Old Jan 19, 2012, 04:09 AM
miniphase is offline
Find More Posts by miniphase
miniphase's Avatar
United Kingdom, Kent
Joined Nov 2004
3 metre slope and thermal wing
I started thinking about a larger wing last year http://www.rcgroups.com/forums/showthread.php?t=1480107 but hit a patch of indecision and diy mayhem, but now's the time to revive the project.
I want to use the model on the slope and off the flat, so I'll be running with the MH45 section. I've used it in the past with mixed results, but learnt much since my early wings and feel it will serve me well on this design
my attachments keep disappearing for some reason...will try uploading them again in a few hours time
miniphase is offline Find More Posts by miniphase
Old Jan 19, 2012, 04:22 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Foam cutting and setups for such are one of those subjects that always seem to raise a lot of debate when mentioned(ANOTHER one on scratch built edfs right now)So, no Q's,but lots of pics would be welcome.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Jan 19, 2012, 04:35 AM
miniphase's Avatar
Joined Nov 2004
Hi Stuart
I will take plenty of fotos and feel free to fire away with any questions as we go along. It took me a long time to get consistent cores (lots of trial and error before the internet) and it was frustrating getting at best a 50% hit rate. Now with a few simple bits of knowledge I rarely ruin a cut, so I'm more than happy to pass on anything that may be of help.
Paul
Old Jan 19, 2012, 06:54 AM
Vernon Hunt is online now
Find More Posts by Vernon Hunt
Vernon Hunt's Avatar
Florida
Joined Mar 2005
Paul,
It's good to see you back on this wing idea. I'll be watching the progress.
Vern
Vernon Hunt is online now Find More Posts by Vernon Hunt
Old Jan 19, 2012, 07:06 AM
miniphase's Avatar
Joined Nov 2004
let's try some attachments again...
Old Jan 19, 2012, 07:12 AM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Mmmm... interesting. May one enquire what the theory behind the elevon shape is? Is it to deliberately make the tip 'draggy' to give a proverse yaw?
S
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 19, 2012, 07:27 AM
miniphase's Avatar
Joined Nov 2004
Hi Shed
If I have to dial in a bit of reflex for level flight, then the taper will give an approximation of washout with more up at the tips than inboard (therfore being less draggy).
I've also found the deeper elevon chord gives better roll response, and I'm sure I read somewhere that it's more efficient to move a large surface a little rather than a little surface a lot. This was evident out on a smaller wing I built with the MH45, I had quite narrow control surfaces, and when I increased the throw to get a better roll rate, the wing would stall out and exhibit the 'zagi death spiral' at full roll input.
Paul
Old Jan 19, 2012, 07:33 AM
Derbyshire, UK
Joined Aug 2008
Makes sense - I ask because I've done a little Xfoil work on profiles and found there to be an optimum location (%chord) for the flap hinge point. I suppose though that with the elegance of the tailless layout comes other compromises...?
Old Jan 19, 2012, 07:47 AM
miniphase's Avatar
Joined Nov 2004
do mosts section have an optimum hinge line at 25%? I tend to feel that I'd rather have more aileron 'bite' and less death spiralling as a priority....I tend to follow my nose rather than crunch numbers
Old Jan 19, 2012, 08:13 AM
Derbyshire, UK
Joined Aug 2008
Can't say. What I do know is that the two sections I've designed and flown have used 27 and 30 %. Mh32 uses 22%, can't remember what the HQ ones use.
Hmmm... "death spiraling" - can imagine you'd want to avoid that one...
On a serious note, the cruching of numbers has become so very much quicker of late (with Xflr et all) that with the cost of building our 'toys', it is [IMO] almost like a 'due diligence' check.
Old Jan 19, 2012, 09:47 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
Miniphase: I see what you mean by moving the inner flap outboard a few mm In this configuration, I'd expect that that surface would act like a flap on a conventional wing, that is near neutral in pitch. Is that your goal with this placement?
The carbon spar and D tube should be killer for flutter control. You'll need at this size. Having a plane that can handle very high speeds at the slopes is 100 times more fun.
I hope we see lots of build pics. I'm still far from 100% with my homemade foam cutter.
BTW, love your fuselage Very sleek.
I'm already jealous.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Jan 19, 2012, 10:20 AM
birdofplay is offline
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
Paul,
I was subscribed to your previous thread,
and now to this one. :-)
Go for it,
Bob
birdofplay is offline Find More Posts by birdofplay
Old Jan 19, 2012, 10:26 AM
miniphase's Avatar
Joined Nov 2004
Kent, I'll run with a carbon spar in the first instance. I'll fly the wing sheeted (but not covered) and then beef it up if needs be from there.
Yes the flaps should be pitch neutral, this will give me an extra kick of lift when thermalling and slow me down enough for those hand catches
I'm not sure of the fuz will end so sleek, I'm thinking a couple of ply cheeks that I can put a electric motor setup between (for flat field work). Maybe I'll have a lipo and esc on board all the time and have a motor that mounts on the back, in which case the pod will be thicker and will end just ahead of the cg
Shed, I'm sure I'll get round to learning Xlfr at some point, I can see the benefits of tweaking a design before the build starts...in the mean time let's cut foam!
Old Jan 19, 2012, 10:41 AM
miniphase's Avatar
Joined Nov 2004
I'm by no means a foam cutting expert, but here's how I approach things.
I've got some right angle templates that allow me to cut two sheets of 50mm foam at once so I start off cutting the blanks I need, and by doing this from one sheet on top of another, it ensures you have identical sets of blanks for each wing.
I put the foam sheets on top of some ply or plaster board and screw the templates on to the foam. This gives me 10mm or so of template sticking below the bottom surface of the foam.
I can then run my cutter down the straight edge and not worry if I come to the bottom at one end quicker than the other...I'll still end up with nice square edges.
Old Jan 19, 2012, 10:50 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Cool Paul, nice to see you up and running, I am actually starting a build as well but a small "park flyer" EPP wing :P
God speed
EZ
Edwinzea is offline Find More Posts by Edwinzea
Sold UK - Valenta Espresso 2-metre slope soarer Hogster Aircraft - Sailplanes (FS/W) 3 Jun 16, 2012 03:56 AM
Discussion 3.2m thermal 'wing miniphase Flying Wings 63 Feb 29, 2012 06:01 AM
Sold Passer 1.8m Slope/Thermal Glider Kit *NEW* **3 Colors Available** SOS-TopGunsBro Aircraft - Sailplanes (FS/W) 10 Aug 02, 2011 02:18 PM
Rave The Golden wing is a 60" forward swept wing for thermal/light air slope. kylekroker Flying Wings 47 Oct 17, 2008 10:37 PM
