This thread is privately moderated by irun4fundotca, who may elect to delete unwanted replies.
Old Oct 10, 2012, 01:10 AM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
FPV Ground Station With Flightsick
Mockup of my FPV Ground Station
7" TFT LCD Display
4 Channel 1.2 Ghz Video Receiver For 1.2Ghz Transmitter @ 1500mw & 600 TV Line Camera (above post)
Short Antenna Patch Cable (male/female) To Antenna Jack (on top)
12v DC 6800mah Pack
12v Power Spliter To RX / Display / UBEC
Logitec Flightstick
Aduino Joystick Interface (In Previous Posts)
Spektrum Mono Trainer Jack
15 Pin Joystick Port (inside or front?)
Internal 5v UBEC To Supply Arduino Power
Internal Video "Y" Splitter To RCA Jack For External Goggles / DVR
Channel 2 Video Input RCA Jack
Tattoo Kit Case
irun4fundotca is online now Find More Posts by irun4fundotca
Old Oct 14, 2012, 12:33 AM
Flying Wood For Fun
Joined Jan 2012
Control Arms...and more control arms!!!!
i was looking through a box today
heres some of my control arms lol
NOT all of them i might add!
Old Oct 15, 2012, 01:49 AM
Flying Wood For Fun
Joined Jan 2012
Video Of The Week - Aircraft Related (Content)
How A Helicopter Is Made
How It's Made: Helicopters (4 min 47 sec)
Heres A Song I Recommend
youtu.be/sGmMCHM82GQ
And another good one
youtu.be/2eopSfWtX7U
and the first song I ever heard of hers
youtu.be/hOpK1Euwu5U
Old Oct 20, 2012, 12:50 PM
Flying Wood For Fun
Joined Jan 2012
APC220 Telemetry Radios
Arrived Friday
I hooked them directly to my ArduIMU and USB on my laptop
and by using HK's ArduIMUTest.exe app i have life
I used the AP to supply the IMU and Radio the 5v needed only
Video of the drift thats happening all the time
the IMU reacts to movement ok though
GOPR0335 (0 min 11 sec)
Tried the imu and gps that I had to rebuild using the radios and got coordinates now
GOPR0336 (0 min 12 sec)
so i think with that said, i need to figure out from here my AP code, So it works using the imu for the em406 gps in binary mode and with the airspeed sensor enabled and using stabilize as my only two switch settings after manual
new video of it all working ...except the airspeed sensor shield..still to test
APC220 Data Working With Ardupilot (Legacy) ArduIMU V2 (Flat) (0 min 0 sec)
I finally got the code to compile myself
I changed the settings for baudrate to 57600 in defines.h (#define ARDU_IMU 57600) for the em406 gps
In AP_Config.h I set gps to type 3 (#define GPS_PROTOCOL 3)
-1 for shield type (#define SHIELD_VERSION -1)
and 0 for no air sensor (#define AIRSPEED_SENSOR 0)
changed the 3rd switch setting from #define POSITION_3 FLY_BY_WIRE_A to stabilize,
the same as the 2nd setting (#define POSITION_2 STABILIZE) now its (#define POSITION_3 STABILIZE)
as i only have on/off on the gear channel.. for now parts coming soon to fix that
Another Video Shot With The Kodak Camera Instead
APC220 Telemetry With Ardupilot (legacy) (1 min 7 sec)
Added APC220 Tutorial here:
http://code.google.com/p/ardupilot/w...elemetryAPC220
Old Oct 23, 2012, 04:12 PM
Flying Wood For Fun
Joined Jan 2012
New Spare Parts
Some Packages From Some Tades Arrived Today
Rasberry pi
GY401 Gyro
2 - EMAX ES08 MD Servos
1 - ALRC DS54MG Servo
KK Multicopter Controller v5.5
Multiplex MULTIcont BL-27/II ESC
Sparkfun 200w Heatgun (not shown)
Additional items for arduino based projects arrived too
(List Updated In Arduino Project Post)
Also some spares listed on first page of my blog
Lemmon RX Specs
- TX port (UART, 9600bps, 8N1)
Condition 1) UART output specification when no signal received (device reset and continuously monitor for valid signal every 0.5 sec):
- <0x13><'R'><'E'><'S'><'E'><'T'><0x13>
- <0x13> is used as header for beginning and ending identifier
Condition 2) UART output specification when signal is received ( updated ~40ms with 8 bytes of information):
- <0x13><Aileron><AUX><Gear> Elevator><Throttle><Rudder><0x13>
- DEC(66) ~ DEC(134) refer to the approximate value for each of the full range control output for the 6 channels.
For example: if all channels are centered except throttle shutdown and AUX is maximized, the UART should output the following.
<0x13><DEC(100)> <DEC(134)> <DEC(100)> <DEC(100)> <DEC(66)> <DEC(100)><0x13>
- PPM port
Condition 1) PPM pulled to ground (logic level low).
Condition 2) If signal is valid, 6 high pulses are used to represent Aileron, AUX, Gear, Elevator, Throttle and Rudder while each signal is separated by ~60us low pulse. ~40ms low pulse followed and continues the updates from receiver.
_________----_----_----_----_----_----___________________----_----_----_----_----_----_______________________
- Vreg port
On board Vreg output is available as reference voltage for logical high signal. Do not exceed drawing over 10mA of current.
- NA port
Do not connect anything to this pin. NA pin is a direct connection to reset the microprocessor. The microprocessor has already pre-programmed a watchdog timer which will ensure the reliability of the unit's long term operation by auto reset in case of any system failure / temporary power failure and resume operation in 0.5 sec.
- GND port
System ground.
PPM Encoder DIY
http://paparazzi.enac.fr/wiki/ATmega_PPM_Encoder_Board
Old Nov 04, 2012, 09:13 PM
Flying Wood For Fun
Joined Jan 2012
DX6i - Ardupilot Mode Switch Mod
heres the mode switch i wanted to install on my gear channel on my DX6i, However the DX6i doesnt support the variable rate
swapping out the gear switch with a 3 position rotary dial switch
and swapping out my trainer switch with the old gear switch to allow always on for trainer for use of the flightstick using the arduiino interface
product links if needed,just pm me i can send you them
heres a 3 way on/on/on you could substitute the rotary with
http://www.digikey.com/product-detai...855-ND/1006933
Cheap PCB Board Manufacturing
Old Nov 12, 2012, 03:25 AM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Always been interested in FPV, I'll be back to read up when I have a little more time.
djdavies83 is offline Find More Posts by djdavies83
Old Dec 01, 2012, 01:08 AM
Flying Wood For Fun
Joined Jan 2012
Spares
4 1/2 base 12 3/4 wide alum gear
ultralite wheels 1 3/4 (45mm)
Some pics of my mothers mini cart we made for her recently
Still needs some things done ,pinstripes, floor and front panel
Installing lights for underglow
and rear markers
Mini Cart Underglow - 5050 SMD RGB Led Strip Test (0 min 47 sec)
Old Dec 07, 2012, 08:46 PM
Flying Wood For Fun
Joined Jan 2012
Energy Links
Fumafia Energy Link List (attachment)
HTML link validator
http://www.filebuzz.com/fileinfo/432...Validator.html
30 Day evaluation Download Link
http://www.filebuzz.com/publisher/download.php?id=4328
You can use any link validator for website building that allows manual bulk
lists of links to be entered into the program to be scanned
do a google search for "html link validator"
enjoy and have fun!
----irun4fun-------------
Old Dec 15, 2012, 10:36 PM
Flying Wood For Fun
Joined Jan 2012
Interesting Things to research
heres a list of things to look into
OpenAero2 open-source stabilisation software for KK2 boards
Afroflight Naze32 Setup Guide For Dummies, like myself
Quadcopter Megga Index
AfroPilot
Weedeater & Trimmer Conversion Kits
Old Jan 01, 2013, 11:55 PM
Flying Wood For Fun
Joined Jan 2012
My New (used) Hoverthings HT-FPV Quad
Arrived the other day been tinkering so far
messing with the software to get it running
as java dont work on this lappy my other one did though
heres what it looks like after i changed the front lights to white, added gopro (for picture)
mock up of transmitter for FPV camera with Inverted V ant
thinking of using my apc220 telemetry modules and looking into gps working with the naze32 flightcontroller
seems to be working right ,need to adjust pids for stable flight now
- Hoverthings HT-FPV frame (black - see specs on frame below)
- Naze32 - Afroflight (latest) Update ----> Swap to KK2.0
- Turnigy 1600Mah 3cell (for testing,setup)
- Turnigy 30A Plush
- EMP N3536 910KV
- 10X4.5 Props (testing others 9x4.5)
- LED lights (red, green, white)
- Gopro Hero
- spektrum AR6100E
Im still considering adding one or more of the following:
- APC220 Telemetry
- EM406A GPS
- 1.2ghz 1500mw VTX
- 1.2ghz Inverted V Ant
- 600 TVL Board Camera
Spin Up Test
HT FPV Spin Up test With L.E.D.s (0 min 16 sec)
thread im following here also
http://www.rcgroups.com/forums/showp...postcount=1820
Added multiwii v2.1 gui settings/readings screenshots
FRAME SPECS
Weight: 350g
Size: 435mm width x 306mm length x 65mm height (Width x Length is motor shaft to motor shaft)
Overall size: 20" (510mm) width x 14" (360mm) length x 2.9" (75mm) height (maximum size assembled with motors for storage, props removed)
Material: G10 Fiberglass
Hardware: Aluminum and Stainless Steel, 4-40 thread (not metric).
Recommended Prop Size: 8x4.7, 9x4.7
Maximum Prop Size: 10x4.5
Recommended Motor Size: 28mm 950-1200Kv for 3S (12V) or 28mm 720-750KV for 4S (16V), motor plates will accept most 38mm motors. Hole spacing from 15mm - 19mm. NTM Prop Drive Series 28-26A 1200kv is a good choice for 3S
Recommended Battery: 3S/4S 2200mah - 2800mah 20C - 25C
Recommended Flight Controller: Naza, OpenPilot, Quadrino. We recommend auto level and altitude hold for ease of flying FPV.
Recommended Camera: GoPro Hero (Frame is designed and balanced for GoPro but other cameras can be made to work).
http://www.ecalc.ch/xcoptercalc.htm
UPDATE- For archive reasons and the google links no longer work for the windows client added the AIO distros in zip
Last edited by irun4fundotca; May 12, 2014 at 09:14 AM. Reason: Added Pics After Finishing Touches On Wiring/Cosmetics
Old Jan 02, 2013, 04:20 PM
Flying Wood For Fun
Joined Jan 2012
Bought a JR Venture CP 30 helicopter yesterday (JRP9005)
& partial trade for my Futaba GY401 Gyro
Came today
kinda interested in flying one bigger than a micro
It's together ,need to adjust everything now and set it up right to my DX6i
Came With Spare NIP Parts :
- Main Blades (RVO0550P)
- Tail Boom (JRP983001)
- Horizontal Fin (JRP996064)
- 3D Flybar Paddles (JRP996056)
- 3D FlyBar (JRP996057)
- Main Blade Holder Set (JRP960867)
- Clutch Lining (JRP970321)
- Tail Output Shaft (JRP970027)
- Blade Spindle Shaft (JRP960068)
- Main Rotor Shaft (JRP960009)
- Used Landing Skids (JRP960034)
Take Off Video - (gopro died)
JR Venture CP 30 - Take off (0 min 30 sec)
Last edited by irun4fundotca; Mar 25, 2013 at 09:33 PM. Reason: Added Take Off Video
Old Jan 07, 2013, 06:52 AM
Flying Wood For Fun
Joined Jan 2012
cool fpv vids
FPV Fun
FPV - drift (3 min 55 sec)
Old Jan 09, 2013, 09:48 PM
Flying Wood For Fun
Joined Jan 2012
Heres some videos about the KK2.0 (LCD)
Setup
youtu.be/lRbAqH-zjVs
Flashing
youtu.be/pNb3u8yIIV4
Quick Tuning Guide
youtu.be/U7pWroCxL38
Tricopter
youtube.com/e6K4NXoq-Qk
Question First Person Video maq007 Electric Plane Talk 6 Mar 10, 2012 09:59 PM
