This thread is privately moderated by irun4fundotca, who may elect to delete unwanted replies.
Old Aug 08, 2012, 08:53 AM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
Progress so far
- Servo Hatch Door trim to stop the door from falling in
- reinforcement to door panels
- inside rear servo mounts
- added updated build photos
irun4fundotca is online now Find More Posts by irun4fundotca
Old Aug 12, 2012, 10:08 AM
Chuckf2000 is offline
Find More Posts by Chuckf2000
Chuckf2000's Avatar
Joined May 2012
Originally Posted by irun4fundotca View Post
started the skybaby yesterday
working out a few things not on paper or in any pics ive found yet
heres the wrap up so far for pics to date of the build
Great build pictures, thanks for posting them.
Can you expand on the 'working out a few things not on paper?' This would be my first build and I just started the hobby a couple mos ago.
Chuck
Chuckf2000 is offline Find More Posts by Chuckf2000
Old Aug 21, 2012, 09:07 PM
Flying Wood For Fun
Joined Jan 2012
explanation
Chuck
most of the things i had to work out were the mounting of the hatches and the landing gear mod i choose to use
added support for the tail section to redistribute impact toward the front on hard tail landings and prevent bends
and my rear tail wheel mod
heres some update pics too
Old Aug 24, 2012, 09:23 PM
Flying Wood For Fun
Joined Jan 2012
Spare Brushless motors for future builds
got thses on rcg over the past few months
and the blue one is from my f117 edf unit
the red one i tested clamped to a chair and had to catch it from pulling the chair over onto the floor at half throttle
using a 3s 5000mah turnigy
the gold one moved it but not over at full throttle
Old Aug 31, 2012, 07:58 PM
Flying Wood For Fun
Joined Jan 2012
New plane
Got a new plane today, well actually almost two
55.2" Airfieild Trainer 400 or FMS Cessna 400 Same as this one
with a new wing in the bag & the main fuse is new also
(Sold the extra fuse and wing, since post)
got it all set up just waitin for the right weather outside to try it
Added Temporary FPV Equip
Contemplating on adding some scale lights using the DElight starter kit
something like this video
Cessna 400 Corvalis (1 min 3 sec)
Old Sep 02, 2012, 03:32 PM
Flying Wood For Fun
Joined Jan 2012
Flap & Gear Mods
Did the flap mod
and replaced the pastic gear arm covers with wooden ones epoxied on
Old Sep 05, 2012, 04:24 PM
Flying Wood For Fun
Joined Jan 2012
Eflite Blade MCX RTF with Extras
got in the extra set of parts for the blade mcx today
didnt use the swash or frame as i dont wanna fix something thats not broke
so until that happens will leave it this way for now
still need main shaft ,as where the red is on it, one side is fixed with CA glue
flys normal tho and i need some O-rings for the canopy
(i made some from small wire insulation after i pulled the wire out)
Short Flight Vid (one handed):
Eflight Blade MCX (0 min 15 sec)
Old Sep 06, 2012, 12:48 AM
Flying Wood For Fun
Joined Jan 2012
Update on the Sky Trainer 400
Was sitting here sorting my tool box tonight and found a gold paint marker(for touchups)
anyway heres my result to match my color scheme
Im going to buy a can of spray now and do it right seeing it matches well
added Exaust tubes from aluminum tubes
Old Sep 10, 2012, 06:01 PM
Flying Wood For Fun
Joined Jan 2012
Arduino Research
i started buying up Arduino parts to build some projects
unknown yet where i will end up so i bought things to give me options
first off is the flightsick to radio project
then on to the ardupilot project
ordered so far
  1. 65x wires $2.42 *
  2. ethernet shield w5100 $10.16 *
  3. sma to sma $2.37 *
  4. SD card module reader $1.87 *
  5. sensor shield v5 $5.60 *
  6. usb to rs232 $1.87 *
  7. Arduino Uno $16.99 *
  8. protoshield $4.69 *
  9. LCD Shield $7.09 *
  10. Sensor Shield $6.88 *
  11. USB AVR Programmer $3.56 *
  12. IR Reciever / Remote $6.89 *
  13. 3D Printed Arduino Case $8.99 *
  14. Adjustable Power Supply Module $1.69 *
  15. RS232 DB15 Female $1.81 *
  16. 50 x Resistors 10K $0.97 *
  17. 50 x Resistors 100K $0.97 *
  18. 1 Meter 50mm Heat Shink Tubing $1.99 *
  19. 4 x Mini Toggle Switch SPDT $2.92 *
  20. 2 x 40 Pin Right Angle Header $0.97 *
  21. 2 Ch Relay Module $2.55 *
  22. SR04 Ultrasonic Module $2.02 *
  23. 40 x Female / Female wires $2.94 *
  24. SMA male to RP SMA female $0.98 *
  25. 2 x 3 Position Rotary Switch $5.09 *
  26. 2 x Black Knob with Orange $0.99 *
  27. 5 x Variable Resistor $0.99 *
  28. 10 x PCB Boards $1.98 *
  29. 5 x 3x40 Pin Right Angle Male Header Strips $5.32 *
  30. DC 4-40V to 1.25-37V Step-Down w/LED Voltmeter $9.27+2.95ship*
  31. 10 Pin Converter to Standard 6 Pin (AVRISP/KK) $2.12 *
  32. Solder Sucker $2.98
  33. Magnifying Glasses $3.95
  34. Mini Bluetooth USB 2.0 Dongle $1.16
  35. Heat shrink Package 6' each 1/8 up to 3/8 $9.21
( * = Arrived Items)
I also picked up a ardupilot on here im going to figure out and get working with the joystick mod for manned flight mode
I plan to swap out my trainer switch so it stays on when needed for the Flightstick Mod
Home Automation
http://freedomotic.com/content/freedomotic-developers
http://code.google.com/p/freedomotic/
Arduino Books Torrent Magnet Link
http://kat.ph/arduino-books-collecti...-t6546192.html
Torrent Contents:
Arduino and Kinect Projects.pdf
Arduino Bots and Gadgets.pdf
Arduino Cookbook.epub
Arduino Internals.pdf
Arduino projects to save the world.pdf
Arduino Robotics.epub
Beginning Android ADK with Arduino.pdf
Beginning Arduino Programming.pdf
Environmental Monitoring with Arduino.pdf
iOS Sensor Apps with Arduino.epub
Practical Arduino Cool Projects for Open Source Hardware.pdf
Practical Arduino Engineering.epub
Programming Home with Arduino and Android.pdf
Servo Magazine Collection Torrent (2003 - 2012 Various)
http://kat.ph/servo-magazine-collect...-t6888101.html
Magnet Link
Good Supplier Of Electronic Components
http://myworld.ebay.ca/grand_sky/
Old Sep 12, 2012, 10:57 PM
Flying Wood For Fun
Joined Jan 2012
Arbiter v3.5 Elite 360 Controller Mods
Not exactly RC related but electronic hobby related ...so.. meh
i got the kits in today
Heres the package contents
i added a solder point image showing front and back
Old Sep 13, 2012, 09:56 PM
Flying Wood For Fun
Joined Jan 2012
Closeups - Airfield Trainer Setup
Heres some Closeups of my Airfield Sky Trainer Setup
keep in mind the flaps can be mixed and ailerons could be reversed and linked together on a Y cable instead
Old Sep 22, 2012, 01:45 AM
Flying Wood For Fun
Joined Jan 2012
Ardupilot Links & Build Post
The Ardupilot Arrived today
Contents :
* Ardupilot (Legacy)
http://diydrones.ning.com/profiles/b...ilot-main-page
* ARDUIMU+ V2 (FLAT)
http://store.diydrones.com/ArduIMU_V...arduimu-20.htm
* Legacy (original) ArduPilot Shield V2 Kit
http://store.diydrones.com/ProductDe...ode=KT-0001-01
* EM406A GPS
https://www.sparkfun.com/products/465?
* UBLOX GS407 GPS
http://store.diydrones.com/GS407_U_B...-gps-gs407.htm
rewired a board wire that goes to throttle was on the wrong pin
made a patch to supply imu shield/gps
loaded ardupilot 2.7 code
have my radio now controlling throttle ,servos, and enabling auto/man using my gear channel
Ardupilot Project
http://code.google.com/p/ardupilot/
Ardupilot Manual
http://code.google.com/p/ardupilot/wiki/ArduPilot
Ardupilot & IMU useage
http://code.google.com/p/ardupilot/wiki/ArduIMU
Ardupilot Firmware
Arduino IDE Loader
http://arduino.cc/en/Main/Software
Hex Loader
http://xloader.russemotto.com/
Compass offset
http://www.ngdc.noaa.gov/geomagmodel...5CD887273738E1
imu code
http://code.google.com/p/ardu-imu/downloads/list
imu wiki
http://code.google.com/p/ardu-imu/wiki/Code
Labview runtime
http://ftp.ni.com/support/softlib/la...lvrte86min.exe
heres what it looks like so far below
I wrote instructions for adding apc220 telemetry to the legacy manual
http://code.google.com/p/ardupilot/wiki/TelemetryAPC220
Arduino Project On Post 50
http://www.rcgroups.com/forums/showp...7&postcount=50
Last edited by irun4fundotca; Mar 21, 2013 at 02:08 PM. Reason: Pic Update Wired Up Testing
Old Sep 25, 2012, 01:42 PM
Flying Wood For Fun
Joined Jan 2012
Flightstick To Radio For FPV Flight
Logitec Wingman I'm trying to connect for fpv using an arduino uno interface directly to my radio's ppm trainer port
- Serial port interface (15pin Dsub)
Heres some info for the Mod/Build
Thread here:
http://www.rcgroups.com/forums/showthread.php?t=1515226
And One Mentioned on above page:
http://www.built-to-spec.com/blog/20...h-the-arduino/
Added modeswitch to change flight modes
might use a Orange rx TX module and bypass the radio all together in the gcs
Added test Board Layout for shield
Protoshield Used
http://www.adafruit.com/products/51#Downloads
Posted a help Inquiry Here for arduino programming
https://sourceforge.net/p/forge/help...?limit=25#a674
Video of last tests before I was sidetracked
arduino flightstick (0 min 10 sec)
Old Oct 02, 2012, 12:33 AM
Flying Wood For Fun
Joined Jan 2012
The BluCube Camera
recently i purchased a 600 tv lines board camera
i pondered how i was going to mount it and protect it
and came up with this
v1 two peices of blue dow styrofoam
  • Front cutout to fit front camera
  • Back cutout to fit all plugs and wire lead
  • Taped the sides after sandwitching it all together
  • Heatshrunk It
  • Applied velcro for mounting
added front layer to add areodynamics and countersink camera lens more
and heatshrunk it all in 50mm heatshrink
Video Link of it mounted on pan tilt
Pan/Tilt using Blucube Cam (0 min 9 sec)
(((((Date on camera is off and im sick of setting it so its gonna stay that way lol)))))
Brushless Gimbal Motor Links
Added a new lens...
Old Oct 03, 2012, 06:51 AM
BriGuy82 is offline
Find More Posts by BriGuy82
SemperFi!
BriGuy82's Avatar
United States, TX, Texarkana
Joined May 2012
That's great! My idea wasn't nearly so protective. I was thinking just adding to the back. I actually have some foam here at work that might just make the exact shape.
BriGuy82 is offline Find More Posts by BriGuy82
Question First Person Video maq007 Electric Plane Talk 6 Mar 10, 2012 09:59 PM
