Old Jan 16, 2012, 06:07 PM
warhead_71 is online now
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Funbuild 5: 59" foam Grumman Goose
**** Getting her balanced and trimmed ****
Foamie 59" RC Grumman Goose : Flight 4 (0 min 0 sec)
Foamie 59" RC Grumman Goose : Flight 3 (5 min 34 sec)
Foamie 59" RC Grumman Goose (4 min 9 sec)
**** Build montage and maiden flight, June 30, 2012 ****
Foamie 59" RC Grumman Goose (4 min 55 sec)
**** Taxi test and an accidental hop, June 23, 2012 ****
Grumman Goose taxi test (5 min 27 sec)
**** Float test, June 22, 2012 ****
Foamie 59" RC Grumman Goose : float test (0 min 0 sec)
**** Electronics Installed, April 16, 2012 ****
RC foamie Grumman Goose (1 min 42 sec)
**** One year later: Brown County Forest Preserve, Indiana. April 19, 2013 ****
Grumman Goose (1 min 47 sec)
I drew this up almost 2 years ago but home remodeling and kids put it on the back burner. I guess this is the perfect excuse to start building it.
I'm going to go with the 1/10th scale size, wingspan 58.8" and length 47.4". Made from 1/2" pink foam and 1/4" FFF. I might deviate from the plans here and there as I want to try a few different methods for building up wings and covering the foam.
Power will be from 2 DAT750 motors turning 11x6x3 props on 3S 2200mah-3300mah. Should make about 35oz of thrust each or 70oz total. This is my first twin, but I want to try differential steering for water taxiing.
581.4squin wing area
64oz AUW (estimated)
Max CL 1.17 (NACA 23015)
Wing Loading 15.85oz/sf
Cubic Loading 7.89oz/cuft (between "trainer" and "sport")
Stall Speed 18.2mph
*** edit ***
Actual AUW is between 74-77oz depending on battery, but it obviously has no problems at this weight as I can ROW at 2/3 throttle and maintain a level cruise at 1/2 throttle.
warhead_71 is online now Find More Posts by warhead_71
Old Jan 16, 2012, 09:27 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
I was wondering what happened to this Goose. Glad to see it coming to life again!
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jan 16, 2012, 10:10 PM
WAGliderGuy is offline
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Sounds fun! There is a Goose that visits a lake near me often and the takeoffs sound great. Looking forward to more
WAGliderGuy is offline Find More Posts by WAGliderGuy
Old Jan 16, 2012, 10:42 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hey Warren,
I'm really looking forward to seeing how you tackle this one.
Funny thing, flying boats and amphibs never really did it for me, but as I've watched a couple come together here on RCGroups, I'm warming to them. The Goose definitely has the cool factor going for it...
Steve
Steve85 is online now Find More Posts by Steve85
Old Jan 16, 2012, 10:44 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
And after the Goose, I want to do the Duck someday....
Old Jan 16, 2012, 10:46 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Hey Warhead .. good to see you are picking this back up ..cant wait to see ya get started..
Vyceroy is offline Find More Posts by Vyceroy
Old Mar 06, 2012, 11:24 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Finally got started on it last night. I made really good progress in about 3 hours work. I have the fuselage box completely built and just need to add the V-bottom triangles and hull sheeting. Everything went together pretty well except I needed to do some light trimming/sanding and a little heating to pull the nose together. This 1/2" foam doesn't bend very easily so I had to "convince" it. A small deviation from my plans is that I built the wing saddle area up as part of the fuselage box and will hotwire out the wing saddle afterwards so I have a perfect fit. Next step will be to carve the nose-block from a single large chunk of foam, then build the cockpit/canopy. Couldn't be happier how easily this is going together. I'll post some pics tonight.
P.S. - this thing is HUGE! I could easily fit the neighbor's cat inside...
Old Mar 06, 2012, 11:30 AM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Now there's a good idea if i ever heard one
Old Mar 06, 2012, 11:35 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Don't be forgetting to build in operating wingtip drop down floats.. it's an important /defining feature..
Bare is offline Find More Posts by Bare
Old Mar 06, 2012, 11:51 AM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
I have not decided whether I want to do the retracting floats or static floats yet... I guess it depends on which paint scheme I choose and what is appropriate for that era. I definitely won't be doing the retracting wheels "yet". I just want to make sure it flies before I go through all the trouble.
Old Mar 06, 2012, 12:14 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
i think the static floats are part of the older gooses charm .. if you get the retracts done i would love a set ..
Old Mar 06, 2012, 12:34 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Float retracts would be very easy just using a pair of mini retracts. Servo-less retracts would make the job even easier. Wheel retracts are definitely do-able... just more complicated than I want to spend time on before I find out if the plane even flies well. If the maiden is good, I can easily retrofit wheel retracts... though the retractable tailwheel might be hard to get to without opening up the turtle deck. I plan to fly this off water most of the time though, so I can't justify the added weight, servo load, and complication other than just as a technical challenge. So maybe after the maiden... if all goes well.
Old Mar 06, 2012, 12:35 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
meant the wheel retracts lol
Old Mar 06, 2012, 04:15 PM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Gotta love a goose! Looking forward to following your progress!
Craig
trumps is offline Find More Posts by trumps
Old Mar 06, 2012, 04:26 PM
LedKitty is offline
Find More Posts by LedKitty
I even seen a house fly!
LedKitty's Avatar
Montreal!
Joined Oct 2003
I'm very interested too!
Definitely subscribed!
Cheers,
Kitty
LedKitty is offline Find More Posts by LedKitty
Question New possible kit - 1/16 scale Grumman Goose zbrubaker Waterplanes 65 Nov 04, 2012 04:35 PM
Question Sport scale parkflyer Grumman Goose zbrubaker Parkflyers 4 Apr 27, 2012 05:40 PM
Question Grumman Goose Retractable Landing Gear Pilatuspc12 Scale Kit/Scratch Built 15 Dec 23, 2011 12:22 AM
Discussion 52-inch Grumman "Cutter's Goose" greenseaships Foamies (Scratchbuilt) 15 Nov 26, 2011 02:46 AM
Discussion My first scratch build.. grumman goose?? flynfunny Foamies (Scratchbuilt) 12 Aug 08, 2011 03:23 PM
