Old Jan 15, 2012, 04:11 AM
seadog985 is offline
Find More Posts by seadog985
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
RC Ship Transport Case/Box
Have some 1/144 scale warships ships rangeing 36" to 47". As my fleet slowly grows I need a better way to load them into my suv and was thinking that maybe a case/crate/box for each might be the best way to maximize space and insure the safety of each. Would like to see any photos of transport methods you guys might have before I break out the saw and ruin a bunch of wood. Thanks.
seadog985 is offline Find More Posts by seadog985
Old Jan 15, 2012, 08:29 AM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
United States, MI, West Bloomfield Township
Joined Dec 2004
Umi, can we add transport boxes to your FAQ/ref list?
http://www.rcgroups.com/forums/showt...98#post3720461
http://www.rcgroups.com/forums/showthread.php?t=734392
http://www.rcgroups.com/forums/showthread.php?t=1014165
+ many more
and the related display stand threads:
http://www.rcgroups.com/forums/showthread.php?t=637017
+ many more
and the related "shipping a model" threads:
http://www.rcgroups.com/forums/showthread.php?t=713833
http://www.rcgroups.com/forums/showthread.php?t=1150245
+ many more
patmat2350 is offline Find More Posts by patmat2350
Old Jan 15, 2012, 11:14 AM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Yeah, I can do that...
Oh, and I can add a transport case too.
This one fits airplane carry on dimensions.
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Jan 15, 2012, 04:01 PM
Reckless is offline
Find More Posts by Reckless
Ladysmith Vancouver Island
Joined Feb 2008
I'm about the undertake in this myself .. mainly just to be able to put them in the trunk of the car (even stacked if needed)
my favorite design is pretty simple ... basically make the stand with the bottom base slightly larger then the model, and then a box that slips over top with latchs to lock it to the base.
ofcourse even simpler would be to find tupperware containers that fit the model .. build the stand to lock into the container... but my current stuff is WW2 warships, and reaching into a container to pull it out doesn't thrill me.
I'm sure both methods and more are displayed in the links above
Reckless is offline Find More Posts by Reckless
Old Jan 15, 2012, 05:38 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Thanks for the replies. The case Umi showed was more along the lines of what I had in mind. I did search around and had seen the hillbilly boxes but sizing is going to be an issue I think. Am thinking more along the lines of building a stand that can have sides and a top attached for safe transport. Then at the pond just drop the sides and presto, a ship on display. Would also take away the risk of having to life it out of the case.
Old Jan 15, 2012, 07:40 PM
JPCAT is online now
Find More Posts by JPCAT
Dried fish eater
JPCAT's Avatar
Joined Mar 2011
The transportation case for my STOUT.
It is better to have been able to remove a mast for storage.
JPCAT is online now Find More Posts by JPCAT
Old Jan 15, 2012, 09:47 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
JP, now that is really nice.
Old Jan 15, 2012, 10:39 PM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Transport Cases
Mine are like Umi's, just not all of them, are not currently set up to go on an aircraft. My sides, bolt on with flat head, brass screws, that go into brass threaded inserts. I use slotted screws, so I can use a dime, and remove the side for inspection. I used to carry a screwdriver, but I am sure TSA, would want to keep it. CB
CaptCB is offline Find More Posts by CaptCB
Old Jan 15, 2012, 10:48 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Thats what I had in mind CB. There are some screw like things that they use to attach the side of some pressed wood furniture, a male and a female part. I was thinking that Lowes might have something like that and I could get some thin plywood and make some sides and a top to attach to my existing stands. The part you used might be smaller/better.
Old Jan 15, 2012, 11:23 PM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Seadog,
I just made mine so that my stands just slide into the case, with the boat on them. Then I have a adjustable brace that keeps the boat in place on the stand. I tape any loose house pieces to the hull, before closing up the box. My one boat has made between 5-7 rides, in an overhead compartment. Today, I think I would do the same as UMI, and make sure, it fit the SMALLEST, airline, carry-on dimensions. You don't want them to have to "throw it" in the belly. CB
Old Jan 16, 2012, 06:14 AM
GlynnG is offline
Find More Posts by GlynnG
UK
Most of my models tend to be based on ships so something akin a "coffin" shape has to be used. The masts can usually be detached which cuts down on the height of the box.
Having made some really overweight boxes I now try to use thinner wood. The strips sold for panelling seem to work OK. Glue them together to suit the beam of the model plus some foam packing. Then cut to the desired length and height.
The corners are reinforced with some square strips, front and back made from hardboard, the back being fixed and the front bottom hinged for access. A piece of plywood is usually needed underneath the top of the box so as to spread the load from the handle.
So for these boxes have allowed for safe transport to and from the sailing waters. Perhaps not immediately obvious, they also make for safe storage when the model is not in use. Who hasn't knocked the odd bit of a model when working on something else?
Glynn Guest
GlynnG is offline Find More Posts by GlynnG
Old Jan 16, 2012, 09:13 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
Although this is a UK address, there are many sites on your side of the pond that supply the same type of components.
http://www.theelectronicsshop.co.uk/
Easy to put together and use whatever sheeting materials to suit.
Regards Ian.
Look at flight case solutions.
Circlip is offline Find More Posts by Circlip
Old Jan 16, 2012, 12:00 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
I would also recommend using thinner materials for the box cover and sides.
I used 3/8" plywood for the bottom and three sides of my box, and had to use
the thinner 1/8 and 1/16" material for the large faces. The box ended up weighing
eight pounds, and was a bit much to carry around when walking to locations that
offered sailing opportunities.
Old Jan 16, 2012, 03:13 PM
Tachikaze is offline
Find More Posts by Tachikaze
太刀風
Tachikaze's Avatar
United States, OR, Eugene
Joined Jan 2003
Carrying case for Revelle Schnelleboot 1/72nd scale. Awaiting leather luggage handle.
Tachikaze is offline Find More Posts by Tachikaze
Old Jan 16, 2012, 03:47 PM
Vita ex Machinis
patmat2350's Avatar
Joined Dec 2004
From a sponsor's link here... not cheap, but nice, and could fit many of our boats:
53" x 18" x 22"
http://www.helihobby.com/product-p/lp-m0118.htm
Link Transport Case for Multicopter Rc Heli Halle Multirotor Talk 4 Nov 29, 2011 05:41 PM
New Product Transport box for multicopters bostjan Multirotor Talk 3 Nov 21, 2011 01:01 PM
Help! DLG Transport --Thinking inside the box. tbird911 Hand Launch 1 Oct 28, 2011 11:03 AM
Discussion Lipo Storage/transport box: Did I do right? astroboy Batteries and Chargers 4 Aug 14, 2011 10:32 AM
Discussion Needing transport case suggestions for tRex 600 wartoy Large Electric Helis 8 Jul 28, 2011 12:46 AM
