Old Oct 06, 2012, 01:14 PM
wwd is offline
wwd
Find More Posts by wwd
wwd
La Mesa, California
Joined Jan 2010
Hello Again,
this is the exact message I get, hope this may help. This comes the the Map Maker program when I press get map
Map Maker
runtime error
/_2147024156(800702e4)';
Don't know if this information helps but this is the message I get.
Thank You for Your time,
Wwd
wwd is offline Find More Posts by wwd
Old Oct 06, 2012, 01:27 PM
wwd is offline
wwd
wwd
La Mesa, California
Joined Jan 2010
Hello,
the error numbers seems to be some sort of control for user accounts. Am working on it now. Hopefully I can figure this out and post a positive result.
Thanks for Your time,
Wwd
Old Oct 06, 2012, 01:31 PM
wwd is offline
wwd
wwd
La Mesa, California
Joined Jan 2010
Hello Again,
ok, it is run as administrator error. I had read that about the other programs but did not equate it to this one. Anyway all seems well. Sorry for my slow learning progress and again,Thank You for Your time,
Wwd
Old Oct 06, 2012, 04:32 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
no problem... all FY programs need to be "run as administrator"
Glad you have it sorted!!!
Let me know how it works for you and if my video made sense.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Oct 06, 2012, 11:13 PM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
Originally Posted by saabguyspg View Post
These are from the panda which should be the same...
PID parameter tab
Attitude control 50
attitude integer 5
Hdg dampening 50
wording may vary becuase I am too lazy to type in chinglish
Steve
No, unfortunately they are not the same. Anyway, thanks for the reply, hope to get the FY31AP settings.
Pattaya01 is offline Find More Posts by Pattaya01
Old Oct 07, 2012, 12:13 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
ummmm I am pretty sure they are
I have both and those are the ones I always revert to when I want to start over..
what ones are you most concerned with?
Old Oct 07, 2012, 12:22 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
here is a link to a manual where it shows all the defaults in the photos... they are almost exactly the same..
hope this helps
http://www.sierra.ro/upload/Image/FP...GCS_Manual.pdf
Steve
Old Oct 07, 2012, 01:07 AM
Sitas is offline
Find More Posts by Sitas
Joined Jul 2011
In the Fy31ap manual side offest damp 60, in the panda manual side offest damp 5. Why?
Sitas is offline Find More Posts by Sitas
Old Oct 07, 2012, 05:25 AM
Thidsa is offline
Find More Posts by Thidsa
Norway, Nordland, Leknes
Joined Jun 2012
I get this error....with mapmaker
Bjoern
Thidsa is offline Find More Posts by Thidsa
Old Oct 07, 2012, 06:27 AM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
Gentlemen,
first of all, I have read the *F* manual... and I haven't found an answer there.
I'm a complete novice in fpv so pardon my questions
1 - Am I right presuming that once I switch to using a so called data link a.k.a. data modem or data radio I stop using my 'normal' receiver on the plane's end; instead I use it on the ground as part of the ground station set up?
2 - If yes, that means I don't need to use the 'big' female plug that normally goes into the lower right side of the AP unit, and this lower right 8-pin connector remains vacant... Instead, the data link's 4-hole plug goes into the UART part of the AP, is this correct?
3 - If it is correct, that means OSD has nowhere to be plugged in because there is only one UART connector, and the manual reads "This interface connects to the data radio, PC computer serial port or OSD module". Does it mean I have to solder a parallel two-head cable so that I can plug both data link and OSD into the UART connector of the AP unit?
Thank you.
Cathay Stray is offline Find More Posts by Cathay Stray
Old Oct 07, 2012, 08:50 AM
Joined Sep 2012
hope this helps
Steve
Yes, this does help ----- a bit. Not all data is listed. But anyway, I got an automated reply from Feiyu that they are on holiday, starting again tomorrow. So maybe they will give me the full set. Would be a very nice option of you could just press a button "Load factory settings". Thanks for your help.
Old Oct 07, 2012, 09:00 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
side offset dampening is one to play with in flight..
on m 31AP I have it cranked up to 70 and in Panda I have around the same value.
This i find is how hard it tries to keep to a straight line and follow course... play with it.. you won't crash because of it but the plane will really zig zag if it's too low...
Steve
Old Oct 07, 2012, 09:03 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
1. No please do not use the data link to fly your plane. Use your receiver to fly and the data modem to tune etc. Using the data link creates too much latency (delay) of course this is just my opinon but it's my strongest recommendation.
2. There should be a parallel cable from the osd to the 31AP such that the data modem shares the data. Note that you will not have voltage amps etc in your GCS if you use get the data on the OSD.
Steve
Originally Posted by Cathay Stray View Post
Gentlemen,
Thank you.
Old Oct 07, 2012, 09:04 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
agreed and I will suggest them to do this as well... or you can say I second the suggestion as they know me fairly well.
OK what are you missing? I can give you values to start with.
Steve
Old Oct 07, 2012, 07:06 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Can anyone else running FY31AP 2.0 firmware confirm if the version number programmed it to it is wrong? I flashed 2.0 to my FY the other day and after programming it still read 1.2, but I am thinking they may have forgot to update the version # in the firmware.
Other then that it does seem to fly a bit better now, they must of worked on the routines some.
NorCalMatCat is offline Find More Posts by NorCalMatCat
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
