Joined Feb 2011
Eddy, The pin must be fully inserted into the elevator tube to assure correct throw.............. From - http://www.f3j.com/perfection/instru...tions_text.pdf
Anthony. |
The settings in the instructions were written down very early in the testing phase and after a lot of questions on my settings (especially after WC in South Africa) I decided it was time to check what my 3 model were set up for and rewrite the instructions. The settings is a personal thing and you set up the plane like you want. All people have different ways of using the sticks and while some have long sticks in a tray the next one might want short ones on a hand held radio. But the settings should now be a good starting point for those that dont want to use too much time on setup flying.
The reason for explaining a method of setting up the flap servos is that it is too many pilots that have problems installing and using way too long horns. So a minimum of helping them was written down. With servos in neutral the arm will be about 20 degrees towards the flap. And with offset it will be straight up. This should be a decent amount of offset applied but more can be done as you have done. But not all trasmitters can do so much offset so the stated amount of offset should be easy to apply for all or most radios. Another issue is that I like my arms to be straight towards the flap when full butterfly applied. This means the load on the servo/gear is less when the flap is out when model is hiting the ground. If you are happy with your setup there is no reason to change just because we rewrotethe instructions. Happy pilots is what Samba wants. Regards Jojo www.jojoen.no Webmaster at Samba but living in Norway.. ![]() Quote:
Sensitive subject alert... warning, warning... ;-)
Question for you Pike Perfection pilots:
The Perfection has an articulated elevator as opposed to a full flying stab (Full flying has been previously considered optimum for nosing over at slow speed and nailing the spot). Have any of you noticed a lack of control authority trying to nose over and nail the hunski? This could show up when flaps are deployed, and the elevator is already close to full deflection due to flap to elevator mix. Just curious. Thanks D |
The slow speed elevator authority has never been a hindrance for me although I don't think is is quite as good as my 3.5 Maxa with the large stab. There is a physical limit with the Perfection due to the tip of the elevator hitting the tail boom. Just enough travel for me... Keep in mind this comes from a guy that struggles with the Hunski with any model
![]() How is the Vixen? Have you tried the larger stabs yet? Quote:
USA, KS, Wichita
Joined Sep 2002
DP,
I am seeing no issue nosing over on my Perfection. I even have blemish on the nose of mine from nosing over smacking the nail at the Masters. Landing was about the only thing I did well on at the Masters. The plane reminds me a lot of the I2 in the landing zone. See ya, Pat [/B] Quote:
| Thread Tools | |
| Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) | rapyd | Aircraft - Electric - Helis (FS/W) | 7 | Jul 25, 2011 06:44 AM |
| Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section | Lancer263 | Aircraft - Sailplanes (FS/W) | 0 | Nov 11, 2010 11:07 PM |
