Thailand, Chon Buri, Pattaya
Joined Sep 2012
I never knew this feature of "course and altitude hold". How to enable/disable this? |
Joined Sep 2012
Could it be you are mixing up with another AP? I do not want to un-intentionally enable this function and loose my plane. |
Australia, QLD, Brisbane
Joined Aug 2012
Then you can tweak and tune it. Easily done as the descriptions are very good. The mission planner software is excellent. Air speed sensor, current sensor, minimosd I have working really well. I wanted rssi from my rangelink displayed on the osd. Took 5 mins to wire up. Used the customisation utility for the minim osd and its working well. Can't say how pleased I am with the a 2.5. It lets me do anything I can think of. |
Joined Oct 2011
If anyone gradiometers to explain how to make. Thanks in advance to all. Joseph |
Joined Apr 2012
After about 15 minutes of tuning... Here is a log from a flight with my panda on the weekend...
Just received the F-TEK, with Hornet OSD from HK
Reading this thread you suggest 3 batteries ? One main for the motor, one 2s with BEC for the reviver, and one third 12V 3s for F-TK and OSD????? I have X8 wing with 6000mAh 4s for the motor I have Castel BEC 10A, a voltage regulator set at 12V, and separately a noise filter for the camera (Pixim-seawoolf) Please tell me the correct connection and if I need something else I have to solder the filter at the out of 12V regulator for all 12 V device or just only for the camera If I set the Trx (800mW) near motor and ECS(85A) will be a problem with FR noise? I' very confused |
Hi and thanks for the link!
I will be using it on the logged data at the ground control station and I assume it will be in the same format. I have been very busy lately working too much.So this log converter... does it output a lat, long, elevation and time file? say comma delimeted text file or something? I need to input that data into another program. Thanks again. Steve Quote:
Joined Apr 2012
The converter is mine, produces KML file, it needs some upgrading actually since I made it before FY officially released the protocol (I reverse engineered the entire telemetry protocol!).
Latest blog entry: Flying in the Neighborhood
| Thread Tools | |
| New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio | yiny0730 | Video Piloting (FPV/RPV) | 316 | Sep 19, 2011 01:30 PM |
| Discussion Question: KK board and FY-20 or FY-90q | Hamanu | Multirotor Talk | 2 | Feb 08, 2011 04:10 PM |
| AXI'fy your CORONA...NIB 2820/10 | iflych52 | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2004 08:24 AM |
| Fy or Die ? a newbie poll | Demolisher | Foamies (Kits) | 29 | Mar 08, 2003 02:31 AM |
