Old Feb 04, 2012, 10:55 AM
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Oups, I think the firmware got the parameters to 'weigh' backwards. The instructions are right. I'll update the files later tonight.
EDIT: The firmware files for 3.13 are now updated. Sorry for that.
I also added a guide how to mod a Futaba 10C:
https://bitbucket.org/fpvkiwi/channe...d/wiki/TxGuide
Other Tx'es are similar
FpvKiwi is offline Find More Posts by FpvKiwi
Old Feb 07, 2012, 12:23 PM
T.ing to put on air 100 models
chiloschista's Avatar
Switzerland
Joined Feb 2008
Hi FpvKiwi,
in the meantime I had an answer from ACT about their PPM format.
On port 1 PPM, on port 6 Serial.
PWM (would it say PPM ?) Signal S3D
Auf SERVO-1 kommen die BURST Impulse mit stark verkürztem Servosignal: 200µs high, 200µs low,
gefolgt von low entspr. dem ServoTiming DIV 4. Beispiel: Servo = neutral = 1.5msec DIV-4 = 375µsec.
Signal sieht dann so aus: 200µsec high 200µsec + 375µsec low.
translated ...
On SERVO-1 on the BURST impulses with greatly shortened servo signal: 200μs high, 200μs low,
followed by the corresponding low-servo timing DIV fourth Example: servo = neutral = 1.5msec DIV 4 = 375μsec.
Signal looks like this: 200μsec high 200μsec + 375μsec low.
Best regards,
Ric
chiloschista is online now Find More Posts by chiloschista
Old Feb 08, 2012, 02:58 AM
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
Thanks for the info. The format isn't supported now but would be easy to support with a custom firmware version.
Old Feb 09, 2012, 03:10 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Looks like this product would allow me to inject a mechanical pan/tilt ppm signal between my JR9503 and my DragonLink Tx without to much fuss.
cactus is offline Find More Posts by cactus
Latest blog entry: FPV mQX
Old Feb 09, 2012, 03:50 PM
cactus's Avatar
Durango Colorado
Joined Sep 2001
Originally Posted by thefeeman View Post
Fpvkiwi
Could this be used to set up a JR tx for head tracking? I.e. instead of adding channels, I want to replace 2 with the headtracker ppm stream.
Cheers
Felix
I'm looking at this for my JR9503 to add pan tilt into the DragonLink. Is your username a reference to Half Life 2 the game by chance?
Old Feb 09, 2012, 04:02 PM
Joined Dec 2007
So can you put this on the PPM output of a DX7 and then have a switch board connected to this device? On plane do I need any equipment or does the DL just detect the extra add on channels being provided by the board?
rsands2801 is offline Find More Posts by rsands2801
Old Feb 10, 2012, 02:43 AM
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
cactus: Yes adding pan/tilt is pretty easy when you already have a DL.
rsands2801: Yes it can be connected between Tx and DL. No extra equipment needed in the plane as long as your DL Rx has enough servo connectors (9 and 12 count DL Rx versions exist).
Old Feb 10, 2012, 05:54 AM
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
pm sent for adding 3 channel to my FF9/DL combo !
Cedric
GLADUS63 is offline Find More Posts by GLADUS63
Old Feb 10, 2012, 11:59 AM
cactus's Avatar
Durango Colorado
Joined Sep 2001
I started looking through the Wiki on this, but I have not found my answer yet. Can you point me to the section I need to look at if I want to connect the gimbal from an old surplus Tx up to the CW for adding pan/tilt before it goes into the DL Tx?
Old Feb 10, 2012, 07:05 PM
Joined Dec 2007
So if you add this in how do you make a board that has a few switches on it for actions onboard? for example maybe an autopilot switch off the transmitter or an ignition switch for a plane (outside of FPV)
Old Feb 12, 2012, 05:22 AM
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
cactus: that page was pretty well hidden and not very clear either. It's all improved now, including shiny pictures:
https://bitbucket.org/fpvkiwi/channe...ternalSwitches
rsands2801: The above page explains the electrical aspect. For the mechanics of an extra board, that's not something I can help with. I know it's been done with Wizard. And people in the DIY forum do that sort of thing all the time.
Old Feb 12, 2012, 08:35 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Hey Hugo or Fpvkiwi, I am ready to set my CW up for use with my Futaba 14MZ and TSLRS. Is there a tutorial or some predone config file/code I can use?
Also, I have a 12 and 8 channel TSLRS RX that I will be using in different planes. Would I need to set different modulation types (FASST MULTI, FASST 7 channel) or will the CW just tale care of the 14 channel signal when the 8 channel RX is used?
Thanks!
techspy is offline Find More Posts by techspy
Old Feb 12, 2012, 09:03 AM
Up up and away!
FpvKiwi's Avatar
Sweden
Joined Oct 2010
If you just want to condition the signal to create a valid DL 12ch;
Set Dial = C and connect 12ch PPM input
Turn on power
Press button 1
(LED blinks)
Press button 1 again
(LED stops blinking)
Done.
I don't think you ever change the modulation when using TSLRS? You can set the Tx to 12ch PPM regardless of 8 or 12 ch TSLRS Rx.
Old Feb 12, 2012, 09:05 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Cool, thanks!
Old Feb 12, 2012, 09:50 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
ok, another question....
I was planning on installing the CW inside the TSLRS TX. But, I may be using my TSLRS with another system at times that has a "normal" 8-9 channel ppm signal. Will this be a problem with the CW? Should I just use it externally when need or will it work with non standard and standard ppm signals without reprogramming it each time?
New Product Channel Wizard: Flexible PPM encoding/decoding/mixing FpvKiwi DIY Electronics 36 Feb 10, 2012 02:24 AM
Discussion Converting a PPM 9 channel to PPM 8 channel....... lazy-b DIY Electronics 5 Mar 10, 2011 11:22 AM
Question PPM decode + PWM encode in one PIC AnthonyRC UAV - Unmanned Aerial Vehicles 31 Mar 04, 2008 04:10 PM
Question PPM decode + PWM encode in one PIC AnthonyRC DIY Electronics 14 Jul 03, 2006 01:26 AM
