Old Jan 19, 2012, 10:34 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
Question
where are you guys placing your separate receiver pack?
wheres a typical location to place a receiver pack? i have a lifesource pack.
im still learning and have learned alot since joining this site! i am a bit confused as to whether i should power my radio gear from a bec or a receiver pack. im hearing becs failing on some people. what are the ups & downs on becs and receiver packs? any info is big help for me!
sbach 342 60" ep
out of stock is offline Find More Posts by out of stock
Old Jan 19, 2012, 10:54 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
sbach 342 60" ep
A BEC can work very well - depends on lots of factors. Some are better than others. Some are linear regulator based designs and significantly reduce in current capacity as the number of cells goes up. Some are "switching" and generally can tolerate more cells but "might" introduce electrical interference. Some servo's require more power than others for the same "general" characteristics. Digital servos for example (I don't use) seem to be more power hungry but then again some of the cheap Chinese servos also seem power hungry.
Many of the "good" ESC's have switching BEC's that can handle 3A draw (vs 2A for linear at 3S and less at 4S). These are generally the ones I use and I have had no failures or issues (other than forgetting to validate cutoff voltage when first getting into LiPos).
It depends on the plane you are flying, how you fly it (fast, 3D), the number of servos (load) and how smooth your control setup is. I see people complaining about their BEC's failing, but there seems to be a good correlation with too much load on the BEC, inadequate cooling and or too many cells in their pack and a linear regulator that is not rated to handle that load. When in doubt, test it (all electric flyers should have a voltage, current meter that can be installed inline to evaluate at least that the prop is not drawing too much current). If not confident, use a separate battery or higher rated standalone BEC - it is not worth losing a plane.
For what it is worth, ALL of my planes count on the built in BEC. Most are gliders so the in flight load is very low on the servo. I run 6 small, quality analog servos on a 3A switching BEC with no worries but on sailplane. I would NOT do this with a conventional power plane where the servos work much harder. I think you will find that many people use 3 or 4 servos with a switching BEC that is rated at 3A.
Just bear in mind that the separate receiver battery, if not charged, can also lead to catastrophic failure.
I am sure others will pipe in!
Scott
ScottSails is offline Find More Posts by ScottSails
Old Jan 19, 2012, 11:47 PM
John Kim is offline
Find More Posts by John Kim
Panorama City, CA
Joined Sep 2004
If you are flying small foam park flyers, you have no choice but use a built in BEC due to limited pay load and space.
If your plane is large, it is safer to use separate battery for receiver and servo.
John Kim is offline Find More Posts by John Kim
Reply With Quote  (Disabled)
Old Jan 20, 2012, 10:18 AM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
I would fly a 60" WS and larger airplane only with a separate receiver pack. These use standard size servos and at least 5S packs. Not worth risking it to a BEC when there are good receiver packs (like 2S LiFe).
Ivan
ivanc is offline Find More Posts by ivanc
Old Jan 20, 2012, 10:56 AM
Speed only
Joined Jan 2012
ivan, john and scott thank you very much. What's a good receiver pack? ?
Old Jan 20, 2012, 11:08 AM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
I'm using this one or this one if the first one is not in stock and I need one badly.
There are also some on HK but they often are not in stock and takes a minimum of 10 days to get items from HK when they are all in stock.
When using 2S LiFe make sure you use servos capable of 6V. Some servos are rated for 4.8V only and may not survive being powered by a 2S LiFe.
Ivan
Old Feb 19, 2012, 07:16 PM
Speed only
Joined Jan 2012
yup thats for sure
Old Feb 19, 2012, 08:05 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
OK, nobody mentioned where to put the receiver battery.
It's your bargaining chip when adjusting the CG. When you're ready to balance the plane, then position the battery to help get the balance as close as possible before adding any extra weight to the model.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Feb 19, 2012, 08:27 PM
Speed only
Joined Jan 2012
Pete
definitely makes sense. and by the way lol i just updated this thread lmao im sorry. (your like, what the? all this information and nothing about the main topic?) thanks mate! good answer!
Old Feb 19, 2012, 08:30 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I typically place the receiver battery pack under the fuel tank in a airplane. You normally want everything forward as much as possible, to save on adding lead weight to the front of the plane to get the CG to come out correctly. But then it depends on the airplane too. Of course the small Life packs are fairly lightweight compared to Nicad or NMH packs, so it probably doesn't make much difference where you place the battery pack with them.
Now with Lipo packs, you probably want to have it in a location to allow you to remove it for charging separate from the plane. That way on the rare occasion something might go wrong the Lipo pack doesn't burn your plane up on you too.
earlwb is offline Find More Posts by earlwb
Old Feb 19, 2012, 10:05 PM
Speed only
Joined Jan 2012
is it possible to use a 6" extension from liFe pack to Rx? i mean, i tried but the Rx barely powers up. at first i thought it was the liFe pack that was out of charge but when i removed the extension and plugged the liFe directly, my radio system came to life.
yes its lightweight so maybe it wouldn't make a difference. i hope lol
Old Feb 19, 2012, 10:08 PM
Speed only
Joined Jan 2012
oooop's! double posted. sorry!
Old Feb 19, 2012, 10:12 PM
ivanc is offline
S.A.D. member
ivanc's Avatar
Joined Dec 2004
Your servo extension is no good. I use servo extensions for the battery pack all the time but the ones I use are the ones with thicker wires (22 AWG). "Standard" servo extensions use 26 AWG which is much thinner and not capable to carry power to 4 or more servos.
Ivan
Old Feb 22, 2012, 10:58 PM
Speed only
Joined Jan 2012
Ivan
actually that is very true. thanks ivan.
Question BEC or Rx pack? What do you run? northernmike Racing Boats - Electric 11 Nov 26, 2011 11:48 PM
Question LiFe or NiMH receiver pack? 320pilot Electric Sailplanes 7 Aug 16, 2011 10:40 PM
Discussion Troubleshoot strange esc or bec or receiver behaviour gordonbw Power Systems 3 Jul 27, 2011 06:57 AM
Discussion Running ESC BEC and external receiver battery pack Baz_180 Power Systems 3 Apr 02, 2011 01:36 PM
Help! Should I use a Seperate Receiver Pack or use the BEC from the Speed Controller?? tyrolean_marcus Electric Sailplanes 35 Nov 28, 2010 07:45 PM
