Fy-31ap
OK I will start a 31AP thread.
Some general info 1) 31AP is an IMU autopilot (no thermo piles) 2) it has a functioning GCS in windows 7 3) the AP can remember up to 20 waypoints (with latest firmware) 4) it can also RTL, circle at given location and do "click and fly" 5) it works with xbee pro ttl modems 6) it has NO airspeed sensor however it does increase throttle to keep ground speed PLEASE NOTE!!! there is some work being done to add airspeed control found here http://www.rcgroups.com/forums/showthread.php?t=1807224 7) it is VERY easy to hook up and get flyling 8) it is also very cheap and now shipped with an osd Who am I? I do not work for FY, however they did send me this autopilot for testing before it's release, we found some minor bugs with the GCS that now seem to be corrected. The only bug I can see right now is that for some reason my RTL altitude seems quite low... be aware of this and check on your platform. I have done a quick video on my last flight. Everything about this AP is easy very self explanitory. I give it a 9 out of 10 for the price (even if I had to pay) The only reason I don't give it a ten is becuase of my RTL altitude... however all waypoints seem to maintain altitude well. About me.. I own or have tried the following for fixed wing craft. 1) Ardupilot 2) Atto pilot (never really got the support I wanted and they moved on wanting more money for features I thought were standard) 3) FY-21AP (good but this is waaaaay better) 4) FY-3ZT (good but more complex) 5) FY-Panda system (replacment for 3ZT but have not flown it yet) 5) Eagle Tree (excellent but no waypionts or GCS) Ok I will reserve some first posts then update as required. Steve |
Tech FAQ's
FY HAS RELEASED A FIRMWARE UPDATE THAT IS VERY IMPORTANT!!! ENSURE YOU UPGRADE TO THE LATEST BEFORE FLYING!!!! how do I change the mode from navigation to heading hold? see this post http://www.rcgroups.com/forums/showp...postcount=1821 what do the tuning parameters do? see this post for a WORK IN PROGRESS. http://www.rcgroups.com/forums/showp...postcount=1730 where do I buy it? http://shop.fyetech.com/index.php?cPath=21_40 can I use my own modem? yes, I have found the xbee pro (900mhz) work well with the system, however I do find that for the first GPS lock of the day I need to unplug the data modem so the gps can get a lock... then after that it finds sats no problem even after rebooting. does it work with XP? yes but I had slow connection problems, I recommend a recent laptop running win 7 with 4GB of ram how do I upgrade firmware? http://www.rcgroups.com/forums/showp...&postcount=429 My firmware version is not reading correctly after upgrading it whats going on? Check that the baud rate is set correctly in your device manager it should be 19200 how cold can it be to fly? I have fllown with no issue down to zero deg C. However, I did fly at -10 and I had problems. I think that if I re-initialized the gyro's before that flight then things would have gone better. The manual states working temperatures down to -25 deg will it display my voltages and current on the GCS and the OSD? No it does not... I don't know why but I have even confirmed this with FY that you will not see the voltages on the GCS Where can I find the latest gcs download? the latest one is found here http://www.feiyu-tech.com/download-e...d=43&nav_num=6 I have it working on windowns 7. Run AND INSTALL this program as an administrator. There is a 2D GCS now but I need to make a map (gst and jpg file) for it... where do I get the program? They now have two programs to make the offline 2D maps, one called mapmaker which I have a how to video below for and one called GScreen but I need to make a video for that. Both will need an older version of Google Earth found here http://www.feiyu-tech.com/download-en.php?id=63 Where do I find other FY downloads like firmware upgrades? they are found here http://www.feiyu-tech.com/download_list-en.php Please explain the differnce between gyro init, setting level, and servo neutral http://www.rcgroups.com/forums/showp...postcount=2038 |
Video's
how to connect
FY GCS overview PLEASE CLICK THE LINK IN THE UPPER LEFT CORNER AND WATCH IN HD ON VIMEO OR IT WILL BE BLURRY!!!!
FY 2D GCS overview
How to use mapmaker (please download and view on your computer because the file is not working on Vimeo for some reason)
Canada, ON, Maynooth
Joined Nov 2011
Mr. K... I have a basic Question regarding the power supply to the FY-31A. I am going to be supplying power to the system via ESC BEC. My newb question relates to how the power should be applied. I understand power is supplied via Rx Ch.1. I wonder how I should do this properly. Eventually I wll use an external BEC, which makes sense to me, however I am still waiting for a delinquent package with the new BEC in it... So for now I am just wondering the correct method for powering the unit from the ESC...???
Joined Nov 2011
I just received mine, from Feiyu tech. Here is the current pricing:
FY-3Zt (Panda) $1323 FY-31AP $199 Hornet OSD w/ GPS $138 FY-31AP Trade Edition $289 (includes all of the above) 2.4g Data radio 606 $129 x2pcs 433M Data radio 602 $239 x2pcs 433M Data radio 605 $295 x2pcs Hope this helps! |
Joined Nov 2011
What I have so far... Perhaps a properly wired example could be shown here... I hope the photo helps. The connection from the Rx to the FY-31 is obvious. The connection to the GPS I think is correct. The current sensor, shown with the ESC and supply battery make sense... The three control servos are correctly connected I am sure. The OSD receives power via the 1300Ma shown to the left, which also powers the Vid Tx and camera.
The Vid in and out is a little unclear to me... The Vid in and Vid out makes sense, but the corresponding pins do not seem to fit a standard two pin connection. It seems that the connection is made across the two top pins, horizontally, yet the key on the top of the unit suggests that the connection is made vertically, which is where the problem with the two pin connector is. I hope that someone more familiar with the "correct" way to set this system up will post a response... |
| Thread Tools | |
| New Product FY thread: FY20A/FY21AP/FY3ZT/FY31AP/FY90Q/FY91Q/FY-Frame/FY-GCS/FY-OSD/FY-Dataradio | yiny0730 | Video Piloting (FPV/RPV) | 316 | Sep 19, 2011 01:30 PM |
| Discussion Question: KK board and FY-20 or FY-90q | Hamanu | Multirotor Talk | 2 | Feb 08, 2011 04:10 PM |
| AXI'fy your CORONA...NIB 2820/10 | iflych52 | Aircraft - Electric - Helis (FS/W) | 0 | Jul 26, 2004 08:24 AM |
| Fy or Die ? a newbie poll | Demolisher | Foamies (Kits) | 29 | Mar 08, 2003 02:31 AM |
