Old Oct 12, 2012, 11:23 AM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Originally Posted by Daryl Perkins View Post
Question for you Pike Perfection pilots:
The Perfection has an articulated elevator as opposed to a full flying stab (Full flying has been previously considered optimum for nosing over at slow speed and nailing the spot). Have any of you noticed a lack of control authority trying to nose over and nail the hunski? This could show up when flaps are deployed, and the elevator is already close to full deflection due to flap to elevator mix.
Just curious.
D
It is agood question since elevator might be in the turbulence of the wing. But it seems to be no issue on that.
"Nosing over" is different when flaps is deployed or not. But with flaps deployed it is still better than the Perfect or Xplorer 1 (even with large elevator). I know as I have flown a lot of 3.8 X1. With flaps in it is nosing over very fast so I have slowly this year learned to slow down and push both sticks on landing. This also prevents me forgetting to take in the flaps not having damage to linkage, hingeline or servos.
I even use 40% expo on elevator since it is so crisp.
jojoen is offline Find More Posts by jojoen
Old Oct 12, 2012, 01:18 PM
Neil Jones is offline
Find More Posts by Neil Jones
Joined Jul 2012
Just curious.
D
Daryl - I haven't experienced any real differences in the LZ, infact it seems very positive in this area.
However I notice a less positive response when pushing over to level flight after the zoom and feel I have to push over a little sooner while there is a bit more speed compared to the all flying stab of the Perfect.
Regards
Neil
Neil Jones is offline Find More Posts by Neil Jones
Old Oct 20, 2012, 11:15 AM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
My understanding was that an all flying tailplane was less efficient than an articulated elevator. In the sense that they can create more drag, if the flow separates early due to a 'severe' control input.
Wing-span is offline Find More Posts by Wing-span
Old Oct 20, 2012, 11:20 AM
vespa is online now
Find More Posts by vespa
First pull up, then pull down
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Yes a hinged elevator is more efficient but has a limited range of motion. So for 99% of the flight hinged is better. For landing it's possible to run out of authority with a hinge but AMTs are unlimited -- hence the question.
vespa is online now Find More Posts by vespa
Old Oct 20, 2012, 11:24 AM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Vespa,
Absolutely, I'm sure I posted about the subject 3 or 4 years ago.
Old Oct 22, 2012, 10:41 AM
Neil Stainton is offline
Find More Posts by Neil Stainton
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Maybe, but most of the time the glider pilot should not be using extreme control inputs, and for small control deflections the all flying tailplane will be better.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Oct 25, 2012, 03:27 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
I think the real advantages are for the 'ping' and nailing a landing. Perhaps non elsewhere that I can think of.
Old Oct 25, 2012, 03:29 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Neil,
Which is the item, thingy, used to fly the 200m height rules F5J. Have I got my wires crossed?
Old Oct 25, 2012, 05:46 PM
Joined Feb 2001
As far as I know the The RC Electronics Altimeters are the only ones approved for UK eSoaring, and FAI sanctioned F5J events, though each event needs different firmware loaded.
They are available here:
http://www.esoaringgadgets.co.uk
http://www.electricsoaring.co.uk/altimeters.html
The CAM unit we sell is only approved for BARCS electric events.
Neil.
Old Oct 27, 2012, 02:06 PM
Chuck it and see!
Wing-span's Avatar
Joined Sep 2006
Thank you Neil.
Old Oct 28, 2012, 06:03 AM
Joined Jul 2012
Pike Perfection stab and elevator response to random electric soaring altimeters in just 2 posts. Nice
Old Oct 28, 2012, 10:09 AM
Silent-AV8R is online now
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
Downwind turns cannot be far behind!!!
Silent-AV8R is online now Find More Posts by Silent-AV8R
Old Oct 28, 2012, 06:11 PM
vespa is online now
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Oh boy. I'm sure there are lots of folks out there who still believe that downwind turns are a myth. Around here we call them folks "flatlanders".
Old Nov 04, 2012, 02:55 PM
tewatson is online now
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Perfection maiden
First flights on Perfection today... Standard C68 layup, came out at 2,020g (71.25 oz) all-up with CG at 113mm. Got launch settings, differential and rudder mixing pretty close. Launches and turns well.
Initial impressions are a wide speed range, with ability to run nicely in reflex yet slow way down with a few mm of camber. Noticeably absent is the tendency to steepen bank angle while circling, with minimal to no cross-controlling needed. Rudder is quite effective (as expected) and elevator authority seems more than adequate, even with full flaps deployed. The drooped nose is nice for sticking landings.
More testing to follow, including mono launches and ballast.
Tom
tewatson is online now Find More Posts by tewatson
Old Nov 12, 2012, 12:20 PM
Team JR Air
tewatson's Avatar
Joined Oct 2006
Perfection install
Some Perfection install pics. A nice touch is that Samba builds in ribs on both sides of the wing servo bays, which saves me the trouble of doing it. I added an extra layer of carbon cloth to the servo bays as well. Fuse tray only required adjusting the openings to align the servos with the pushrods.
Battery is a Hyperion 1,450 LiFe (unregulated) and the RX is a Spektrum AR8000X.
Tom
Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) rapyd Aircraft - Electric - Helis (FS/W) 7 Jul 25, 2011 06:44 AM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
