Old Feb 11, 2013, 11:32 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
Yes 2d is better in the field but 3d has more setup options for panda.
If you have a fairly new laptop 3d has been pretty reliable for me.
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Feb 11, 2013, 11:34 AM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
That save will save everything so make sure you read before saving on that page.
Use the 3d Gcs to set up your plane I think it's easier.
Originally Posted by jbx907 View Post
hi, what CGS are you using? version? when i change my NAV mode to FAF, i dont see any save for it! is the save fuction for parameters only?
Old Feb 11, 2013, 12:04 PM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
With no panda, would 3d still be easier? Just a cheap 2 year old desktop running vista.
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Feb 11, 2013, 12:13 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
1st off dispose of "Vista"..
hendrnk is offline Find More Posts by hendrnk
Old Feb 11, 2013, 03:20 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
i find the interface easier but it's not needed... stick with the 2D if on vista...
Old Feb 11, 2013, 04:35 PM
ooren is offline
Find More Posts by ooren
Israel
Joined Dec 2012
Hi,
can someone help a Newbee?
cant operate the 2D neither on vista nor on win 7,
I am not sure if the problem is with the gst files I'm creating or the software I installed .
is there other Gcs softwares that I can use with fy31ap not made by FY ?
I will appreciate it if someone will upload a gst file that he was able to use,
any file, don't mined the location.
thanks.
Oren
ooren is offline Find More Posts by ooren
Old Feb 11, 2013, 05:32 PM
jstark45xd is offline
Find More Posts by jstark45xd
jstark45xd's Avatar
United States, NV, Gabbs
Joined Feb 2012
Originally Posted by ooren View Post
Hi,
thanks.
Oren
I was just having the same problem with GPS 3 and 4. I had to go into properties and change compatibility mode to Xp service pack 2. Then everything started working.
I thought I read somewhere that you could also change from meters to feet somewhere too?
jstark45xd is offline Find More Posts by jstark45xd
Old Feb 11, 2013, 11:13 PM
ooren is offline
Israel
Joined Dec 2012
I changed to administarator mode and to Xp service pack 2.
still with the same problem,
can anyone upload a working gst file (or send in a pm) ?
will appreciate it !!!
thanks,
Oren
Old Feb 12, 2013, 09:13 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
thanks,
Oren
A xxx.gst file comes together with a xxx.jpg file. You need to experiment with the software until it creates both. If you choose a too big area, it will not create the jpg file and your xxx.gst file will not work.
I tried a couple of times until I understood the limitations.
Pattaya01 is offline Find More Posts by Pattaya01
Old Feb 12, 2013, 09:57 AM
Joined May 2010
Is the default RTH altitude 100 meters? It will climb/descend to this in RTH mode?
Thanks.
Old Feb 12, 2013, 12:06 PM
hendrnk is offline
Joined Apr 2012
Thanks.
I thought RTH was defaulted to like 50m,. It should climb to this level when initiated.
Old Feb 12, 2013, 03:08 PM
jsnyder is offline
Find More Posts by jsnyder
Joined Jul 2009
Hello, I am new to this device and stabilized flight but here is my question.
After buying a new FY31AP and setting it up as per the manual all of the modes seam to switch and function ok but modes i do not have any rudder control or any movement of the rudder through the transmitter. I have down loaded and installed the latest fermware but no rudder movement from the transmitter if i move the FY31AP from side to side the rudder will jump from side to side.
Need so help, also i have tryed to send email to feiyu tech service but it keeps getting returned as not deliverable.
Thank You,
John
jsnyder is offline Find More Posts by jsnyder
Old Feb 12, 2013, 03:10 PM
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
check the dip switches again... the manual can be confusing and you may have them all opposite to the correct direction..
does the aileron stabilize and work properly?
Old Feb 12, 2013, 03:26 PM
jsnyder is offline
Joined Jul 2009
Yes all other controls seam to work ok but not the rudder. I have moved the dip switches up and down and left them in the down position.
Old Feb 12, 2013, 04:37 PM
hendrnk is offline
Joined Apr 2012
In manual mode on the FY31AP, the rudder still does not move. You might want to check the cable going from the receiver to the unit or switch the aileron cable to the rudder port on the FY-31AP and see if the rudder moves when you move the aileron on the Tx.
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
