| Thread Tools |
| This thread is privately moderated by irun4fundotca, who may elect to delete unwanted replies. |
JR Venture CP 30 Adjustments
Heres what they look like now
Heres the end of the hover test and landing
Added DX6i Radio settings pictures
New Flight Battery
Bought a :
Venom 5C 2S 2400mAh 7.4 Receier/Transmitter Flat Pack LiPO Battery Specs: Weight: 3.5 oz (99.2 g) Battery Type: Lithium Polymer (LiPO Battery) Configuration: 2S1P Dimensions: 92 x 30 x 18 mm / 3.62 x 1.18 x 0.71 in Plug Type: Universal Receiver Plug Lithium ELC in Grams: 1.44 Wire Gauge: 22 AWG Capacity: 2400mAh Cell Count: 2 Volts: 7.4 Charge Rate: 0.5C (1.2A) C Rate: 5C Continuous Discharge: 5C (12A) Min Discharge Volts Per Pack: 6V Max Burst Rate: 7C (17A) Max Volts Per Cell: 4.2V Max Volts Per Pack: 8.4V Watt Hours: 17.76 $39.49 After tax OUCH! ...thats local for yah!! |
Alternate Flight Controller For HT-FPV Quad
Ordered a flight controller today and some other parts
HobbyKing Hobbyking KK2.0 Multi-rotor LCD Flight Control Board Nylon XT60 Connectors Male/Female (5 pairs) GENUINE Hobby King Quadcopter Power Distribution Board Buddy Code http://www.hobbyking.com/buddy.asp?c...E-15753334B886 PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC) Buddy Code http://www.hobbyking.com/buddy.asp?c...C-2BFA6E6A0CCC Goodluckbuy.com Balance Charge Extension Cable 20cm 3 cell Mounting Plate Mount 45 Degree Adapter Flight Controller Protector for Multicopter Added photos of 3d printed AR6100e case |
Usefull Links For Builders
Misc Airframe Links for builders - I will Keep adding more links - send me anything You think is usefull too!
An Introduction to the Multicopter World MotoCalc is an Electric Flight Performance Prediction program for Windows and is available for a 30 day free trial. MotoCalc has an internal database of thousands of motors/props/etc. and can make power/flight predictions based on data input. Electric Motor Calculator by Diversity Model Aircraft is a free online tool for matching props to motors to batteries. Propeller Thrust Calculator is a free online calculator to give thrust from given propeller and RPM or vice versa. MultiSurface Aerodynamics is an airfoil and wing analysis software package. The software predicts lift and drag for multiple interacting wings. Electronic Speed Controller Links HobbyKing Atmel Atmega Socket Flashing Tool Silabs ESC`s SiLabs ESC Flashing Update: BLHeli rev8.0 with more features and supported ESCs! sskaug on RCG: The changes are focused towards multirotor performance: - Added a 2 second delay after power up, to wait for receiver initialization - Added a programming option for disabling low voltage limit, and made it default for MULTI - Added programable demag compensation, using the concept of SimonK - Improved robustness against noisy input signal - Refined direct startup - Removed voltage compensation - Miscellaneous other changes And a lot of escs have been added: - RCTimer 6A ESC / RCX 6A - Turnigy AE45 ESC - Turnigy Plush 40/60/80A - Origin/Oversky/HK ESCs - Hobbywing Skywalker 40A sbec Arduino Flashing Using •AVRBurnTool and the Arduino Silprog hexs are at the bottom of this page under “Current firmware and software” which is currently called owSilProg v20120715 as of this posting. Atmel ESC`s SimonK ESC Flashing Spreadsheet For Firmware Files & Corresponding ESC's SimonK .hex flash files can be downloaded here USBasp Drivers Khazama Programming Software Flashable ESC List Battery info Nickel Cadmium (NiCd) Energy/Weight: 40-60 Wh/kg Nominal Cell Voltage: 1.2V Fully Charged Cell Voltage: 1.2V Depleted Cell Voltage: 0.8-1.0V Nickel Metal Hydride (NiMh) Energy/Weight: 30-80 Wh/kg Nominal Cell Voltage: 1.2V Fully Charged Cell Voltage: 1.35-1.4 V (unloaded) Depleted Cell Voltage: 1.0V Lithium-Ion Energy/weight: 160 Wh/kg Nominal Cell Voltage: 3.6 / 3.7 V Fully Charged Cell Voltage: 4.2V Lowest Cell Discharge Voltage Before Damage: 2.4v to 3.0v Lithium-Ion Polymer (LiPo) Energy/weight: 130-200 Wh/kg Nominal Cell Voltage: 3.7V Fully Charged Cell Voltage: 4.23V Lowest Cell Discharge Voltage Before Damage: 3.0V Flight Controllers http://oddcopter.com/flight-controllers/ Naze32 - Adroid GUI Config Tool Apk - Windows GUI Tool(GCS) Atlernate Windows GUI Cirrus AIO KK 2.0 KK 5.5 & LazyZero KKmulticopter Flash Tool Open Areo (KK2.0) Files Naza Ardupilot (legacy) px4fmu Open Pilot CC3D Radio Links Spektrum The Spektrum trainer port only gives either PPM-in or PPM-out, not both at the same time. There's no power supply from the port and channels from the trainer can not be reassigned in a Tx menu. Spektrum DX6i trainer: Inverted 6ch PPM, 3.0V idle, 0V active. 22ms fixed frame-length. 400us peaks. Signal width spans at least 930-1930us. Insert trainer plug when Tx is off to output PPM (trainer). Start the Tx first to input PPM (master). When sending PPM to the Tx, at least 6 channels must be present (6-9 verified to work). Frame length must be shorter than approx. 28ms. 9X Mod Forum Futaba Module Adapter For 9x 9x Solderless Programmer Board with LED Backlight Support This add-on board was designed for the Flysky 2.4Ghz 9-channel radio transmitter model number FS-TH9B, commonly referred to as the "9x". It is also sold under various other re-branded model names and numbers, including (but not limited to): Flysky FS-TH9X, Eurgle 2.4Ghz, iMax 9x, and Turnigy 9x 9X Thread 9XR Module Bay Pinout = top pin 1 is PPM out, pin 3 is VCC and pin 4 is gnd. PPM signal is set to 22.5ms and 300us, 12 channel. Open LRS https://github.com/kh4/openLRSng http://www.rcgroups.com/forums/showthread.php?t=1446653 http://www.rcgroups.com/forums/showthread.php?t=1782034 FPV Links E-OSD From HobbyKing E-OSD Mod Thread My Pics/Post Of Mod E-OSD Good Closeup Pics Of Mod NTSC Files Links PAL Files Link Pan/Tilt & Gimbal Related anonfiles.com/file/e3c5e682b13722771a50a53522537193 hidemyass.com/files/ircCp/ thepiratebay.se/torrent/8339832 Overseas Tracking •China Post Registered Airmail (tracking number starts with "R" and ends with "CN" ,i.e:RR123456789CN) •China Post Express Mail Service (EMS,tracking number starts with "E" and ends with "CN" ,i.e:EA123456789CN) •eBay ePacket (also called EUB (tracking number starts with "LK" and ends with "CN" ,i.e:LK123456789CN) •Hong Kong Post Airmail/EMS (tracking number starts with "R" and ends with "HK" ,i.e RB123456789HK) •Singapore Post Register Mail (tracking number starts with "R" and ends with "SG" ,i.e RB123456789SG) •Russia Tracking (tracking number starts with "RA" and ends with "RU" ,i.e RA123456789RU) Hard Case Links (GCS/Transmitters ect) http://www.cmcgov.com/store/pc/nanuk...&idproduct=397 http://www.hardcases.ca/products/nanuk-920 Scale Lighting Programmable Controller - Delight Starter Kit L.E.D Calc Joystick http://www.nghobbies.com/cart/index....roducts_id=486 APRS TinyTrak3 version 11 Sample station http://aprs.fi/#!call=a%2FVE3UEL-1&t...3600&tail=3600 Morse Code Arduino (encoder/decoder) http://arduino.cc/forum/index.php?topic=8638.0 Prototyping PCB Boards http://imall.iteadstudio.com/open-pc...120418002.html Cheap OSD with GPS http://www.bambucopter.com/suppo-eas...-with-5hz-gps/ LIVE NEWS FEED LIVE VIDEO GAME FEED heres a neat project thread http://blog.jaspervanloenen.com/ |
Hoverthings HT-FPV Naze32 Swap to KK2.0
Finally figured I would give the KK2.0 a try
Everything came today packaged in a box from hobbyking Removed wire harness for esc's Added a Power distribution board Mounted the KK need to do something about the top plate as with the pins on the KK it wont attach ,they should be optional right angles available possibly changing them to right angles if i cant get longer standoffs Update ------> Finally Changed Standoffs
Gopro Live Video Feed FPV Cables
Sample pics
Some technical info: 2.5mm jack for gopro early version: Connector tip: White wire Second from tip: Red wire Third from tip: Yellow wire Fourth from tip: Green wire GoPro HD Hero: Green = Ground Red = Audio Out Yellow = Video Out White = Audio Out GoPro Large Connector Pinouts Pin- Function 1- GND 2- R video out – component Pb/Cb or composite (composite video out activated by grounding ID2 and ID3, component video out activate by grounding ID2). 3- G video out – component Y 4- B video out – component Pr/Cr 5- USB +5V power 6- as above 7- USB Data+ 8- USB Data- 9- GND 10- Audio out Right 11- Audio out Left 12- Pwr/Mode button (tie to ground to activate) 13- Playback mode button (tie to ground to activate) 14- Audio in Right 15- Audio in Left 16- IR input 17- Trig digital output 18- GND (?) 19- ID1 digital input 20- ID2 digital input 21- ID3 digital input 22- ID4 digital input 23- Adapter output – power output for external equipment (follows internal battery power). 24- as above, but only powered when camera is on 25- VBat+ external power input ? 26- as above 27- GND 28- DATA interface I2C 29- CLK interface I2C 30- GND 5.8Ghz Skew Planer "Cloverleaf" Sample Pic 3.6v Water generator http://www.seeedstudio.com/depot/36v...html?cPath=207
| Thread Tools | |
| Question First Person Video | maq007 | Electric Plane Talk | 6 | Mar 10, 2012 09:59 PM |
