This thread is privately moderated by irun4fundotca, who may elect to delete unwanted replies.
Old Apr 26, 2012, 07:20 PM
irun4fundotca is online now
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
Got a friend into airplanes recently
Sold him my extra stuff
Futaba T6EXAP PCM 6-channel transmitter
with a Futaba FP-R138DP FM receiver
Futaba FP-T6NLK FM 6Ch (No Receiver/Battery)
35" Wingspan Flyzone Cessna 182 Skylane
With stock 380 Electric Motor (Now swapped to a brushless 450)
Tactic TTX400 4Ch 72mhz FM On CH42 RX, Tactic 6Ch RX
3 x 7Cell 8.4v 1100mah ElectriFly Batteries & Chargers
irun4fundotca is online now Find More Posts by irun4fundotca
Old May 01, 2012, 07:05 PM
Flying Wood For Fun
Joined Jan 2012
1.2ghz @1500mw or 1.5w VTX & TRX
video test of my longer range transmitter
1.2ghz @1500mw or 1.5w 4Ch VTX & TRX
1.2ghz 1.5watt fpv test.mp4 (1 min 17 sec)
Ordered Battery packs for plane (tx/cam) & ground station (rx/lcd)
Completed System
Old May 03, 2012, 02:24 AM
Flying Wood For Fun
Joined Jan 2012
DX6i Backlight Custom Mod
I modded my DX6i with the turingy 9x backlight mod today
i added a twist though using a micro toggle switch on the back to save battery
while using the radio with my flight sim's as it eats battery life when not needed
heres some pics of the mod ,once i started, i kept forgetting to take pics through all the stages
i ordered a second white kit as i bypassed my resistor when i modded it, i did'nt see it on the plug board when i removed it and my light is way to dim to see in any light ..be great for night flights lol
replaced with white board looks awesome
i used my second hk wiring that came with the backlight without modding it i used the first removed red wires to rearange the red and black needed joined onto my switch lead and it plugs into the new wire harness so replacement is easy now
i used the bandsaw to cut off the excess length of the display removing the silver tape from the edges and replaced it after it was cut shorter so it reflects all the way around it like the original one i used tape around the edges to join the back light to the display so they stay together
once it was installed i used the tip of a screwdriver between the boards to center it in the front window moving it slowly untill centred
Old May 17, 2012, 11:35 PM
Flying Wood For Fun
Joined Jan 2012
Got a new plane its a Hangar 9 Solo Sport Trainer with an O.S MAX AX .46 Glow
the engine has only one tank ran through it since new
the wing covering had a rip in it and the alerions needed the control rods
and now i just need the front steering linkage but i need to get one to do it
besides that its ready to go now
Old May 19, 2012, 01:48 AM
Flying Wood For Fun
Joined Jan 2012
Ran the second tank through the .46AX today
installed all missing parts to complete the solo sport
Undid the stab section replaced elevator hinges with pinned hinges
Reattached it all much more solid than the person who tried to assemlbe it from new
Did another recheck of the throws and limits of the servos
Need to pick up wing elastics, As I forgot to buy some at the hobby shop today
one just wont do!
Old May 19, 2012, 08:06 PM
Flying Wood For Fun
Joined Jan 2012
Lost The Hangar 9 Solo Sport Trainer in some trees across the road
looked for hours and cant find it
, the elastic broke and the wing xame off the fuse droped like a bomb and the wing fluttered down
3 of us looked and looked with no results
Update....Found the plane and recovered the parts everything works fine
never found the wing yet tho
Planning to use the parts for my skybaby build coming up soon
Old Jun 01, 2012, 12:19 AM
Flying Wood For Fun
Joined Jan 2012
Today i tested out my brushless .50 glow equiv motor
using a 10x6 master airscrew i clamped it to a chair back with a clamp and at half throttle
it pulled the chair over, i almost missed catching it lol
and thats with a turingy 11.1v 3s 5000mah 20c-30c burst pack
i think it will provide the thrust i need to get my 60" off the ground
woot
Old Jun 20, 2012, 12:32 PM
Flying Wood For Fun
Joined Jan 2012
70mm EDF Project
- 5mm Dollarama Foam
- 16mm Lowes (DOW) Blue Foam
- A flat carbon fiber spar vertical across the wingspan just in front of the edf unit
- For the Glue i choose Lepage PL Premium Ultra (100% Polyurethane)
the adhisive works like spray foam and turns into white foam itself and goes on like a jelly or clear paste you have about 10 minutes to work with it before it starts to really turn into foam
I built this around the edf unit itself
there wernt any plans i could research online involving an edf unit that i liked
as i wanted a slower flyer than a jet
I was considering on a BiPlane EDF maybe next lol
Because of weight limits i chose not to cover the cockpit area for now,
but figured i would surround the battery to prevent slides
the rear i reduced a half inch to give a little more thrust and went with the diamond pattern as a test
Old Jun 22, 2012, 04:08 PM
Flying Wood For Fun
Joined Jan 2012
Non R/C Steampunk Projects
Just being creative away from the r/c field
Thought I Would share in some ideas
Open to any and all comments you may have
And in no way am i making fun of or mocking any person with a disabillity
I have faitfully done thousands of hours volunteer work with several non profit organizations
that deal with persons with handicaps or disabled persons
Added photos of the final finished version
i think i will call it the Steampunk - "Retard Detection Device" Plaque
Added Steampunk - 25mm Plasma Rifle
Article Published on Steampunk Canada
Old Jun 28, 2012, 06:20 PM
Flying Wood For Fun
Joined Jan 2012
Added two boats to the arsenel today
- an unknown one all balsa
- traxxas nitro vee
.15 electric start with a backup electric motor
needs work but cool
since first post i restored most to working condition
- Repaired crack in rear hull
- Repaired water pickup = added alluminum top
- redone wiring for RTS motor & battery
- replaced servo & missing throttle linkage
- replaced blown glow plug
- replaced gas tank (as seen in pics there was a bad leak in the corner of the tank)
- replaced wireharness
- bought ez-start and battery pack/charger
Old Jul 09, 2012, 08:46 PM
Flying Wood For Fun
Joined Jan 2012
Sold my 45" Wingspan SIG T-38 Kobra running a Merco .30 Glow to my friend to get him in the air
development board and chip
http://www.microchip.com/samples/default.aspx
http://modtronicsaustralia.com/shop/...ent-board-pcb/
PIC24FJ64GB004
LED control
http://diydrones.com/profiles/blogs/321-blink
Mavpilot app
http://www.communistech.com/blog/mav...and-beta-test/
Old Aug 02, 2012, 01:29 PM
Flying Wood For Fun
Joined Jan 2012
Skybaby Kits Almost Ready to start building
bought the additional wood thats needed
and Purple and Orange Monokote to cover it in a style like my Hurricane
Yet to get a powerplant!
Old Aug 07, 2012, 09:52 PM
Flying Wood For Fun
Joined Jan 2012
Bought a mcx last week, kinda neat , not much good outdoors
I actually flew it outside today (Aug 26th 2012)
the breeze moved it slowly off track a bit but was mild
goes quite high too!
added more pics from the original ad I purchased it from
and two new ones,As now in the box
Traded for a paintball setup
...Don't really have a use for it, But it's worth more than the
$70 I had into the MCX..I think!
Last edited by irun4fundotca; Jan 18, 2013 at 01:24 PM. Reason: Traded for painball setup
Old Aug 07, 2012, 10:16 PM
Flying Wood For Fun
Joined Jan 2012
Skybaby Kit Started
started the skybaby yesterday
working out a few things not on paper or in any pics ive found yet
heres the wrap up so far for pics to date of the build
Plastics
http://parkflyerplastics.com/cart/in...eyword=skybaby
Balsa Laser Cutters
http://store.laser-design-services.com/
Old Aug 08, 2012, 08:12 AM
N827TM is offline
Find More Posts by N827TM
Mansell Models
N827TM's Avatar
United States, UT, Layton
Joined May 2004
Nice pics of your guys build progression! Keep the great work up!
Tom
N827TM is offline Find More Posts by N827TM
Question First Person Video maq007 Electric Plane Talk 6 Mar 10, 2012 09:59 PM
