Old Jan 20, 2012, 11:13 AM
tanner331 is offline
Find More Posts by tanner331
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Here are some more pictures.
tanner331 is offline Find More Posts by tanner331
Old Jan 20, 2012, 02:33 PM
Eclipse_7 is offline
Find More Posts by Eclipse_7
Eclipse_7's Avatar
United States, TX, Houston
Joined Nov 2003
Very cool. I recently finished my 26 in J3 Cub, but now that Guillows is offering more of their kits laser cut, I may have to convert a few of them.
What motor/battery combo will you be using to power your Cub?
Eclipse_7 is offline Find More Posts by Eclipse_7
Old Jan 20, 2012, 06:00 PM
Matt D. is offline
Find More Posts by Matt D.
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
I like it. What are you going to use for radio gear?
Matt D. is offline Find More Posts by Matt D.
Old Jan 20, 2012, 07:55 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Here are the electronics I am using
-receiver- castle berg 4l
-ESC- castle thunderbird 6
-servos- dymond modelsport arrow 3.7 gram servo
-battery- dymond modelsport 25c 2S1P 450mah battery
-motor- go brushless 10g motor
I am not sure what size prop to use. Any recommendations?
Old Jan 21, 2012, 11:42 AM
Lance Nordby is offline
Find More Posts by Lance Nordby
I want to fly everything!
Lance Nordby's Avatar
Hillsboro, OR, USA
Joined Mar 2004
Hey, I was just up in your neck of the woods last month on a business trip. I about killed myself trying to down an entire King Louie breakfast. That reindeer sausage didn't sit well with me.
If I lived there I know I would get a lot more building in. Are you going to put skis on that baby?
Lance Nordby is offline Find More Posts by Lance Nordby
Old Jan 23, 2012, 12:33 AM
funkbox80 is offline
Find More Posts by funkbox80
Joined Jan 2012
Hey, I like your plane, is this the 24" model?
funkbox80 is offline Find More Posts by funkbox80
Old Jan 23, 2012, 10:49 PM
Barrett53 is offline
Find More Posts by Barrett53
Barrett53's Avatar
Joined May 2011
Was it pretty hard to do the conversion to add ailerons and rudder/elevator? I just received mine in the mail, and I'm considering starting this soon, is it pretty easy? This is my first balsa model that I will be building. Any advice?
Barrett53 is offline Find More Posts by Barrett53
Old Jan 25, 2012, 12:09 AM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
It is a little bit of a challenge. The elevator and rudder were already marked on the plans. They were pretty easy. the fuselage had almost no modifications other than the pushrod tubes and the servo tray. The hardest part has been the ailerons. I cut the back off of the ribs where the aileron was going to be and then I sanded them down and added balsa to the leading edge of the aileron and to the trailing edge of the wing. I used the dimensions of the piper j 3 cub for the ailerons size.
You should also look at other builds for ideas.
here is a list http://www.rcgroups.com/forums/showthread.php?t=827861
Old Jan 25, 2012, 12:11 AM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Here is a picture of my wing. Just need to sand the leading edge and cover it.
Old Jan 25, 2012, 12:19 AM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Yep it is guillows kit number 303
Old Jan 27, 2012, 10:54 AM
Barrett53's Avatar
Joined May 2011
Can you post some pictures of the fuselage so I can get an idea? I think I will only do rudder and elevator. How do You hinge them and what do I use for control horns or what? That is what I am really confused on because I have never built a balsa plane before only foamies.
Old Jan 27, 2012, 02:21 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Here are some more pictures of the fuselage
Old Jul 16, 2012, 01:42 AM
Matt D. is offline
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
Tanner,
Any more updates to this cool little plane?
Old Dec 17, 2012, 02:56 PM
tanner331's Avatar
Kenai ,Alaska
Joined Aug 2010
Hi
I just started work back on the super cub.
I just covered the first wing.
I have decided to change the covering to iron-on stevens aeromodel aerolite covering instead of tissue.
Help! Need help converting Guillow's Piper Super Cub 95 hahakingpin Beginner Training Area (Aircraft-Electric) 3 Nov 17, 2014 03:14 AM
Build Log Guillow's Piper Super Cub 95 - Brushless Conversion BennettOZ84 Scale Kit/Scratch Built 142 Jan 31, 2013 02:10 PM
Build Log Guillow's Super Cub 95 Kit #303 LC Electric Conversion gavronm Scale Kit/Scratch Built 19 Jul 26, 2012 09:33 PM
Guillow Chipmunk & Piper Super Cub 95 Fireflynj Scratchbuilt Indoor and Micro Models 2 Nov 22, 2005 11:59 AM
Guillow's Piper Super Cub 95 Capt Crash Free Flight 3 Sep 08, 2004 01:43 AM
