Old Jan 16, 2012, 02:21 AM
Rotatorus is offline
Find More Posts by Rotatorus
Rotatorus's Avatar
's-Hertogenbosch, The Netherlands
Joined Apr 2006
Contest
Funbuild 5: Dornier Do 18 Flying boat
Dornier Do 18 flying boat
After some initial hesitation I have decided to join the Funbuild 5 - Multi engines - contest. I'll be building a Do 18 roughly based on the 1965 Flying models plan by A.B. Swanston. The original plan is for two .15 -.19 engines and has a wingspan of 66". I'll be "microsizing" this one to around 65cm wingspan (25,5") and it'll be build up like a guillows style stick and tissue model.
I intend to power this bird with two 5gr outrunners from Hobby King driving two air-ace counter rotating three blade propellors. Depending on the outcome I might change things to another prop & motor combination.
So far I have printed and stuck together the plans and made initial estimations of what gear might fit. All additional information on the Do18 is welcome and progress will be reported in this thread.
Attached:
- two pictures of the D018
- original plans by A.B. Swanston (1965) in three parts
Robert
Rotatorus is offline Find More Posts by Rotatorus
Old Jan 16, 2012, 06:03 AM
LenBFP is online now
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Hi Robert, that looks like a fine choice for the funbuild. I will be watching with interest.
Len
LenBFP is online now Find More Posts by LenBFP
Old Jan 16, 2012, 07:29 AM
Glong-flyer is offline
Find More Posts by Glong-flyer
Glong-flyer's Avatar
Ballarat, Australia
Joined Jan 2007
Robert love your choice. Have you any plans to do the Do 24 as well?
Will follow
Pete
Glong-flyer is offline Find More Posts by Glong-flyer
Old Jan 16, 2012, 09:57 AM
Rotatorus's Avatar
Joined Apr 2006
Hi Len, Hi Pete,
Welcome to my little thread. I hope to perform to your expectations on this build. I'll sure try to make it an interesting build. Feel free to jump in with tips and remarks when you feel like it. I think the building process will quite easy. I just hope I'll be able to keep her light and balanced to actually get her up in the air and fly her... If that works out then there will be the flying off water.....
For now I'll start with the building. So far I've been cutting up my plan to get the templates for the formers and the other parts. I drew up a little plan for the left wing and alread deviated from the original. I have no need for a removeable wing at this size so the constuction will be straight forward. 6x6mm square balsa for the leading edge and 2x5mm stip balsa for the trailing edge. Flaps and ailerons are made with 2x15mm stip balsa. Also the wingtip curve will be made out of 2mm balsa. All formers will also be 2mm balsa and I might use some 0.4 mm plywood sheeting for high impact area's like the underside of the floats and the bottom of the fuselage.
Biggest challenge at this time is to redesign the engine pod in a light but strong and scale way. Also at this scale it will be a challenge to get a small BL motor in there running free from rubbing the inside of the pod... Cooling????? I need to think about how to do that with this design. There is an oil cooler in the center pylon... Maybe I can use that as an intake for ait but where does it come out...
I'll think of something.
Thanks for dialing in!
The Do 24 is one of my all time favourites. We have one in a small museum at about 40 minutes driving distance. I've been wanting to make one for quite a long time but I got side tracked. I have some 3-views somewhere so maybe I'll give that another try when this build goes well.
Robert
Old Jan 16, 2012, 04:00 PM
Rotatorus's Avatar
Joined Apr 2006
I have made a little progress on the do 18. So far I have made the tailfin, the rudder, the horizontal stabilizer and elevator planes. For the main wing I started with the general outline and the aileron and flaps. Now I need to start cutting ribs in order to make progress.
Robert
Old Jan 16, 2012, 04:36 PM
jofrost is offline
Find More Posts by jofrost
It flew once before...
jofrost's Avatar
Northwood , New Hampshire
Joined Jul 2004
Hi Robert ,
Great choice & welcome aboard the Funbuild 5
-John
jofrost is offline Find More Posts by jofrost
Old Jan 16, 2012, 04:43 PM
Rotatorus's Avatar
Joined Apr 2006
Thank you John!
It is a great plane but I'm already thinking it is a bit small at this size. Very convenient because I don't have a lot of space but it might deliver some issues when installing the RC gear. Well, we'll see what happens.
Robert
Old Jan 16, 2012, 08:29 PM
Wolpertinger is online now
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Another interesting choice for the build off! I'm looking forward to seeing this one come together. You don't see one of these every day.
Wolpertinger is online now Find More Posts by Wolpertinger
Old Jan 16, 2012, 09:53 PM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Hey Robert,
Looking forward to this one.
Steve
Steve85 is online now Find More Posts by Steve85
Old Jan 17, 2012, 05:03 AM
Rotatorus's Avatar
Joined Apr 2006
Wings are getting their form. I've cut out all the ribs for the wings and they are partially installed already. I have found several non-scale aspects in this plan. One of them is the alternating thickness in the original plane where this plan has a wing which in thickness goes from thick to thin from wingbase to wingtip. Need to do some sanding when all ribs are installed it seems.
Robert
Old Jan 17, 2012, 04:48 PM
pmullen503 is offline
Find More Posts by pmullen503
United States, WI, Fond du Lac
Joined Sep 2008
Cool project! The thinner wing at the root will complicate things but it'll be more scale. I can see why the original plans would simplify this.
pmullen503 is offline Find More Posts by pmullen503
Old Jan 17, 2012, 08:20 PM
Ballarat, Australia
Joined Jan 2007
Nice work Robert keep it going.
Where did you get the 3-view for the Do24 at I looked and looked and have not found any good ones at all.
Pete
Old Jan 18, 2012, 03:08 AM
Rotatorus's Avatar
Joined Apr 2006
Pete
Hi Pete,
Mine is just a big blowup of one of those 3-views you can find on the web. I don't even know where I have it now (somewhere in the computer or on one of those external drives) or where I got it. It's not that good but I think it might be a good basis to start from. Having an actual Do24 around is a luxury which can be very usefull to fill in the details. If you start on a Do24 let me know and I'll go to the museum and take pictures of the things you want me to.
Len did build a Do24 in this thread:
http://www.rcgroups.com/forums/showthread.php?t=781075
For now I'll focus on this little plane.
Robert
Old Jan 18, 2012, 03:09 AM
Rotatorus's Avatar
Joined Apr 2006
Thanks warhead_71 very usefull material.
Robert
Contest FunBuild 5 Vought V-173 Flying Flapjack Ronald L Scratchbuilt Indoor and Micro Models 53 Apr 08, 2013 09:24 AM
Contest Funbuild 5 Beechcraft D-18 pmullen503 Scale Kit/Scratch Built 103 Sep 22, 2012 11:05 AM
Discussion DORNIER Do-18 greggk Waterplanes 0 Sep 21, 2009 10:53 PM
Discussion Dornier Wal electric scale flying boat nickchud Scale Kit/Scratch Built 29 Jan 08, 2008 06:29 AM
Discussion Dornier DoX flying boat? tim slocum Electric Plane Talk 9 Nov 10, 2006 02:10 PM
