Old Jan 20, 2012, 12:21 AM
Markusab's Avatar
Italy, Lazio, Rome
Joined Dec 2006
New tilting motors Vtol
Vtol success!
Vtol Maiden Flight.mpeg (3 min 51 sec)
Opinion?
Markusab is offline Find More Posts by Markusab
Old Jan 20, 2012, 01:21 AM
France
Joined Nov 2008
Stable hovering, little "pendulum". Nice design.
As you say : we want to see the transition, the trickiest phase for a VTOL.
What controler are you using ? gyros and Program Tx , KK or multiwii FC board ?
Good job
lebrett is offline Find More Posts by lebrett
Old Jan 20, 2012, 01:49 AM
vtol fan
nadine's Avatar
Joined Jul 2009
YESSSSSSSSSSS.....Another v-tol
Please share us,what stabilization system you use?!
niceeeeeeeeeeeeeeeeeeeeeeeee
nadine is offline Find More Posts by nadine
Old Jan 20, 2012, 02:09 AM
Markusab's Avatar
Italy, Lazio, Rome
Joined Dec 2006
I use Gyro and Tx progam,the video it'is really the first attempt outside garage and CoG it's exactely under the lift vector of the engines so i have to move the lipo a little bit forward (i think) to reduce pendulum effect...today in Rome Italy ,the forecast its very bad;i hope in W.end the transition will be tested and filmed too.
Tks for your apprezzation and sorry for my poor English
Stay tuned,regards
Old Jan 20, 2012, 03:09 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Will be verry usefull if you post what radio do you have ,the mix tipe,a drawing scheme wiring etc.,worth like a 1000 words!....regards
Old Jan 20, 2012, 06:15 AM
France
Joined Nov 2008
How many gyro are there ? 2, 3 ? , angle between gyros ? 90°, 120 ° ?
What sort of Tx prog and mixer are you using ? Plane, Heli ?
At the moment I'm building a prototype with H2 heli tx mixing :
-for the two front motors (pitch and aileron channel behind two gyros 90° hovering only ) ,
and a rear pushing motor ( throttle channel) with 2 servos (yaw and elevator) the tail being a close copy of the polaris's one.
Adjusting the throttle/pitch curve and playing with 2 different idling curves, I hope I don't have to move the front motors for forward flight.
Old Jan 20, 2012, 07:58 AM
Winging it Ò>
leadfeather's Avatar
Joined May 2006
Congratulations on successful hovering! I'm looking forward to seeing more progress and finding out more details of your build. Best of luck!
leadfeather is offline Find More Posts by leadfeather
Latest blog entry: Quick Stick
Old Jan 20, 2012, 04:44 PM
Markusab's Avatar
Italy, Lazio, Rome
Joined Dec 2006
Thanks for the congratulations and for your interest in my project ...
This device is very simple: the motors rotate on a shaft in carbon tube
8mm diameter: channel 4 (rudder) moves the tubes, channel 2 (elevator)
moves the servo that moves the channel 4 servo (mechanical mixer) and Channel 7 moves across the base of the mixer causing the forward tilt of the engines.
next time the block diagram and some pictures.
Regards
Old Jan 21, 2012, 04:12 AM
France
Joined Nov 2008
mechanical mixer so.....
the diagram and pictures will be very interesting
Old Jan 21, 2012, 05:53 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Verry interesting thread!..Mechanical mixing....Hmmmm
regards
Old Jan 21, 2012, 11:57 AM
v22chap's Avatar
Goshen, Indiana, United States
Joined Jan 2003
very interesting ,, especially the mechanical mixer...but that is what I started out with and really it did work the best for the area I used it on as I could get more conversion throw with the mechanical setup than with an electronic !!!!
v22chap is offline Find More Posts by v22chap
Old Jan 21, 2012, 01:13 PM
vtol fan
nadine's Avatar
Joined Jul 2009
All what we have to do,is to wait that Markusab,have a nice transition with the plane.
I have to admit that plane only with mechanical mixing,it hover really stabile..
Best regards
Old Jan 23, 2012, 01:37 AM
RCvertt's Avatar
Joined Aug 2007
Originally Posted by Markusab View Post
...Opinion?
Thumbs up. You'll get another one after the transition
RCvertt is offline Find More Posts by RCvertt
Old Jan 26, 2012, 09:53 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Old Jan 31, 2012, 11:38 AM
vtol fan
nadine's Avatar
Joined Jul 2009
Any news Markusab!?...Cheers
Discussion Quad. All props same orientation. Tilting 2 or 4 of the motors? Bmr4life Multirotor Talk 8 Nov 23, 2011 01:32 PM
Discussion VTOL - Tilting rotor shaft? Tomo8281 VTOLs 11 Aug 11, 2011 11:04 AM
Discussion new idea for tilting rotor shaft? rcnutt Auto Gyros 35 Jun 28, 2009 08:18 AM
Discussion Can tilting motors be used as elevators? Bugman Jeff VTOLs 2 Mar 11, 2007 12:22 PM
Build Log New VTOL builder wanting to build a VTOL mandrin13 VTOLs 27 Jan 09, 2007 04:12 PM
