Old Jan 15, 2012, 12:56 PM
Colin Geisel is offline
Find More Posts by Colin Geisel
Colin Geisel's Avatar
Canada, ON, Angus
Joined Aug 2007
Help!
26cc ID and Carb help !!???
Hi guys, hopefully someone can help me out. I was recently given this engine and I'm looking for a little more info on it. The ignition that was in the box says SV on it, but I have not been able to find an SV 26cc that was equipped with a primer bulb carb.
I have no documentation with the engine, I would like to know what kind of engine this is for sure.
Also, I would like to know if anyone could recommend a replacement carb with a choke instead of a primer bulb.
Any help is greatly appreciated.
Colin
Colin Geisel is offline Find More Posts by Colin Geisel
Old Jan 16, 2012, 09:08 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
carb
Keep the primer bulb...that is a great starting asset.It pumps fuel from the tank to the carb without cranking the engine.=less effort.
A second and often forgotten advantage is that it also flushes the carburetor.
If the engine sits for any time,the gasoline evaporates at a faster rate than oil,so theres the difficulty of getting fresh fuel to the carb by choking.
You can add a choke,but keep the primer.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: AMA 'traditional' , once more ?
Old Apr 08, 2012, 11:43 PM
rebranger is offline
Find More Posts by rebranger
USA, AL, Huntsville
Joined Apr 2007
Looks like somebody has changed out the carb, which is good!! .see a number on the side of carb? should be WT something, It'll crank w/o a choke, mine do
rebranger is offline Find More Posts by rebranger
Old Apr 09, 2012, 04:20 AM
Canada, ON, Angus
Joined Aug 2007
Thanks, guys. I've just built a test stand, I'm going to run it hopefully next weekend. I'll let you know how it goes.
Help! Carb ID Jason_WI Engines 3 Jun 30, 2010 10:57 PM
Sold 26cc SV rear carb "new in box" pryor808 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Mar 08, 2010 01:55 PM
Sold SV 26cc Gold Head Rear Carb kbailey45us Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 07, 2010 09:32 PM
Sold Chinese rear carb 26cc gasser OKheli2 Aircraft - Fuel - Engines and Accessories (FS/W) 3 Oct 12, 2009 05:23 PM
Question Can I flip the carb on SPE 26cc? infinitemass Engines 2 Mar 30, 2008 05:53 AM
