Espritmodel.com Heli Air
Old Jan 19, 2012, 08:32 PM
Joined Jan 2012
dynam sonic 185 glider help
I am as new to this hobby as you can get. I just purchased the sonic 185 from nitroplanes. It arrived with one of the screws missing from one of the servos that hold the rudder control wire in tight. No big deal right? I believe the screw has somehow gotten wedged in th motor. My question is how do I remove the motor to go fishing for the screw without destroying the glider?
Ontario Bob is offline Find More Posts by Ontario Bob
Old Jan 20, 2012, 11:06 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Just looking at the pictures, you'd need to remove the spinner and prop... the motor must be held in the proprietary plastic mount by ~3mm threaded screws, so you'd have to unscrew those. If you take the canopy off and remove the battery (maybe the ESC too)... the motor should come out of the mount backwards.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Jan 20, 2012, 08:00 PM
Joined Jan 2012
That was way to simple. Thanks Dr. Kiwi
Old Jan 23, 2012, 04:48 PM
Dr Kiwi's Avatar
Joined May 2003
Kiwis aren't good at rocket science, but simple practical stuff we can do. Actually my brother is a theoretical nuclear physicist, so maybe he can claim to be a rocket scientist... but practical, he is not!
Old Feb 20, 2012, 03:32 PM
United States, WI, Middleton
Joined Feb 2012
Hi there!
How do you transport such a ''huge" plane?
I have Sienna 2011, but still it' seems to be ''to the limit'' of van''s capacity..
thx!
zawaprz is offline Find More Posts by zawaprz
Old Feb 20, 2012, 05:30 PM
Joined Feb 2012
Description posted on Nitroplanes about this plane says: 'easily transportable'... when I tried to chat to them, he said: talk to our tech department... funny... and yet.. nobody has a problem here?
Old Feb 20, 2012, 05:43 PM
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
First, take the wings off, then place in any sub-compact car.
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Feb 20, 2012, 06:24 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Originally Posted by zawaprz View Post
Hi there!
thx!
The wing comes off the fuselage in two pieces, each about half of the 1.85m/73" span.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 22, 2012, 11:43 AM
tripleup05's Avatar
United States, GA, Grayson
Joined Mar 2008
Is his name Sheldon Cooper?
tripleup05 is offline Find More Posts by tripleup05
Old Feb 27, 2012, 10:25 PM
Joined Feb 2012
Hello,
I have possibly silly for most of you question (am not experienced flyer can say), hoping someone would confirm what I just heard from Tech Support...
... Just got my Sonic with Mode2 radio... and.... found out, that it has different assignment of ailerons and rudder from what I used to fly... For instance in my old radio for Typhoon 3D my ailerons are on the right hand side joystick with elevator, while rudder is assigned to the left one with throttle. but.. It's different on Sonic! (too bad!! I'd hate to learn new way of controls) - in Sonic rudder is exactly assigned in opposing way then on Typhoons. Specifically Sonic's ailerons with throttle are assigne to left joystick while rudder with elevator to the right one. According to Tech. Support guy in order to resolve it all I need is to switch wires on receiver; rudder wire I should plug to aileron ch, and aileron to rudder... That effectively should change my assignment on radio to what I want. Is this true? Can someone please confirm it? - I also asked, if that in any way would influence characteristic of Sonic's physical performance (diff. angle for ailerons/rudder???) - and he said no... I don't know enough about this stuff.. Can you again confirm of what Tech. Support guy says? I've notice already ailerons have difference when it comes to receiver between two planes: For instance, on my old receiver in Typhoon, I have 2 dedicated plugs for left and right ailerons separately (2ch, one for each aileron), while here on Sonic just one plug - for both ailerons just 1 plug on receiver (newer technology???).
Many thanks in advance to whoever can explain to me those things...
Also.. I would like to use my new lipo battery that came with my Sonic on my Typhoon.. The problem though is connection to the battery. New from Sonic has 'barrel' like, while Typhoon's old type (NI-MH old battery) used different one (white with natch on side) ... I'm thinking about buying some kind of adapter... (GPMM3130???). Any opinions? My Typhoon's NiMh battery is rated as 10.8V, and 1000mha, while the new one is 11.1V with 2200mha, 25C - the voltage is just slightly higher, but the same 11.1V battery I've seen recommended by ParkZone for the lipo battery for Typhoon - so I'm assuming 0.3V difference is not a problem here... Again, any opinion would gr8tly be appreciated!
Discussion Dynam Sonic 185 sail plane Dannyrevs Electric Plane Talk 66 May 06, 2013 01:35 AM
Discussion rx for dynam sonic 185 lightfoot500 Electric Plane Talk 3 Jan 23, 2012 03:41 PM
Discussion Dynam Sonic 185 RXTX Upgrade limbatus Electric Sailplanes 5 Feb 02, 2011 11:59 PM
