Old Apr 02, 2012, 11:00 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Sure Keith, Perfect was very good, and the mods made it even better, but I believe evolution will go on
Tuomo is online now Find More Posts by Tuomo
Old Apr 02, 2012, 12:07 PM
vespa is offline
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
The larger the fin is, the more dihedral is needed to maintain spiral stability and vice versa. The popularity of Kolb joiners would then suggest that the Perfect had too large a fin.
vespa is offline Find More Posts by vespa
Old Apr 02, 2012, 12:46 PM
Neil Stainton is offline
Find More Posts by Neil Stainton
HyperFlight Support
Neil Stainton's Avatar
United Kingdom, England, Stratford-upon-Avon
Joined Feb 2001
Or that people now prefer models with more lateral stability than was popular before Dr Drela popularised this.
Neil.
Neil Stainton is offline Find More Posts by Neil Stainton
Old Apr 02, 2012, 02:15 PM
Tuomo is online now
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
If I remember Perfect modifications right, it happened the other way round. More dihedral came first, larger rudder was relatively late mod.
Old Apr 02, 2012, 03:44 PM
s2000 is offline
Find More Posts by s2000
so. cal.
Joined Jan 2006
Anyone notice the fin "wobble" or flex in the video pointing towards the tail that Jojo posted?, seems like the fin/rudder removable portion looks almost loose.
s2000 is offline Find More Posts by s2000
Old Apr 02, 2012, 03:50 PM
SaltyOne is offline
Find More Posts by SaltyOne
Stamford, CT
Joined Feb 2002
s2000 - your are right. I took a closer look at the video. That fin is wobbling all over the place. I hope they get that issue resolved in the production version. It would a shame to see such a beautiful plane go in because the fin blew off.
SaltyOne is offline Find More Posts by SaltyOne
Old Apr 02, 2012, 04:00 PM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
I think it is just normal flex under flight loads. Early in the video where he shows the fin view during launch, there is a large rudder input. Under launch loads, things are going to flex. I'm pretty sure that none of this flex is visible from the ground. I'm sure that if you took a video of the tail of most modern F3J models you would see this type of flex. I think having the stab in front of the fin just makes it look worse than it really is.
Tom
Kiesling is online now Find More Posts by Kiesling
Old Apr 02, 2012, 04:38 PM
s2000 is offline
so. cal.
Joined Jan 2006
I feel fairly confident in saying if that fin was a permanent part of the fuselage it would not be wobbling that much, there are some strange Gremlin's at the base of that fin that are not natural flex. Yes sure any modern ship has some flex, but not this kind. I'll hang on to my Aspire for now.
Old Apr 02, 2012, 08:44 PM
Tom Gressman is online now
Find More Posts by Tom Gressman
Joined Aug 2005
What are the aerodynamic, including airfoil, and structural differences between the Kolb Prestige and the Samba Pike Perfection?
Tom Gressman is online now Find More Posts by Tom Gressman
Old Apr 02, 2012, 10:36 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You could likely either glue the fin solid to the base, or temporarily with silicone type adhesive and tape as usual.
Either one should eliminate or minimize any wobbling from clearance between the tube and joiner, I would think.
target is offline Find More Posts by target
Old Apr 02, 2012, 10:49 PM
lesterpk is offline
Find More Posts by lesterpk
lesterpk's Avatar
Australia, WA, Perth
Joined Oct 2003
FWIW the new Supra have the same problem. The fin/rudder is slid on the back of the boom and a pin goes through the rear retaining ring. While practicing for the last F3J WC we noticed the severe movement of the fin, especially during launch. The fix was/is simple, tape around the front ring and partway up onto the fin to secure it. Probably all thats needed in this case as well.
lesterpk is offline Find More Posts by lesterpk
Old Apr 03, 2012, 12:09 AM
vespa is offline
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
Guys, that very slight movement of the fin is a fraction of the slop that can be seen in every v-tail ever made. Furthermore, that slight movement pales in comparison to the boom flex. Don't worry about it.
Old Apr 03, 2012, 06:35 AM
Robert Burson is offline
Find More Posts by Robert Burson
AZ Outback
Robert Burson's Avatar
Joined Dec 2000
Just to have a removeable fin, makes the Supra, special. It is worth the work to secure the fin.
Robert Burson is offline Find More Posts by Robert Burson
Old Apr 03, 2012, 07:15 AM
Tuomo is online now
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
The way how fin attachment is done in Perfection is actually very std F3X technology - same idea used in 2-piece v-tails all the time. The fin is quite large, but basically I see no reason why the attachment would not be reliable.
Old Apr 03, 2012, 07:43 AM
s2000 is offline
so. cal.
Joined Jan 2006
So I guess the moral of the story is, I need to just go have fun with my airplanes and not worry about what a camera shows, and please, nobody stick a camera pointing at the tail of a V-tail! I don't want to know!
Sold T-Rex 550FBL 3GX V2 "PERFECTION" (SOLD) rapyd Aircraft - Electric - Helis (FS/W) 7 Jul 25, 2011 06:44 AM
Wanted Pike, Pike Plus, Pike P or Pike WR Wing Center Section Lancer263 Aircraft - Sailplanes (FS/W) 0 Nov 11, 2010 11:07 PM
