check to see if the failsafe is on , if it is it will disable the gyro .
i have had a few slowly fail on me and just flash , but if you could still bring up the programming , then it may be the failsafe |
Latest blog entry: NH airshow
Mt helena western australia
Joined May 2009
servos dead =( no response when plugged into the receiver, only responds when plugged into the gyro and you try to move the horn and apply rudder then, still dont know how this could of happened as it was working perfectly when i landed it.
is that the hk fake futaba 9257, i think thats only 4.8v , you need to lower the voltage to the servo .
.http://www.valuehobby.com/radio-syst...is-es9257.html Specification Size:35X15X30 mm (1.38X0.59X1.2 in) Weight: 22g (including connector wire) Speed: 0.05 sec/ 60° @ 4.8V Torque:: 2.5 kg.cm (34.7 oz.in) @4.8V 34.7oz/in Sensitivity:1 us Gear: plastic |
Joined May 2009
yeh i know, i was just wondering what is the best way and maybe you could set it through the gyro or something fancy like that, but i do have a few diodes that would drop it 4.8v around somewere =s. Do you think my current servo is dead though?
United States, CA, Signal Hill
Joined Aug 2009
make sure the rotor shaft screws are tight i just had a simular problem |
your es9257 servo cooked. This servo can only use for 4.8v only.
http://www.servodatabase.com/servo/emax/es9257. suggest to get ubec or voltage regulator to step the voltage |
| Thread Tools | |
| Sold Assan MEMS GA250 gyro | Jonathan Ott | Aircraft - Electric - Helis (FS/W) | 0 | Jan 12, 2012 07:21 AM |
| Sold assan ga250 mems gyro $15 shipped | ohsnap | Aircraft - Electric - Helis (FS/W) | 2 | Oct 27, 2011 09:57 AM |
| Found ga250 gyro | tcb22185 | Aircraft - Electric - Helis (FS/W) | 1 | Sep 21, 2011 06:44 PM |
| Discussion Another newbie video from CRUZROY on the ASSAN GA250 GYRO'S | cruzroy | Mini Helis | 2 | Apr 27, 2011 09:42 PM |
| Question HK GA250 Gyro: Servo settings. | bamm | 3D Electric Heli Flying | 5 | Apr 08, 2011 07:58 PM |
