Old Jan 07, 2013, 03:58 PM
Miber is offline
Find More Posts by Miber
Joined Oct 2012
Just got my Fy31ap, need help
Hi guys, i just got my 31ap, and test it to connect all wire up. When i did a gyro initialization (with jumper on) and power it for 20 sec, i felt like it works. I connect all of the servos, receiver and the gps module and all servos gave a respons for any movement of the stabilizer (even it should move in the opposite direction). But after a few minutes, the gps modul start turn on the solid red light and the red led in the stabilizer start flashing continuously, and all servos are freeze. What happen?
And i powered it off, when powered it on again it still happen. The red light in stabilizer contiuous flashing and gps red light is on, and when i connected servos the servos freeze again but it sounds like the servo were powered to hold their position, there is a "zzzzzzzzttt" sounds coming from servos.
I thought i need to reinitialize the gyro, i did it again. With the jumper on i powered up the stabilizer, it show the led blinking rapidly like normal initialization, but after about 10 sec, it happen again. The red led in flight stabilizer is blinking again even it was stationery.
Is it normal that when we initialize/reset the gyro the blue led also flashing?
Is there anything wrong that i did in the connecting process?
I connected all wire and servos just like in the manual, the 31ap get power from the esc wire plugged in the throttle pin.
Need your help, thanks guys..
Miber is offline Find More Posts by Miber
Old Jan 07, 2013, 07:05 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
What flight mode are you on?
Did you set your flight modes via your radio yet?
If your servos are not moving when you move the FY31AP, that sounds to me like you're in RC mode.
Not sure about the Red LED flashings, but I think they are normal.
BB
borneobear is offline Find More Posts by borneobear
Old Jan 07, 2013, 08:46 PM
Miber is offline
Joined Oct 2012
Hi BB,
I havent set the SW 1 yet in my transmitter, jut set the SW2 with the turnigy pot. And any position that i switch the red led still flashing continuously.
I'll try to reconnect it all later..
Thank you
BB
Old Jan 08, 2013, 01:13 AM
hendrnk is online now
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
I was wondering if you thought these might work for Data Modems for the FY31AP.
http://www.event38.com/ProductDetail...uctCode=RFD900
http://www.rcgroups.com/forums/showthread.php?t=1659592
hendrnk is online now Find More Posts by hendrnk
Old Jan 08, 2013, 01:42 AM
sgrouts is offline
Find More Posts by sgrouts
Vote F5J Gracia for FPV
sgrouts's Avatar
Joined Jun 2012
Like borneobear said, check your flight mode.
Regarding powering the fy31ap. The normal way is through aileron input pins, not throttle.
Check your manual schematics again
Sakis
sgrouts is offline Find More Posts by sgrouts
Old Jan 10, 2013, 07:48 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Anything that uses standard TTL will work, that will work just fine. Though I don't really recommend 900mhz.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Jan 10, 2013, 07:54 PM
Joined Oct 2011
Anyone care to comment on the 2.1 firmware for 31AP? Also anyone tried using the OSD on the GPS TX line instead of the other UART? From what I wa reading of the chinglish written the refresh rate on the GPS uart is much faster, actually I could do the math, I do believe the GPS UART is 38k baud...
Old Jan 10, 2013, 08:50 PM
eduardokenithi is offline
Find More Posts by eduardokenithi
São Paulo - Brazil
Joined Sep 2010
Im not using a external BEC to power my RX, I'm Just using the ESC. Everything seems to be OK, but the manual recommend the use of an extra BEC.
Anyone having problem using only the ESC to power the RX?
sorry my poor english
eduardokenithi is offline Find More Posts by eduardokenithi
Old Jan 11, 2013, 01:50 AM
GTiDonavan is offline
Find More Posts by GTiDonavan
Joined Jan 2012
Pot conversion to 3 way switch.
Need a 3 way switch from radio shack.
Need 2 * 4.8k ohm resistors. (the pot your replacing is a 10K)
The middle wire from the pot goes to the middle terminal of the switch.
The outside wires from the pot go to the outside terminals of the switch
A 4.8K ohm resistor goes between the middle & the outside terminals.
Make sure your 3 way switch as a center off.
Very easy works like a charm
Why do you use 4.8k resistors and not 5k?
GTiDonavan is offline Find More Posts by GTiDonavan
Old Jan 11, 2013, 08:12 AM
Joined Apr 2012
I don't think 5K resistors exist anyway at least not from Radioshack. I actually used 4.7k resistors. When its calibrated with er9X it doesn't really matter. And I didnt notice any issues with the stock firmware either.
Old Jan 11, 2013, 08:42 AM
Pattaya01 is offline
Find More Posts by Pattaya01
When a hobby gets a passion
Thailand, Chon Buri, Pattaya
Joined Sep 2012
I have been using the BEC of my ESC to power everything for long time without any problems. I just recently changed to an extra BEC to have a bit extra safety.
The only reason I can see is the following. When your motor has a short circuit, your ESC might burn and consequently, the internal BEC as well. By using an external BEC, even the ESC burns, you will still have power for the rest of your electronics so you might have a more or less controlled landing.
But of course this is only valid if you install a high quality BEC. Otherwise you will create another potential problem.
Pattaya01 is offline Find More Posts by Pattaya01
Old Jan 11, 2013, 08:46 AM
Joined Sep 2012
I updated to the latest version and works fine. I also tried to follow the suggestion to change the connection on the OSD, and it doesn't work. No idea what they mean and there is no proper connection diagram. So I changed back to have the OSD connected to the GPS again.
Old Jan 11, 2013, 11:07 AM
saabguyspg is offline
Find More Posts by saabguyspg
saabguyspg's Avatar
Calgary Canada
Joined Jun 2006
I use the osd parallel with the gps conneciton on my DOS system no problem but still have the 31AP hooked up the old way... if it aint broke don't fix it
Steve
saabguyspg is offline Find More Posts by saabguyspg
Old Jan 11, 2013, 11:42 AM
larry baraniuk is offline
Find More Posts by larry baraniuk
Banff Alberta Canada
Joined Nov 2004
Just wondering why you don't recommend 900 Mhz.
larry baraniuk is offline Find More Posts by larry baraniuk
Old Jan 11, 2013, 12:18 PM
Joined Apr 2012
My flight path with the FY-31 looks like the Skywalker is drunk. This is with default settings.
The RTL circle seems nice and around. The wind was fairly strong as well. The flight path near the circle stuff is just me flying around but ore interested in the flight path out over the farm. Seems really inefficient.
New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio yiny0730 FPV Talk 316 Sep 19, 2011 01:30 PM
Discussion Question: KK board and FY-20 or FY-90q Hamanu Multirotor Talk 2 Feb 08, 2011 04:10 PM
AXI'fy your CORONA...NIB 2820/10 iflych52 Aircraft - Electric - Helis (FS/W) 0 Jul 26, 2004 08:24 AM
Fy or Die ? a newbie poll Demolisher Foamies (Kits) 29 Mar 08, 2003 02:31 AM
