Old Jan 19, 2012, 10:06 AM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Originally Posted by Larry Jolly View Post
JoJo,
Please explain why you prefer this layout over the route chosen by Philip and Bemjamin???
The model loks like a a 2 piece wing Prestige , with Perfect sections...
How do you see this as an improvement to Perfect, as you can already get a Perfect in this weight range?
Will you fly it in Cyprus?????
Good luck with the new toy.
LJ
Well travelling I would like 3 piece wing. Actually before EC I wanted initially 2 piece but smaller model so it fitted my box... So now I need to build box but that is ok. It stills goes well in airline companies I use.
The reason i prefer it in other ways is that I think it will shift the weight even further into the midpart of the model. As expained before there is no need for joiners, pins, endgrains, etc. The Perfection wing is built in most ways like the Precision and we know how that helps in torsion rigidity.
It also means less work putting things together and ballast comes in the right spot.
But not only that. You also know that Prestige fuse weights came down by more than 100g using this kind of fuse and also the elevator is genious. Philip and Benjamin and whoever contributed to the Prestige did a nice development there.
jojoen is offline Find More Posts by jojoen
Old Jan 19, 2012, 10:24 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
First flights today and the comments so far is "Good reaction on rudder and ailerons as hoped for. Feeling of lightness and no drag".
Regards Jojo
www.jojoen.no
www.f3j.com
Old Jan 19, 2012, 10:25 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
JoJo,
LJ
Forgot to answer this.
Yes I hope so. But it all deppends on a lot of factors.
Old Jan 19, 2012, 11:18 AM
stefanoc2 is offline
Find More Posts by stefanoc2
stefanoc2's Avatar
United States, TX, Houston
Joined Aug 2006
Jojo,
the length of flaps compared to ailerons looks shorter than in other models.
I am guessing it still slows down on lading because of the lighter weight. Is that the case?
Stefano
stefanoc2 is offline Find More Posts by stefanoc2
Old Jan 19, 2012, 11:47 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Originally Posted by stefanoc2 View Post
Jojo,
Stefano
Flaps is actually 1cm longer than the Perfect
One thing... I am not in Czech Republic but get picture/feedback on it all the time and chime in as much as I can. Latest was that they nailed the elevator setting and it is perfectly in center with normal flight without any adjustments. So calculations were obviously good (CG at what we expect will be the most used 109-110mm)
Jojo
Old Jan 19, 2012, 12:03 PM
Just flyy is offline
Find More Posts by Just flyy
Yep it's Phil!
Just flyy's Avatar
United States, CA, San Diego
Joined Apr 2007
Ok!
I'll take one!
Phil
Just flyy is offline Find More Posts by Just flyy
Old Jan 19, 2012, 02:16 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
Pike Perfection... so does this mean that the Superior was only just better, and the Perfect really wasn't? Just wonderin...
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Jan 19, 2012, 04:28 PM
Gungho is offline
Find More Posts by Gungho
Gungho's Avatar
Singapore
Joined Aug 2006
Will it come with and Electro fuse?
Gungho is offline Find More Posts by Gungho
Old Jan 19, 2012, 10:18 PM
Crash Prone is offline
Find More Posts by Crash Prone
Crash Prone's Avatar
United States, WA, Port Orchard
Joined Feb 2011
Sweet! Now maybe I can afford a Perfect!!!
(Who's selling?)
Crash Prone is offline Find More Posts by Crash Prone
Old Jan 20, 2012, 07:05 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Iceland, Siglufjörður
Joined Sep 2008
Subscribed
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Jan 20, 2012, 09:41 AM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
I understand another well known manufacturer in Bulgaria will also have a new fuselage along the same general lines. Who would have thought so many F3J designs would sprout from the little " Miles" LJ
Larry Jolly is offline Find More Posts by Larry Jolly
Old Jan 20, 2012, 09:50 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Does that imply that the Perfection wings will come with RDS and or sealed servo locations, JoJo?
R,
Target
target is offline Find More Posts by target
Old Jan 20, 2012, 10:42 AM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
I'll take one!
Phil
I'll buy it from you two weeks later!
Clay
ClayH is offline Find More Posts by ClayH
Old Jan 20, 2012, 11:15 AM
Big Browns is offline
Find More Posts by Big Browns
Phoenix, Arizona
Joined Dec 2008
Good looking plane Larry!
Big Browns is offline Find More Posts by Big Browns
Old Jan 20, 2012, 11:18 AM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Just watchin...
Daryl Perkins is offline Find More Posts by Daryl Perkins
Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) rapyd Aircraft - Electric - Helis (FS/W) 7 Jul 25, 2011 06:44 AM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
