Old Feb 18, 2012, 04:45 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Originally Posted by Markusab View Post
...Opinion?
Looks stable. Good job! Nice mechanical mix also.
RCvertt is offline Find More Posts by RCvertt
Old Feb 20, 2012, 02:49 AM
Optimus One is offline
Find More Posts by Optimus One
Joined Feb 2012
Verry stable in hovering!....Did you maiden in forward flight?!
regards.
Optimus One is offline Find More Posts by Optimus One
Old Feb 21, 2012, 04:06 AM
Markusab is offline
Find More Posts by Markusab
Markusab's Avatar
Italy, Lazio, Rome
Joined Dec 2006
regards.
Yes, forward maiden it's no story flight...
I am working to disarm the giros, (smoothly) according to fligh direction ....
Having no dedicated cards so i need to study a system controlled from the Tx (same slide of transition) or some trick aboard...
However it all works perfectly
Cheers
Markusab is offline Find More Posts by Markusab
Old Feb 21, 2012, 05:32 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
deleted.....
nadine is offline Find More Posts by nadine
Old Feb 21, 2012, 11:51 AM
Markusab is offline
Markusab's Avatar
Italy, Lazio, Rome
Joined Dec 2006
Originally Posted by nadine View Post
Ciao Marco...Per favore non mi dimenticate!!!!
Sto aspettando con ansia,notizie da lei
Purtroppo la Eclipse 7 non è sufficiente per quello che vuoi fare... è una radio ormai datata,poche possibilità di programmi Mix e non liberamente assegnabili; oltretutto per la transizione ti occorre almeno uno slide laterale,da azionare con il dito indice (io che volo in modo 1,preferisco il sinistro,per essere pronto ad intervenire su ogni comando)
La Eclipse 7 ha due Trimpot posizionati dove non puoi usarli in volo.... andrebbe bene la Optic 6,ma poi ti mancherebbe un canale...
Ciao
Old Feb 21, 2012, 11:48 PM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Ciao
My radio is mode 1 like yours but he is not a problemm the slide pot.!The Eclipse 7 have 5 free programbill mix ,independent...it's not enaugh!???Cheers
Old Feb 26, 2012, 10:56 PM
lebrett is offline
Find More Posts by lebrett
France
Joined Nov 2008
Nadine,
7 channels could be enough, you only need enough mix to invert roll and yaw after the transition.
Edit : here is the "old" verti4's mix sketch . It was a four motors plane.(9 channel radio)
Dunno the english expression but direct french translate : Who can much, can less too. (so a 7 channel radio with a two motors plane could do what a 9 channel radio do on a 4 motor plane)
Quick translation :
Moteur avant : front motor
Moteur arrière : rear motor
Profondeur : pitch axis
ailerons : ailerons (roll)
Interrupteur de bascule des moteurs : tilting motor switch
First design used two gyros , 45° oriented from the fuse axis.
lebrett is offline Find More Posts by lebrett
Old Feb 26, 2012, 11:39 PM
nadine is offline
vtol fan
nadine's Avatar
Joined Jul 2009
Originally Posted by lebrett View Post
Nadine,
Quick translation :
Oh...Thanks!
I will give a try ,i remember that Sergio was made this vtol with 4 motors..LOL
Cheers lebrett!!!!!!!!
Old Feb 27, 2012, 12:03 AM
lebrett is offline
France
Joined Nov 2008
Sure ! Credit to Sergio.
Here the last Verti4 design link :
http://www.rcgroups.com/forums/showthread.php?t=1444330
This design now use 3 gyros.
Old Feb 12, 2013, 09:11 PM
jyothibasu1k is offline
Find More Posts by jyothibasu1k
NoT iNtElLiGeNt
India, Andhra Pradesh, Guntur
Joined Jan 2011
@ all
can nay one give me a proper thread link regarding kk board
jyothibasu1k is offline Find More Posts by jyothibasu1k
Discussion Quad. All props same orientation. Tilting 2 or 4 of the motors? Bmr4life Multirotor Talk 8 Nov 23, 2011 01:32 PM
Discussion VTOL - Tilting rotor shaft? Tomo8281 VTOLs 11 Aug 11, 2011 11:04 AM
Discussion new idea for tilting rotor shaft? rcnutt Auto Gyros 35 Jun 28, 2009 08:18 AM
Discussion Can tilting motors be used as elevators? Bugman Jeff VTOLs 2 Mar 11, 2007 12:22 PM
Build Log New VTOL builder wanting to build a VTOL mandrin13 VTOLs 27 Jan 09, 2007 04:12 PM
