Old Jan 18, 2012, 01:50 AM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
Delta or WYE wound motors. Which is better?
Which is better for multirotors?
Saw this explanation and from what I can tell, WYE is better but also more sensitive to the ESC timing option we choose. Does this sound right?
I have seen some blue wonder motors where there is one wire coming from the motor and others where there are clearly three separate ones. Is this how we can tell if the motor is Wye or Delta?
RCvertt is offline Find More Posts by RCvertt
Old Jan 18, 2012, 01:56 AM
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
I watched a friend of mine over Xmas painstakingly rewind 4 Turnigy D2822/14 motors from delta to "Y" and he swears they have more torque. I probably couldn't tell the difference, but he knows his quad back to front.
Erknie is offline Find More Posts by Erknie
Old Jan 18, 2012, 01:58 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
I've always been told more poles have more torque.
so, ideally, a high pole count motor should work well for multirotors.
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jan 18, 2012, 03:08 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Are the poles the spokes that the motor wire is wound around? Or is the magnet count the same thing as a pole count?
So a flat motor with more poles with a WYE wind and an ESC set to the correct high, medium, or low timing setting sounds like a good combo.
I still don't understand how we can visually tell the difference between a delta and WYE wound motor
Old Jan 18, 2012, 09:59 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Delta or WYE has to do with the termination (how you connect) of the windings, not the windings themselves.
There are 3 wires and 6 ends for a typical brushless motor.
If all three wires are connected at one end and the other ends of the wires go to the esc it is a WYE of Y or Star connection.
Check out the picture below.
For the same winding, a Delta connection will have 1.73 times the kV of the Y connection.
For the same kV there is no big difference in efficiency.
Great info at this link Electric Motors part 1-5 click on the link to articles to get to the individual articles.
leadfeather is offline Find More Posts by leadfeather
Old Jan 19, 2012, 02:12 AM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Thanks. Sounds like Delta is a little lighter then.
I'd be interested in seeing some test results between the two windings, on the same type of motor and at the same kv.
Old Jan 19, 2012, 08:20 AM
Winging it >
Joined May 2006
The weight ends up about the same as does the efficiency. For the same kV a Y ( WYE, star) requires more turns of wire. To get the wire to fit, the wire has to be a smaller gauge; so in the end you'll have about the same amount of copper.
I think if you post this thread in the electric motor forum you'll get some very good answers form the "gurus" on the pros and cons of Y and Delta.
Bellow is a snip form a chart of a lot of different winds for a Blue Wonder type motor. More of this kind of info in the BW winding thread.
Mini-HowTo Rewinding brushless motors WYE or Delta IBCrazy North Coast Electric Flyers 146 Aug 18, 2016 08:04 AM
Help! Which of these two motors is better? - 2000kv RCX OR 2840kv Hobbyking???? vineet_p Multirotor Talk 0 Oct 24, 2011 05:19 AM
speedy cdrom; what is better:more winds delta or less winds wye submarco Power Systems 3 Dec 02, 2005 09:40 AM
Cool tool for changing numbers of winding and diameters wye/delta - delta/wye powerditto Power Systems 1 Nov 05, 2005 12:17 PM
Are AXI's wound wye or delta ? raymcm Power Systems 11 Feb 17, 2005 05:45 PM
