Old Jan 19, 2012, 10:24 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
brand name servos vs chinese servos. does it matter?
ive been hearing people saying that a servo stamped with a brand name is just about as equal to a unknown chinese brand servo. i myself beg to differ. has anyone had any bad experience with hextronic 5010's? whats a hk servo that will rival hi tech, jr, and futaba? thanks people!
out of stock is offline Find More Posts by out of stock
Old Jan 19, 2012, 10:36 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
Search a little on this column - you will find people swearing at them as well as swearing by them. I agree that there are "some' good ones, but with chinese attention to quality, products that are good today, might not be good in future. Products good last month might not be good now.
For planes I don't mind risking (no sentimental value, no significant cost, very little risk to others around me - small foamies for example) I use the "best" cheap servo I can find. I use the HXT500 and 900 from HK.
For any plane that does not fit into the above category, I use either Hitec or Futaba (because that is what LHS has by the way) and don't mind paying the price for something I believe will last (and works out of the box).
I have never had a servo fail in air but some would argue I dont fly enough. I have had servos fail on bench while setting the plane up - these were Chinese servos for what that is worth. I really do hope that more products "designed" in China actually get some QA processes behind them.
Scott
ScottSails is offline Find More Posts by ScottSails
Old Jan 19, 2012, 10:54 PM
Speed only
Joined Jan 2012
thank you scott! i dont want to risk my baby. i hear solar servos are making hi tech's look pretty bad.
Old Jan 20, 2012, 09:52 AM
Slavko is offline
Find More Posts by Slavko
United States, MI, Tuscola
Joined Oct 2006
Hi Gang,
Just thought I'd pipe up on this one. I've used both the Hex 5010's and also the HK 15138 which is similar to the Hx and also the Futaba 3004. For the way I fly I sure can't tell any difference. The 5010's are a bit noisy but when the engine is running you won't hear it. I've got both the 5010's and also the 15138's in a number of planes and they have been just fine. I also have used Futaba, Hitec, and JR's as well. If the servos you use are safe and you have confidence in them, I see no point in spending the extra on a name brand. If I were flying competition planes I suppose my opinions would be different, but for just going out and tearing up the sky they all work fine. As one of the club's instructors, safety is #1.
Slavko is offline Find More Posts by Slavko
Old Jan 20, 2012, 09:58 AM
Toppers is offline
Find More Posts by Toppers
Toppers's Avatar
Canada, ON, Oakville
Joined May 2008
Where do you think name brand servos are manufactured?
For me, it's all a question of QC.... I prefer to buy cheaper China brands (HK have served me well) and test it thoroughly in set up and pre-flights (as we should for any servos, regardless of name).
I get the occational dud, but it is quite rare and personally I feel I am getting better value with this approach.
Toppers is offline Find More Posts by Toppers
Old Jan 20, 2012, 01:56 PM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
I go with Toppers. I've used mostly Hitec. But, truthfully, I have had no more duds and reliability just as good from the Hobby King Servos. For instance, the 14MG are 14 gram metal gear servos that are comparable to the Hitec HS65MG. But they are only $8 each. So I put metal gear servos on everything. Why not? There is no doubt they are tougher than the plastic gear Hitec HS65.
fmw is offline Find More Posts by fmw
Old Jan 20, 2012, 02:29 PM
earlwb is online now
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The inexpensive servos aren't too bad. I have been using them with pretty good success. But you want to order extra ones in case you have a bad one or more than one bad one. Also so far I have not tried using the cheap servos in a really good plane so far.
Usually the cheap servos use cheap everything, at the lowest cost they can get the parts and assemble it for. When you test the servos using a servo tester, the current draw is higher and the accuracy resolution isn't as good. It is common for the gears to not mesh all that well and the output arm may wobble more due to the poorly fitted parts. Some sometimes you get some nice gems out of the deal.
Now they are getting better in making nicer servos though. I had acquired a bunch of the magnetic induction digital servos a while back. Thse servos use a magnet sensor for positioning instead of the classic feedback potentiometer. When I first hooked them up to test, I didn't put on the servo arm, and the servos were so darn quiet, I thought that they were defective. They made very little to no noise as I moved the joystick back and forth.
In the small planes or park flyers, I have used a bunch of the Hobby King HXT 5 gram and 9 gram servos, and some of their 14MG types of servos too. The HXT 9 gram servos are so amazingly cheap. Now they may not be all that good at centering precision or speed and the resolution is a little coarse, but they do work fairly well.
But when it comes to a expensive large model airplane, it gets the better higher quality brand name servos in it. I don't want a expensive plane to fail because of cheap servos.
But maybe as time goes on, the cheaper servos from China will get good enough to trust in a better more expensive airplane. I just haven't gotten to that point yet to do it myself.
earlwb is online now Find More Posts by earlwb
Old Jan 20, 2012, 02:32 PM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
I lost a plane w/camera to a "cheap" servo, once....Never again....That cost me $700.00
realtimerecon is offline Find More Posts by realtimerecon
Old Jan 20, 2012, 06:28 PM
Speed only
Joined Jan 2012
i guess since i really care about this project i should go the extra mile! its the very first time ive ever built an aircraft. i should at least make it a good PEACE OF MIND experience.
as a final word, peace of mind is what you pay for in the end. these are serious little machines - kite days are over lol cheers
ahh i love this hobby! thanks guys really.
Discussion Square vs. round carbon tubes? Also, how much does brand matter? Cheesehead Composites Fabrication 8 Jan 04, 2012 02:50 PM
Discussion Lipos Cheap VS "name brand" wagondriver42 Racing Boats - Electric 14 Dec 07, 2011 05:28 PM
Discussion ESCs, does it really matter what brand I choose? babanan Multirotor Talk 31 Aug 01, 2011 05:45 AM
Mini-Review Chinese 2.4 vs Brand Name radios. Chinese superiority John Kim Radios 74 Mar 31, 2011 05:51 PM
Discussion no name sc cells vs brand name??? mike86xj Electric Power Cars 6 Jan 27, 2007 01:25 AM
