Old Feb 06, 2013, 08:56 AM
simplyfly is offline
Find More Posts by simplyfly
go ahead and try
Canada, ON, Maynooth
Joined Nov 2011
Originally Posted by Pattaya01 View Post
No, it doesn't make sense at all. When I switch the 31 to Manual mode, it should just pass the signals through. This way, it is always involved and needed. Secondly, when the 31 has a problem and I remove it, I have to completely set up my TX for flying wing. Thirdly, if this is the case, it should have been mentioned in the manual.
Don't get me wrong, I still like the 31 and very happy to use it, but there is a BIG lack of information. This forum compensates for that a lot, but it shouldn't be necessary.
True.
The manual doesn't mention what the setting does... I agree, it would be better not to mix the elevons... and it would be nice to have a more detailed description of the different modes in the manual.
Try setting the 31 back to normal fixed wing, and then make your mix. The dip switch setting may only add the mix, and nothing else... of course, you can always use another model memory slot.. to have one with / one without the mix...
simplyfly is offline Find More Posts by simplyfly
Old Feb 06, 2013, 09:06 AM
go ahead and try
Joined Nov 2011
on a side note... if anyone is interested in a pair of data 602 modems...
http://www.rcgroups.com/forums/showthread.php?t=1825993
Old Feb 07, 2013, 01:01 AM
jbx907 is offline
Find More Posts by jbx907
Philippines, Central Luzon, Guiguinto
Joined Jul 2011
i think changing setting on CGS is good until you turn it off, then everything reset to default. i tried changing altitude to 100 and circle radius to 50, while its on its good, but when turned off, everthing reset to default value went back to alt 50 radius 80.
im not sure about FAF in NAV mode, there no way to find its in FAF mode!
not sure about that...
thinking of getting the FY-DOS, it shows to have this fuction on it!
jbx907 is offline Find More Posts by jbx907
Old Feb 09, 2013, 02:00 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
After you change the values, you have to save them. So first you press "Set", then you press "Save".
Pattaya01 is offline Find More Posts by Pattaya01
Old Feb 09, 2013, 10:44 PM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
yes and make sure you hit read before you change any settings then hit save... then it will save everything even after a power off.
Stev
e
saabguyspg is offline Find More Posts by saabguyspg
Old Feb 11, 2013, 12:56 AM
Deadstick 8409 is offline
Find More Posts by Deadstick 8409
Deadstick 8409's Avatar
Joined May 2010
Newbee alert! I have the ap31/hornet, and would like to download the GCS. It is a RAR file, which I can not open. Is there a different site without rar files? I downloaded some app to open rar's, but it was only free for 2 weeks. I'm cheap.
Help!
Deadstick 8409 is offline Find More Posts by Deadstick 8409
Old Feb 11, 2013, 03:09 AM
jbx907 is offline
Joined Jul 2011
hi, what CGS are you using? version? when i change my NAV mode to FAF, i dont see any save for it! is the save fuction for parameters only?
Old Feb 11, 2013, 03:11 AM
jbx907 is offline
Joined Jul 2011
Help!
its ok to be tiral, right click the rar file and extract to a folder, you wont need it anyone when you've extracted the compressed file to a folder!
Old Feb 11, 2013, 06:57 AM
PistaJ is offline
Find More Posts by PistaJ
Joined Oct 2009
Air speed manager ready for sale
The airspeed manager adjustment has finished. It is ready for you to use. Its price was set to 75 USD. It could be programmed by a very simple procedure during the flight, or by yeti box for those who already have it.
Question for the experienced:
One of my new FY31AP needs to get the gyro resetting done nearly every time I want to use it. Is it normal?
PistaJ is offline Find More Posts by PistaJ
Old Feb 11, 2013, 07:13 AM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Its not normal, but recently when the weather has turned cold, i.e. below 32F I'm having the same problem. I was going to wait until spring to see if this is still the case. Hopefully its a cold thing only.
hendrnk is offline Find More Posts by hendrnk
Old Feb 11, 2013, 10:18 AM
Joined May 2010
Is there a download site that does not involve rar files?
What is the difference - or better why, would one select 2d over 3d on the software? Do I even need the software? I would like to set the RTH altitude, and I think that is about it. Only FPV, no autonomous flight. Thanks.
Old Feb 11, 2013, 10:40 AM
hendrnk is offline
Joined Apr 2012
2D generally means let go of your sticks and the plane will return & fly straight & level. 3D generally means let go of your sticks and the plane will continue to fly at the attitude that you left it. i.e. knife edge, vertical, upside down etc, dependning on the plans ability.
FY31 doesn't have 3D capability.
There are many RAR utilities that are free to use to read / save RAR compression files. Just do a Google search.
Old Feb 11, 2013, 11:14 AM
Joined May 2010
But isn't there 2d and 3d software? I thought it would have to do with mapping?
Old Feb 11, 2013, 11:24 AM
hendrnk is offline
Joined Apr 2012
Sorry miss understood you on the software side.
I have tried both versions of the software. I find the 2D more reliable. You can utilize off-line maps etc with the GCS.
3D has dynamic maps but you will need an internet connection but I find the Software not very reliable. Craps out from time to time / very resource hungry.
Capability essentially is the same in both.
Old Feb 11, 2013, 11:29 AM
Joined May 2010
Thanks! 2d it is then.
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
