Old Jan 19, 2012, 10:24 AM
fishdude is offline
Find More Posts by fishdude
UK
Joined Mar 2006
RCM Pike tip section
I want to sort out my RCM pike tip stall problem for good ,so am now looking to make new tips.
From my original post:-
The adverts imply e MH30 at the root and RG14.5
Others suggest that the sections quoted in the advert bear no relationship to the actual sections.
"The claimed Root section is the MH 30 which in fact is a thin semi-symetrical 7% thick pylon racing section. I have not checked but itmay be MH 32 - a well proven glider section. The intermediate section listed as SD7034 is a thick highly cambered section which does not match the aircraft. The actual section is close to but not quite the SD 7043 a slimmer section.
The RG14.5 I don't have the coordinates for, but the actual section appears close to the RG15. From my experience, the RG 15 will have a higher stall speed than the other root sections and will lead to tip stalls."
Other than the tip stall problems the model is very well designed and constructed and if you are willing to live on the edge it is a good design.
John "
Oct 11, 2006, 05:50 AM Report This Post to a Moderator #5
Swift
with this in mind, can anyone recommend a tip section?
Fish
fishdude is offline Find More Posts by fishdude
Old Jan 20, 2012, 02:53 PM
davidjensen is online now
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Have you moved the CG forward and backwards to see if it helps?
davidjensen is online now Find More Posts by davidjensen
Old Jan 21, 2012, 08:40 AM
fishdude is offline
UK
Joined Mar 2006
Yes done that, also intoduced some wash out which helped and increased tail area.
Now want to try building a new tip.
Fish
Wanted Looking for Pike Perfect wing tip Ken from Japan Aircraft - Sailplanes (FS/W) 2 Nov 28, 2011 06:21 PM
For Sale pike wing tip Soarkraut Aircraft - Sailplanes (FS/W) 0 Aug 18, 2011 07:23 AM
Sold Supra center section and left tip kdt Aircraft - Sailplanes (FS/W) 2 Aug 09, 2011 09:59 PM
Wanted Wanted: Pike WR Center Wing Section and Tail Feathers bretski Aircraft - Sailplanes (FS/W) 3 May 21, 2011 01:12 PM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
