Old Jul 25, 2012, 12:31 PM
czorzella is online now
Find More Posts by czorzella
czorzella's Avatar
Brazil, SP, São Paulo
Joined Jan 2012
FY31AP FAF mode
Hello Steve
First let me thank you for posting all the FY31AP and GCS movies you made; they are very nice and helped me figure out how to use it.
Perhaps you can help me on this one; I'm trying to enable FAF mode on the FY31AP with the GCS, but for some reason it doesn't save the flying mode configuration to the FY31AP. Every time it returns to default NAV mode instead. It's already running on firmware 1.20.
Any thoughts about that?
Carlos
Originally Posted by saabguyspg View Post
Video's
http://vimeo.com/35180853
how to connect
http://vimeo.com/31307727
FY GCS overview PLEASE CLICK THE LINK IN THE UPPER LEFT CORNER AND WATCH IN HD ON VIMEO OR IT WILL BE BLURRY!!!!
http://vimeo.com/38753825
czorzella is online now Find More Posts by czorzella
Old Jul 25, 2012, 04:17 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
do you have it on a 3 position switch?
also the 31ap does not maintain altitude in the middle switch position.. it only maintains roll and pitch.
in navigation mode it will maintian preset altitude.
you need a three position switch and need to adjust the enpoints of the switch to get your desired modes on some radios
Steve
saabguyspg is offline Find More Posts by saabguyspg
Site Sponsor
Old Jul 25, 2012, 05:25 PM
czorzella's Avatar
Joined Jan 2012
Steve
Thank you for your information.
I have it configured on two x three position switch but I didn't actually test it on flight.
Reading some posts back I had an impression that by selecting FAF on GCS, then the NAV mode would be disabled; I was expecting to see the acronym "FAF" instead of NAV on screen of the Hornet OSD.
Are you saying that even if NAV mode is being showed on OSD, FAF is actually enabled? If so, is there a different way to confirm FAF mode is selected? Maybe using the GCS?
Carlos
Steve
Old Jul 25, 2012, 05:33 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I will start over..
the three position switch on your RC TX is manual, stabilize and navigation.
Stabilize will not maintain altitude with 31AP
Navigation will go to pre set waypoints
if you click an icon on the GCS screen in an attempt to change these modes it will do nothing all of this is controlled via RC TX
Now the Hornet is supposed to show the waypoint that you are flying to in the middle at the bottom on the screen when in navigation mode
If you are in stabilized mode I am sure it should say something else... I am not 100% familiar with the hornet's OSD.
In the gcs if you select stabilized mode the green icon should light up indicating this and NOT the navigation icon.... this will tell you that you are in the stabilized mode
Anothe way to tell is to simply put it in stabilized mode and the control surfaces should move as you bank the plane back and forth.
If you are in navigation mode and do the above test then the control surfaces will do much more strange things... but don't worry it won't do that in the air.
Things to remember RTL and Auto circle modes on the other switch take priority over manual stab and nav modes... so make sure you are in the middle on that switch.
also tripple check in stab mode that your surfaces are going the right way when the plane is banked left right up down etc.
does this help??
Steve
Site Sponsor
Old Jul 25, 2012, 07:14 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I believe he is refering to the new GCS ability to re-program nav mode for Altitude Hold, Heading Hold, or NAV, I have not yet tried this functionality myself... But when you are in balance mode it says ABM on the Hornet OSD, If you go to NAV mode it will say WP1, WP2, WP3 (Or something similar to this...)... etc, RTL will say RTL, Circle mode will say ACM.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jul 25, 2012, 08:04 PM
czorzella's Avatar
Joined Jan 2012
Steve,
NorCalMatCat understood my question. I've attached a PDF file where you´ll see snapshots of available GCS flying mode options and expected FAF mode
displayed on the hornet.
I just got a message from Feiyu-Tech support saying they were able to reproduce this issue and they expect to have it cleared on the next Hornet firmware update. Until then, I'm afraid we won't be able to use this FY-31AP functionality which was added with firmware 1.20.
Old Jul 26, 2012, 08:17 AM
voyager4 is offline
Find More Posts by voyager4
voyager4
The Netherlands, NH, Den Helder
Joined Sep 2005
My micro sd card into the hornet Osd didn't record anything of the FY-31. I have send Feiyu tech an email. In there answer they ask my if I use the 1.5 version, but there is no such a file on the download page of FY. The newest on the site is V1.4, that is what I use. Anyone know where to find the 1.5 version for the hornet osd?
voyager4 is offline Find More Posts by voyager4
Old Jul 26, 2012, 08:24 AM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
Had some RTH issues with my FY31AP in the last few weeks.
A lot of hair pulling and scratching, and I finally traced it to my old AP117 OSD which I had 'recycled' for my X8 AP plane.
Conclusion: the AP117 CANNOT be used with the FY31AP. I have no idea why, but it messes up the RTH function AND the GCS communication too.
After I installed the Hornet OSD, everything works as advertised.
Wish I'd figured this out earlier. Could have saved me a lot of grief.
BB
borneobear is offline Find More Posts by borneobear
Old Jul 26, 2012, 10:11 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
MMM I use my old AP117 with 31AP
What issues did you have? did they crop up after a while?
Maybe I need to swap to the hornet. I removed the Hornet from my panda becuase I literally just watch the GCS with that thing... I don't ever fly it FPV becuase it's been so reliable I can tweek setting etc all day long....
I also just moved my Panda to my skywalker becuase the X5 is J.U.N.K.
Steve
Site Sponsor
Old Jul 27, 2012, 09:12 AM
Lachlanhayes is offline
Find More Posts by Lachlanhayes
Tester 22
Australia, NSW, Lismore
Joined Oct 2010
Fy31ap
Hi guys.
First flew FY31AP in an X5 today. Went well.
Setup is X5, newer canted wingtips, unmodified thrust angle. Will add some pics later. Turnigy SX 3513 1420kV 40APlush, works great perfect power, not over powered though. EZUHF on Futaba 12FG with 8 ch lite Rx. Works great and with flt conditions set for each mode I have expo + less travel set for RC mode with separate trims on each mode. 2x 2200 3s in parellel gives 30 mins. Great! Ezosd with IRC 5.8 ghz vid setup with eztracker great, gives 2 km range with 5 turn helical.
CG is about 2cm in front of pimples. So a bit of throw is required in pitch. Got thrust line and trim perfect before going to abm. This makes a bit difference!!!! Was really windy today but RTH and ACM worked great. Coming back xwind, some big hdg changes were made to track back home, but all good. Wish that the fixed alt mode could be enabled though.
X5 with fwd cg was pretty sweet.
Cheers
Lachie
Lachlanhayes is offline Find More Posts by Lachlanhayes
Old Jul 27, 2012, 02:11 PM
voyager4 is offline
voyager4
Joined Sep 2005
Get the Hornet V1.5 file today, thanks Feiyu tech
Old Jul 27, 2012, 02:48 PM
Joined Oct 2011
Hey where did you get it? It's not listed on the website, can you attach a link to it? Also what changes are in it? (Hopefully they fixed the SD Card reset bug!)
Old Jul 27, 2012, 04:39 PM
voyager4 is offline
voyager4
Joined Sep 2005
I get the file from Feiyu Tech, I send them an email and they are responsing very quick, great FY. I couldn't find this file on the FY site, maybe they will place it soon? I can send it to you by mail if you want.
Don't know the difference between the v1.4 and 1.5 yet ,and if it fix the sd card bug I don't know that too. At first sight I didn't see changes. I will test it asap.
Old Jul 31, 2012, 05:52 AM
czorzella's Avatar
Joined Jan 2012
Concerning the FAF mode not being displayed on Hornet OSD, I've inquired Feiyu-tech if v1.5 would have resolved the issue and I got the following reply:
Dear sir,
We will renew the OSD firmware that it can display "FAF" as soon as possible. If it is tested successful ,We will tell you . Thank you very much!
Feiyu Team.
Old Jul 31, 2012, 06:52 AM
GasmanR is offline
Find More Posts by GasmanR
Addicted to Foamies
GasmanR's Avatar
Sydney, Australia
Joined Aug 2006
FY-31 AP Pin Interface
Hi all
Can someone please tell me the function of pins 8,7,6,5 on the 31-AP pin interface. They are labelled GND, Power, P1, P2 respectively but their function / purpose is not listed in the manual. Can I use pins 8 & 7 as power input from an ubec to avoid powering things from my esc via the throttle pins ?
Chris
GasmanR is offline Find More Posts by GasmanR
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
