Old Feb 24, 2012, 06:43 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Originally Posted by vespa View Post
Too late for you jojo but others might want to pay attention to the fuselage servo arrangement. Note that they are intended to go the other way around -- the stagger in the tray is intended to bring each servo closer to the side with the pushrod. This provides much less friction and flex in the pushrod and also ensures the pushrods won't hit the ballast or the other servo. If I hadn't seen so many (every single one) Pike Perfects built with the servos backwards I wouldn't be so sensitive.
I know.... It will be corrected. I was sure I needed the space for a large horn on the elevator.. But will not be corrected today because I will fly in just 8-10 hours after some sleep Be sure I have good support on the pushrods as they bend
jojoen is offline Find More Posts by jojoen
Old Feb 25, 2012, 12:10 AM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
Hi Jojo,
What's the advantage for using big servo arms? Hope all is well.
Best,
Vic
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Feb 25, 2012, 01:34 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Originally Posted by PDX Slope Pilot View Post
Hi Jojo,
Best,
Vic
Deppends on the arm at the elevator...
It is a gear. They have to correspond with each other.
Old Feb 25, 2012, 03:06 AM
Adrie1966 is offline
Find More Posts by Adrie1966
Nederland, ZE, Zierikzee
Joined Dec 2010
JoJo , i hope you post some video if you going to fly your perfection.
Good luck with your maiden.
Adrie
Adrie1966 is offline Find More Posts by Adrie1966
Old Feb 25, 2012, 07:57 AM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Originally Posted by stefanoc2 View Post
Picture #17, detachable tail fin ... very interesting.
Stefano
I'm confused here. The fin appears to be an integral part of the fuse like on most gliders. Which picture shows a detachable tail fin?
Miami Mike is offline Find More Posts by Miami Mike
Old Feb 25, 2012, 08:39 AM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
fin
picture 17 of 19. Slides on with two pins it looks like. bottom left pic of last batch..
BrianSmith is offline Find More Posts by BrianSmith
Old Feb 25, 2012, 11:23 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
This one...
target is offline Find More Posts by target
Old Feb 25, 2012, 11:42 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Have some video also. But that takes time and good pc... Will see... But I took some frames from the videos.
First day was great but the winds were a bit high (6-10m/s). Luckily I had made ballast for the fuse also so used 660g in wings and 300g in fuse. Almost 3kg total... It felt light still but good speed!! Got a couple of huge thermals after some huge 240m launches. Rudder is for sure better and speed was good even with only 300g ballast in. Felt very stable on landing. A good first day out but cant say too much because of the conditions. Wing was bending but not more than what I am used to from strong perfects. The kick from the elevator seems very good and no problems what so ever with these heavy launches
Old Feb 25, 2012, 12:24 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
What a gorgeous plane!! Cool trick with the Gopro on the line -- can't wait to see the video! How'd you switch the fuse servos? Did you have to replace the rudder pushrod? Are they hypo tubes in pillow blocks like the Perfect?
vespa is offline Find More Posts by vespa
Old Feb 25, 2012, 01:17 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
I hope video in an hour or two but deppends if laptop can take it...
The pushrods are 1,5 glassfiber with teflon outside. So I took the "old type tube" and glued on to get the rudder one longer.
Old Feb 25, 2012, 02:00 PM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
I wonder why not carbon rods, lighter for sure. Any reason?
roydor is online now Find More Posts by roydor
Old Feb 25, 2012, 02:02 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
I would think because the elevator rod needs to bend slightly.
Old Feb 25, 2012, 02:03 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Here is a short video. But nice enough for me
Pike Perfection first flights in Norway (Strandefjorden, Valdres, Fagernes) feb-12 (1 min 37 sec)
Old Feb 25, 2012, 02:28 PM
Robert Burson is offline
Find More Posts by Robert Burson
AZ Outback
Robert Burson's Avatar
Joined Dec 2000
Jojo
As always you have the best and most original photography, bar none.
Great photos and video.
Robert
Robert Burson is offline Find More Posts by Robert Burson
Old Feb 25, 2012, 03:46 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Thanks Robert!
This video from Audun a local flier might show that the conditions were not that super fancy for the motor guys... This flight I was "empty" with only 300g ballast (the real maiden)
Jo testing his new Samba Models sailplane (2 min 13 sec)
Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) rapyd Aircraft - Electric - Helis (FS/W) 7 Jul 25, 2011 06:44 AM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
