Old Feb 11, 2013, 09:51 PM
G_T is offline
G_T
Find More Posts by G_T
G_T
Joined Apr 2009
I guess this weekend, time permitting, I'll see if I can gen up and test some -151 versions of the foils.
Gerald
G_T is offline Find More Posts by G_T
Old Feb 12, 2013, 01:41 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Thanks GT, looking forward for them, a second Synsegy wing is on my list
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Mar 20, 2013, 01:46 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Hello G_T
The winter gave me a break last weekend and I finally maiden the Synergy wing (116g). Total plane weight 256g. The wings were laminated with Kevlar 1oz. The fuse and horizontal stab are from the supergee (I have a mold ) and the vertical is a development of a friend of mine.
Overall the maiden was uneventful I was epecting some sort of structiral faliure (long story) but the plane handles quiet well. As it was mentioned before it climbs quiet good, I improved my launches in 10m now reaching up to 40m not very high but I had never launched something that high. After couple of dive tests it was clear that the plane was still a bit nose heavy.
On flight the plane is a pleasure to fly, the cuirisng mode is really good and can be one can thermal on it. On speed the planes moves very fast and penetrates in the wind without problem. The thermal mode still needs some twiching but is not big deal for the moment.
On highlight I noticed that the wing is very forgiving, I think it has the softest stall characteristics I had ever seen on a plane. It just dives the nose down not even 30cms and goes on. It also turns the thermals like the iner tip is nailed on the centre of the thermal quiet a nice an useful trick on small bubbles
again thanks a lot for sharing your designs and airfoils
regards
EZ
I am planning on building a second wing but using CF UD of 50g/sqm on the D-box and a layer of 25g glass on bias. I think a bit more weight on the wing wont hurt the performance.
Again than
Old Mar 20, 2013, 04:36 PM
Paul Harvey is offline
Find More Posts by Paul Harvey
Canada
Joined Jun 2009
Hi EZ,
Your flight report is encouraging me to give it a try too. Is yours a two panel hot wire cut core? I am working on a SGII style pod and boom fuselage as well, I am curious to hear a little more about how you went about the pylon/wing mount please. Any pictures showing a little more?
Hope mine turns out as nice.
Paul
Paul Harvey is offline Find More Posts by Paul Harvey
Old Mar 21, 2013, 07:50 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Hey Paul, you should definitely give it a try. THe original idea was to have it 4 panels CNC cut. BUt I was having trouble cutting the tip. SO at the end it end up being a 3 panel. So I suppose I am missing a lot of performance from the original wing tip.
THe mount is quiet simple, I am attaching some pics. I used two spidernuts, trimmed to match the boom. I first made the holes on the wings and passed through the bolts to hold the nuts in place. then with everything together I glued the nuts to the boom making sure of alignment. Once the nuts were dried I removed the wing and wrapped CF tow around the base of the nuts to secure them to the boom, I added a CF tub Ca. 8mm in diameter 3mm wall thickness which are the actual pylons. I am using M4 bolts which give the stability necessary. Finally I made a small piece to cover the pylons, I think is more esthetic than structural.
I will be building one of this in a couple of week, I hope I will not forget to take some pics of the process.
Regards
EZ
Old Mar 21, 2013, 10:45 AM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
See mine here. Same airfoils, higher aspect. 4 panel. Don't be afraid of the 4 panel. I used templates from Juzwuz and cut the outer three panels by hand only since they are so small. Plan on burning a little foam to practice. I mic'd the foam after cutting and it was within .001 for the panels I kept. The inner panel was cut with a drop bow since it was a little bigger.
See the Japanese threads I referenced for some really nice examples of pylon mount. Google chrome to translate.
http://www.rcgroups.com/forums/showthread.php?t=1853766
G Norsworthy is offline Find More Posts by G Norsworthy
Old Mar 21, 2013, 12:59 PM
Canada
Joined Jun 2009
Hi EZ and Greg,
Thanks for insights guys, that helps a lot.
I am a little camera shy with my work right now until I have had a chance to let some local club members look things over and flight test and provide feed back to try and end-up with something that they like, being better pilots and having been exposed to more in the modeling world than I, otherwise I would share some of my building too. I have to travel an hour to fly legally and the field is only open for half the year not to mention conditions and life all lining up to make flying even possible. So any one watching would be eating a lot of popcorn while waiting.
I hope to end up with something that fly's well in the hands of the new DLG pilot, can place in the middle of the pack, hold up to most of the rigors encountered, modest in terms of cost to build and own (dream sequence) and satisfy the owner enough but perhaps still wanting more if they end-up wanting to reach for the top. So nothing ground breaking, just try and make the best use of proven materials and techniques. If I ever end up with a plane that begins to meet my goals I may try and make it available to a few that show an interest regionally perhaps.
Paul
Old Mar 21, 2013, 02:02 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
Paul, from my experience better do not do the cost. If you honestly calculate, the cost of materials, tools, electricity and man hours a homemade plane cost more or less the same as on of those nice moldie DLGs. Of course the pride you fell when your own model flys, well it is priceless
MY two cents
EZ
Old Mar 21, 2013, 02:29 PM
Master of the Wind
Joined Sep 2008
I agree with Edwin. The only reason I build from scratch is if I can't get what I want on the open market. Otherwise it is not worth the time investment.
Old Mar 21, 2013, 02:52 PM
Canada
Joined Jun 2009
Guys, I agree with what you have added and would second that but for someone who likes to build, like me, it can be a different story as you have noted, so that is what keeps me involved in my little project. Thanks' for trying to help keep it real.
Sorry if I helped to trend the discussion away from the original thread topic.
Soar On ,
Paul
Old Mar 24, 2013, 01:41 PM
kajakmannen is offline
Find More Posts by kajakmannen
kajakmannen's Avatar
Gavle, Sweden
Joined Jul 2003
Anyone that knows where the sweet spot for angle of attack for the wing is?
BR / kajaken
kajakmannen is offline Find More Posts by kajakmannen
Old Mar 24, 2013, 08:49 PM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
AoA??? I XfLr5 says something like 4. But I am using 0.1 decalage and it working very well so far.
EZ
Old Mar 26, 2013, 06:25 PM
jbarnhardt is offline
Find More Posts by jbarnhardt
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
One more Synergy wing...
Allrighty, I've finally had a chance to put together the Synergy wing I'd been planning. It's based on GT's planform as published in this thread. 4-panel cores were very nicely CNC hot-wire cut by RDJay from HL60 foam. Layup is pretty traditional: 1oz Kevlar skins, doublers, and flap prefacing; CF/Kevlar LE; CF tip and center joint reinforcements; .060" CF rod spars. It came in at exactly 130g before servos/horns/linkage or peg. I was hoping for something more like 125g but I think I can still build this up under 10oz, will be shooting for 9.5oz.
The LE turned out quite good except for a small section at the 4th-panel transition on each wing that, after bagging, is a bit "pointier" than it should be. The wing is extremely rigid in torsion, and pretty stiff in bending (about the same as my disser Akcent-2). The layup is pretty dry - I bagged the skins on the mylars with paper towel before putting them on the cores and back in the bag. The surface is fully glossy where there was extra epoxy (spar and doubler areas, LE, TE) but there are dryer areas that are "textured" (see 3rd picture). All the fibers appear to be fully saturated, and there is no evidence of the skin buckling or coming away from the foam when I bend or twist the wing. My gut says this is fine structurally but if anyone thinks otherwise please feel free to comment.
This wing will be (appropriately) paired up with a GT fuse that I've been dying to put to use since last fall. As soon as I have a few flights in I'll post a mini-review of the fuse in the relevant forum and feedback on the wing in this forum. Thanks Gerald for making another set of modern foils available to the community!
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Old Mar 26, 2013, 06:34 PM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Nice work John! Those look great. I hope you can bring them to the next contest(built of course).
Lee
killercando is online now Find More Posts by killercando
Old Mar 26, 2013, 07:45 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Good stuff!
tom43004 is offline Find More Posts by tom43004
Discussion Airfoil and plane design work for 2012 G_T Hand Launch 171 Dec 28, 2011 07:18 PM
Discussion Will this slightly different mixer set up for an Octo work? jessestack Multirotor Talk 1 Dec 07, 2011 10:45 AM
Discussion DLG Contest Schedules for early 2012 FLY F3B Hand Launch 8 Oct 11, 2011 12:04 PM
Idea Small 30" DLG Design Concept for Spektrum AR6400L Collaborative Work.. RobertTHaas Hand Launch 13 Apr 17, 2011 09:20 PM
Alert Listed my Rex 450 SA for sale... going in a different direction Sky_Dancer Mini Helis 3 Nov 28, 2008 10:06 PM
