientifically justify a 65C rating of 65C.
What good is all your effort if you never confront an industry leader like TP with your supposed actual true calculations for their explanation. You just might come away with a new appreciation for your due diligence as well as TPs.
We will wait
Old Apr 14, 2012, 06:25 PM
So. Cal.
So, no data to substantiate? There's a surprise...
If you are so confident and eager to prove that TP's packs can meet the 65C claim, show the data. I am not the one asking for it. I maintain that 60C+ packs do not exist. I have searched high and low for the data and can find nothing.
As clearly stated by John at the outset, the simple tool is a 'rule-of-thumb' to help modelers get the most out of their lipoly investment, not to discredit lipoly vendors. If that happens to be a resultant outcome, then so be it and the consumer benefits.
I have no doubt that lipoly manufacturers are aware of the many threads within RCGroups and other fora that lament the ridiculousness of C ratings. If they had data that substantiated their claims, it would make sense that they would be clamoring to present said data as it would sell a LOT more lipolys. Nothing but crickets so far...
As consumers gain the tools to objectively measure and predict the performance of their lipolys, it's hoped that the current practice of dramatically overstated 'C' ratings will subside at least somewhat.
We shall see...
Mark
Old Apr 14, 2012, 07:20 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Mark one industry giant seem to agree with you...
Look at the BVM jets website, they added a section about I.R. on this page:
http://www.bvmjets.com/df_power/elec...es/Storage.htm
I think they should drop the C rating and name them by I.R.
Ron101 is offline Find More Posts by Ron101
Old Apr 14, 2012, 10:34 PM
elecfryer is online now
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
United States, CA, Camarillo
Joined Aug 2007
In general, if "us" modelers started asking for "IR" numbers prior to purchasing batteries, it would get the manufacturers attention however...........with all the different chargers (capable of measuring IR) and other IR measuring devices I can only imagine the vartiety of statements there would be based upon the numbers generated by these different devices that do NOT all work to/on the same standard!
Before "we" start talking about taking manufactures to task about their "C claims" we might want to consider about listing equipment that we believe does an acceptable job of determining "IR" in a LiPo battery (or other batteries for that matter).
Myself, I now use a CellPro 10XP. I understand that it is good however, I have no way of knowing! This week, I will be purchasing one of the IR checkers made by Wayne Giles, based upon what I have read, I trust it. The fact that I trust it does not PROVE that it is accurate however, if it's numbers and the cellpro numbers are close (within say 10%?) then I will feel a lot better!
Flame on!
Michael (of your not fryin, your not tryin!)
elecfryer is online now Find More Posts by elecfryer
New Product Cell Internal Resistance Meter - more useful than 'C' ratings - Now available. Inflexo Batteries and Chargers 468 Oct 05, 2012 10:02 PM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Idea Proposal for simple lipo performance figures of merit kgfly Batteries and Chargers 8 Oct 29, 2009 05:55 PM
Question What is the formula for lipo discharge amps? C ratings and such? skid_68 Batteries and Chargers 6 Nov 10, 2005 08:10 AM
LiPo "C" Ratings: Useful? RD Blakeslee Batteries and Chargers 121 Mar 17, 2005 10:02 PM
