I will post initial flight impressions as soon as I have it in the air. Graham |
Sweden
Joined Sep 2005
Been there done... /Mattias |
Joined Apr 2009
I ran some numbers for the wing in cruise mode, unturbulated, for a comparison. I also ran some numbers with just the tip region turbulated, as a number of people have done.
As usual, drag of turbulation not included. Included for comparison is the Zone-V2 moldie reference design in cruise. Unturbulated, the forgiving wing does not give up a whole lot to the Zone-V2. At this one camber setting, it appears close enough that some actual flight testing would be warranted. Gerald |
Joined Apr 2009
Just the wing, and no extra drag assumed for turbulators if present. Drag for the whole plane depends on lots of additional things... When comparing wings it is easier to just stick with wing numbers. The values are for comparison purposes only.
Gerald |
Neil. |
Well the wing had its maiden flight today. This was a full scratch build as I did not have a spare fuse to put the wing onto so it took a while. I wanted to keep the Zone Ver2 plane intact so that I could do comparison flights. It is cloudy and dark outside today so I will take some pics tomorrow.
It was not ideal weather for test flying on the beach where I live with a wind of about 10 to 15mph and a good bit of turbulence. However, I get very impatient with a new plane so I took it down to the beach and dialed in the initial settings while sloping a little 1m high dune. This is not a good way to get an idea of how A DLG is going to fly as it is not its intended purpose. However, initial impression is that the handling is good. I did not have the Zone Ver2 plane with me so could not compare the penetration, but so far it seems pretty good. I did a few light duty launches and was favourably impressed, although, launching into a good breeze is also not a good way to judge how the plane will launch in still air. Virtually anything will go high if the wind gradient is favourable. Tomorrow morning is looking good so I will have a better idea of how it flies after tomorrows testing. This is all without turbulators at this stage. Gerald, what would you suggest as a test procedure once I am ready to put turbulators on the wings ? Graham |
| Thread Tools | |
| Discussion Airfoil and plane design work for 2012 | G_T | Hand Launch | 171 | Dec 28, 2011 07:18 PM |
| Discussion Will this slightly different mixer set up for an Octo work? | jessestack | Multirotor Talk | 1 | Dec 07, 2011 10:45 AM |
| Discussion DLG Contest Schedules for early 2012 | FLY F3B | Hand Launch | 8 | Oct 11, 2011 12:04 PM |
| Idea ThermalPlex Small 30" DLG Design Concept for Spektrum AR6400L Collaborative Work.. | RobertTHaas | Hand Launch | 13 | Apr 17, 2011 09:20 PM |
| Alert Listed my Rex 450 SA for sale... going in a different direction | Sky_Dancer | Mini Helis | 3 | Nov 28, 2008 10:06 PM |
