Old Jan 16, 2012, 10:09 AM
alpea 41 is offline
Find More Posts by alpea 41
check for reversed controls
alpea 41's Avatar
United States, CA, Chino
Joined Oct 2007
Cool
Cartoon Mig 15 3 blade prop as DIY EDF
Put this up here cuz it's unusuall..
I built Sparks'es cartoon Mig 15. He designed it to fly with a 3 blade prop cut down to fit in the fuse in the nose.
I first got it to fly as a pusher with tail mounted motor as a pusher , but needed a 2200ma battery in the nose to balance it. Wing loading was high at AUW of 20 oz.
So I mid mounted the motor in the fuse and tried with a cut down prop. Not enough air out the rear. Went to a cut down 3 blade GWS prop , still not enough thrust. Changed to a 2212 06 2200 KV motor and away it flew .
All my trials and successess are at the end of Sparkes Cartoon Mig 15 - F-86 thread here http://www.rcgroups.com/forums/showthread.php?t=1441002
But if you've ever wondered if a crude EDF could be made out of a prop in a fuse , here's your answer
20120115 0641 (0 min 56 sec)
20120115 0642 (0 min 46 sec)
20120115 0645 (1 min 6 sec)
alpea 41 is offline Find More Posts by alpea 41
Old Jan 17, 2012, 11:51 PM
MUTCAKE is offline
Find More Posts by MUTCAKE
MUTCAKE's Avatar
USA, WA, Bremerton
Joined Mar 2009
Now that's what I like! You guys always have fun when you fly! All the laughing makes me laugh. Great job.
Keith
MUTCAKE is offline Find More Posts by MUTCAKE
Old Jan 18, 2012, 09:07 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Well I admire the candor about "crude' :-)
It seems to go around in circles OK. Is it capable of More?
Bare is offline Find More Posts by Bare
Old Jan 18, 2012, 09:15 PM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
I think if I try a 4000 kv motor like your smallest EDF has I will be more comfortable rolling it and it might even loop. But when you try a dozen underpowered launches where it returns to Earth for lack of thrust believe me you are pleasantly satisfied to the point of giddy to fly a few circuits ...
Old Jan 19, 2012, 01:08 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Caproni Stipa next.
Stuart A is offline Find More Posts by Stuart A
Old Jan 19, 2012, 06:43 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
YOU never said what size fan is after cut down prop. I use 3 blad 64mm fan two for $10 3500kv dw 12AMP
space 1 is offline Find More Posts by space 1
Old Jan 19, 2012, 09:33 AM
alpea 41 is offline
alpea 41's Avatar
Joined Oct 2007
Prop was GWS 10x6x3 cut down to about 6x 6x3. the plane woulda flown fine with a light edf set up 64mm or so , the experiment was to make it fly with an internal propeller.
Old Jan 19, 2012, 12:14 PM
space 1 is offline
USA
Joined Apr 2007
yea you need 4000kv motor. make sure prop is on right numbers to front
Discussion 3 channel 1/48 scale MiG 15 with 25mm EDF! Joe Malinchak Micro EDF Jets and Power Systems 5 Nov 30, 2011 07:13 AM
Discussion 70mm edf mig 15 to pusher prop sco215 Pusher Prop Jet Models 0 Apr 22, 2011 01:27 PM
Discussion Alfa Mig 15 or F86 withe 5 blade fan and Mightey Mite EDF motor $169.00!! Bajora Hot Online Deals 7 Mar 14, 2009 04:54 PM
Discussion Simple cartoon Mig-15 Bobnormal Foamies (Scratchbuilt) 10 Apr 13, 2008 12:25 PM
Sold Kamdax Mig-15 EDF & Kamdax Mig-15 Pusher Jets Yardbee Aircraft - Electric - Jets (FS/W) 6 Nov 26, 2006 09:40 PM
