I was ordering the Kontronik's for my Rafale last night so I went ahead and ordered the Kontronik 400-36 / Beat 40-6-12 for the MIG.
Chris - I have read the EZone review on the Mig. When it first came out and again this year after finding the Mig at NEAT. I decided on the Mini Fan instead of the 609 to keep it light. I think I saw it on The Zone that the MF 480 is more efficent at and under 400 watts. I'll probably make new smaller fiberglass ducts sized for the Mini fan. I have three TP 2100 3s packs and they should do well at 40 watts. I think this is the motor/esc/fan that you use in your Parahna. ??? |
St. Mary, Maryland, United States
Joined Dec 1996
. The 400-36 should work fine. The MF setup is a little lighter. No need to make new ducts, just slit the existing duct about 6" lengthwise, stick the MF in with some protective plastic wrap and overlap the ducting until it fits. Secure with Ca, remove fan and maybe run one reinforcing strip along the joint. |
Kevin,
I fly mine with a 609 and a B50-12S on 12-1950 FAUP cells. If you had chosen the 609, I don't think you could get the LiPo's in there. I think it will be fine with the 400/36. I wouldn't put the cheater hole in it either. I don't use it with the 609 so you shouldn't need it with the MF480. Be sure to check the CG, if it's a little tail heavy it will snap roll if you get it too slow. Jim Phelps |
| Thread Tools | |
| Rave Wattage Stearman PT-17 Power set-up | Durwood | Electric Plane Talk | 0 | Mar 28, 2005 11:44 AM |
| Alert what power set-up for mig | rjarois | Electric Ducted Fan Jet Talk | 0 | Dec 29, 2004 08:20 PM |
| Power Set Up for an SRBatteries AcroPro- Will a Mega 16/15/7 or 22/20/4 Work??? | ClipperBill | Power Systems | 0 | Oct 31, 2004 07:55 PM |
| GWS NARO Power Set Almost NIB | mecone | Aircraft - Electric - Airplanes (FS/W) | 0 | Sep 10, 2001 08:08 AM |
| Multiplex TJ Power Set | RICH S | Foamies (Kits) | 1 | Apr 22, 2001 02:27 AM |
