Old Oct 08, 2003, 01:24 AM
TJJ is offline
TJJ
Find More Posts by TJJ
TJJ
TJJ's Avatar
Erie, CO
Joined Jun 2003
What happens if you run a LiPoly to zero? (Alternate title: Up a tree without a clue)
Unfortunate mishap with a tree and my SlowStick right at dusk means she spends the night 30 feet up until the light of day. (I'm sure I'm not the first guy to get one stuck in a tree, but I sure feel stupid!) I'll fetch my rope, harness, and prusicks and get up the tree in the morning, but what am I going to find?
I have a TP2100 3s1p and PHX 25 on the SlowStick (with a MP Jet BL) and obviously was unable to disconnect the battery. I'm assuming the battery will power the receiver and servos until it's dead. And I know LiPoly doesn't like less than 2.5-2.7v per cell. My guess is I'll have a bloated sausage for a battery (too bad, only about 10 charges on it too).
Assuming all goes well with my ascent tomorrow, I'll post a pic of the battery and the verdict. Hopefully I'll get some sleep tonight, I'm still picturing the little red LED on the ESC blinking out to me in the darkness. She was desperately signalling me to help her down, and now all I see is the blinking. It's getting weaker and dimmer as the hours go by, until finally, there is, nothing. It's going to be cold tonight too. Sleep well SlowStick.
TJJ is offline Find More Posts by TJJ
Old Oct 08, 2003, 02:45 AM
Suzanne is offline
Find More Posts by Suzanne
Germany
Joined Dec 2001
Try to slow charge each cell at 100mA until it reaches 3V. Then, charge each cell individually to 4.2V, if possible. Watch the pack while you do this.
If all goes well, the cells will survive.
Suzanne is offline Find More Posts by Suzanne
Old Oct 08, 2003, 03:20 AM
drewjet is offline
Find More Posts by drewjet
drewjet's Avatar
Central Florida
Joined Oct 2001
No you are not alone. Exact same thing happened to me. My 3 cell etec was down to 3.0 volts for the whole pack, or 1 volt per cell. It would not take a charge on my ginzel in Lipo mode. So I charged in Ni-cad mode till it got to 9 volts. Then aborted and charged in Lipo mode. It still works but is maybe 10% weaker than my other etec 3S packs.
drewjet is offline Find More Posts by drewjet
What happens if you don't know what you're doing when towing.... 96S14 Scale Sailplanes 5 Nov 22, 2004 02:22 PM
What happens when you run 74 watts through a 6.8 oz. flying wing? Tres Wright Parkflyers 8 Sep 14, 2004 06:22 PM
What happens when you run out of model memory on your Transmitter??? Ralph_D Parkflyers 27 Dec 20, 2003 07:50 AM
This is what happens when you run too many amps through your ESC... thomer Power Systems 23 Aug 26, 2003 09:51 AM
What happens if you plug a servo into the rx backwards? Ben C Power Systems 7 Nov 25, 2001 04:02 AM
