Old Jan 20, 2012, 12:21 PM
Howemd is offline
Find More Posts by Howemd
Howemd's Avatar
United States, VA, Yorktown
Joined Sep 2005
1.2gHz Diversity antenna choices - low/med distance/alt
I am building my first FPV dedicated multicopter and have a question for "the best" receiver antenna setup for this mission. Looking for a low level close in setup (<50ft inside 1/2 mile) and low/medium alt within 1 to 1.5 miles.
I am running the RMRC 300mW 1.2gHz tx w/ a low pass filter on the quad
Currently for the ground station I have a RMRC rx w/ saw filter upgrade and a RMRC Optimized 8dbi Patch antenna.
I want to buy a second receiver and the Eagle Eyes diversity set-up, but what other antennas should I upgrade? For the quad, I currently have a inverted V and the stock whip. I thought about an Ibcrazy cloverleaf on the second receiver. Will that work with the stock whip or inverted V antenna or would I have to go to the bluebeam antenna set on both? Is there something better?
Thanks in advance!
Howemd is offline Find More Posts by Howemd
Old Jan 23, 2012, 10:22 AM
IBCrazy is online now
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Save your money and get a set of circularly polarized antennas. No need for diversity or the extra RX. You need circular polarization on both ends to make it work.
If you really want a killer punch (ie 1/2 mile through buildings) get a cloverleaf and a 3 turn (7.5dbic) helical. The helical is a direct replacement for your patch.
-Alex
IBCrazy is online now Find More Posts by IBCrazy
Old Jan 23, 2012, 11:19 AM
GhostRider32 is offline
Find More Posts by GhostRider32
Joined Dec 2006
Alex,
I'm getting ready to order this:
http://www.readymaderc.com/store/ind...roducts_id=508
It comes with the optimized 8dbi patch. Would it be better to substitute this
http://www.readymaderc.com/store/ind...roducts_id=552
for the optimized patch and inverted vee.
If not, what would you recommend?
GhostRider32 is offline Find More Posts by GhostRider32
Old Jan 23, 2012, 08:12 PM
Howemd is offline
Howemd's Avatar
Joined Sep 2005
-Alex
When are you looking to turn back on direct ordering through your website? RMRC is out of 1.3 ghz bluebeam whip sets with a 90 turn for the tx.
Old Jan 23, 2012, 10:48 PM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
You can find a "TrueWired" set which essentially the same as bluebeam here
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Jan 23, 2012, 11:07 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
corrected.....
rclab1 is offline Find More Posts by rclab1
Old Jan 24, 2012, 11:15 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
@GhostRider32 - My recommendation: BluBeam whips or TrueWired antenna set. Both work incredibly well. Forget the optimaized patch. CP omnis will outperform it hands-down.
If you need a 90 degree connector, order an adapter. They're cheap
-Alex
Old Jan 24, 2012, 11:18 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It might never happen, actually. I have turned back to what I love: R&D. That's how I build VAS and that's the direction I am headed. HugeOne and I have been putting our efforts together. Anything he makes and anything I make are compatible. We are on the same team.
-Alex
Old Jan 24, 2012, 11:44 AM
Joined Dec 2006
-Alex
Thanks for the help.
Old Jan 24, 2012, 11:51 AM
Howemd is offline
Howemd's Avatar
Joined Sep 2005
-Hugo
Shows y'all are out of stock for 1.3 ghz sets, when do you think they will be available to order?
Thanks in advance!
Old Jan 24, 2012, 02:13 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^Hugo makes them to order and is a bit faster than I am. It should only take him a day or two to build you one. I am working on a CNC wirebender to make the lobes faster so both of us can have a stock of wires so we can cut down on the lead times.
-Alex
Old Jan 24, 2012, 02:20 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Thanks in advance!
Oupss, corrected my online stock... Like Alex said I keep shaped antennas, just need to add coax length and connectors as customers request.
Old Jan 24, 2012, 03:20 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
ya if ur gunna be flying low. go with CP.
Toysrme is offline Find More Posts by Toysrme
Old Jan 24, 2012, 07:05 PM
joesa3rd is offline
Find More Posts by joesa3rd
Joined Nov 2011
1.2ghz long range omni "air"" antenna ?
Hugo, Alex,
how does this antenna perform "1.2ghz long range omni "air""? where are it's strengths and weaknesses.
I strange can't seem to locate an good info about antenna but I'm very interested. Already have many
flights on the SP and Clover's and love them but just looking for some more range with my single RX base
station. I'm also always open to try new kewl looking antennas
Hugo,
I see you are out of sock on this antenna but I'm curious if you build to order?
Joe
joesa3rd is offline Find More Posts by joesa3rd
Old Jan 24, 2012, 08:42 PM
Howemd is offline
Howemd's Avatar
Joined Sep 2005
Ordered, thanks for the info/help!
Discussion Low Pass Antenna Filter for 1.2GHz - 1.3GHz. Why this little thing is so expensive ? tushev FPV Talk 28 Aug 06, 2014 10:15 AM
Sold 1.2Ghz 8dBi patch antenna ecampos FPV Equipment (FS/W) 3 Dec 09, 2011 03:24 PM
Discussion small antenna for LR 1.2ghz video i3dm FPV Talk 2 Oct 03, 2011 12:44 PM
Wanted Need a 1.2GHz patch antenna and an antenna tracker ChrisS Aircraft - General - Miscellaneous (FS/W) 1 Jun 17, 2011 08:07 AM
