Old Jan 16, 2012, 11:28 PM
ferrocium is offline
Find More Posts by ferrocium
Hooked on FPV
Joined Jan 2012
2 Blade VS 3 Blade Prop for Multirotors?
I was just curious of what people prefer; 2 blade or 3 blade props for a multirotor?
I've heard arguments that go both ways. Airplane owners obviously will use a 2 blade prop because it is more efficient at wind speed. But what about use for quadrotors or other slower moving craft?
From what I can see the pros outweigh the cons:
3 Blade Pros:
  • I have heard that 3 blades cause less vibration and give more stability for fpv or aerial photography.
  • They say that 3 blade rotors are less affected by the wind.
  • Blade tips have better tracking with 3 blades
  • Equivalent 3 blade props are easier to bring up to speed quickly from a stop
  • I've heard that a 3 blade prop may actually be more efficient than 2 at low air speed because the motor doesn't turn as fast. (I don't really believe that though)
2 Blade Pros:
  • Faster speeds
  • More efficient?
What do you guys think?
ferrocium is offline Find More Posts by ferrocium
Old Jan 17, 2012, 12:16 AM
soulreaper is offline
Find More Posts by soulreaper
Joined Nov 2005
I already asked this question......I did not get to many responses. Most people that use 3 blade props only use them when clearance is an issue. When it comes to helicopters 3 blades or more provide more lift than 2 blades, thats why you see heavy lift helicopters using 3 or more blades. Three blades will hover at a lower rpm. Other than that, this question only starts arguments. I have read a few threads and there are always different opinions. I use 3 blade props on my x525 and Im happy with them and dont plan on going to 2 blade props at all.
soulreaper is offline Find More Posts by soulreaper
Old Jan 17, 2012, 12:24 AM
simonjardine is offline
Find More Posts by simonjardine
MultiRotor Jedi
simonjardine's Avatar
Australia
Joined Apr 2008
Two blades are better than three.
No arguments, they just are :-)
end of thread
Simon
(look at Microdrone, Dragonflyer etc..etc..)
They would use 3 blades if they were better!
simonjardine is offline Find More Posts by simonjardine
Erknie is offline
Find More Posts by Erknie
Australia, QLD, Brisbane
Joined Nov 2011
That's because the question has been asked many times. Search is your friend:
http://www.rcgroups.com/forums/showthread.php?t=1225763
http://www.rcgroups.com/forums/showthread.php?t=1113189
http://www.rcgroups.com/forums/showthread.php?t=1107558
http://www.rcgroups.com/forums/showthread.php?t=189013
Erknie is offline Find More Posts by Erknie
Old Jan 17, 2012, 01:26 AM
Hooked on FPV
Joined Jan 2012
Thank you guys for the replies, it looks like I have some reading to do, I didn't realize it was such a hot topic
Soulreaper: I noticed that you have an x525. That is what I'm planning on getting from goodluckbuy. I snooped a little to see what kind of setup you have and it looks very nice Is that the kit from http://www.goodluckbuy.com/x525-v3-q...lticopter.html
If not then do you think that kit has pretty much the same motors as yours?
Also, I see that you have a KK board. How do you like that board so far? Do you think it will be a good stable one for FPV? I have been looking at this one and the Crius Multiwii and can't decide which one I want as the Multiwii is pretty expensive. Hope you don't mind me picking your brain.
Old Jan 17, 2012, 01:30 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Personally, I like using 3-bladed GWS 9x5x3 props in place of the 10x4.5 2-bladed variety that comes with most XA and DJI kits. It takes more time to balance them, but the results are pretty dramatic. In addition to being vibration-free, they are also a ton quieter. I have no idea whether the efficiency is better or worse, and frankly, I really don't care. To me, it's all about vibration isolation.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Jan 17, 2012, 02:44 AM
scousethief is online now
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
The efficiency of a 3 blade is less than a 2 which is less than a 1 from all accounts they also consume more amps but give a little more thrust. Personally i quite like 3 bladed props but they can be a pain to balance so i have been using the 2 bladed variety.
scousethief is online now Find More Posts by scousethief
Old Jan 17, 2012, 03:06 AM
Erknie is offline
Joined Nov 2011
If you remove material from the heaviest of the 3 blades, it's easier then trying to add tape to the lightest blade like you might have done on a 2 blade.
Old Jan 17, 2012, 07:48 AM
Joined Nov 2005
I purchased my kit from ebay, for $154.00 dollars shipped. Yes the kit from GLB is the same. I like the kk board. I have not changed the firmware. I already have all my FPV equipment, and I will have all of it mounted soon. Im going to fly FPV with the stock kk board, and see how it does. If I decide to get another board I will get a ff free flight board, it has auto leveling and its plug and play.
Old Jan 17, 2012, 08:06 AM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
My experimenting with two verse 3 bladed props, they required difference PID settings. This is where the oscillation comes from. The Three bladed requires less gain because they have more mass creating more gyroscopic forces.
rimshotcopter is online now Find More Posts by rimshotcopter
Old Jan 17, 2012, 08:16 AM
jforkner is offline
Find More Posts by jforkner
jforkner's Avatar
Copperopolis, CA
Joined Sep 2003
-- Gary
Gary,
Would you mind describing your balancing tools & technique?
Thanks.
Jack
jforkner is offline Find More Posts by jforkner
Old Jan 17, 2012, 08:17 AM
TheX is offline
Find More Posts by TheX
Old new guy
TheX's Avatar
United States, TX, Austin
Joined Sep 2004
I use 3 blade on micro's because finding proper pairs of 2 blade 5x3 props means waiting forever for them to get here from Hobbyking, unless someone has a US source.
TheX is offline Find More Posts by TheX
Old Jan 17, 2012, 11:03 AM
Jakub J is offline
Find More Posts by Jakub J
Jakub J's Avatar
Krakow/POLAND
Joined Dec 2009
3 Blade Pros:
2 Blade Pros:
  • Faster speeds
  • More efficient?
You are right.
My choice is 3-blade - much lower vibrations, only slightly shorter flying time. One cons - 2-blade are much more friendly in transport.
Jakub
Jakub J is offline Find More Posts by Jakub J
Site Sponsor
Old Jan 17, 2012, 12:06 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Originally Posted by jforkner View Post
Gary,
Thanks.
Jack
First of all, you need one of those magnetic balancers. I think mine is a TowerPro. Basically it is just a frame that holds a magnet on each arm. A steel shaft goes between the magnets, and has rubber slide on pieces to hold the prop in place. I then just use two different grain pieces of sandpaper, one coarse and one fine.
You start by letting it rotate on its own, and one blade will end up pointing down. You sand this one with the coarse/fine sandpaper until it doesn't point down anymore, and you get one blade to point up. Rotate to the next blade, to try and get it to point up. Whichever way it falls, that blade you sand next, until that 2nd blade will point up. Rotate it to the next blade and repeat.
-- Gary
Old Jan 17, 2012, 12:32 PM
Hooked on FPV
Joined Jan 2012
Well that settles it... I'll just have to get both
Question How do I determine 3-blade prop replacement for 2-blade? the_law_man01 Power Systems 1 Sep 06, 2011 01:49 AM
3 or 4-blade prop vs. 2-blade prop R Hudson Power Systems 11 Aug 11, 2006 09:10 AM
Discussion 2 blade vs 3 blade prop? donjiskra Power Systems 3 Jun 10, 2006 12:47 AM
3 Blade vs 2 Blade Prop Robert Hoffman Sport Planes 3 Aug 23, 2002 02:58 PM
