Old Jan 15, 2012, 12:07 AM
wollins is online now
Find More Posts by wollins
"RC ADDICT" in Toronto!
wollins's Avatar
Toronto Canada
Joined Aug 2004
Air compressor advice
Looking to get into airbrushing etc ... so the compressor that I'm looking to get is basically just for that. I've heard people say that I should get the biggest I can afford etc since I may find other uses for it down the road etc ...however just looking to use it for painting.
Here's the thing though ... I'd like to get enough compressor to cover airbrushing AND HVLP painting. I've heard that one needs at least a 1HP compressor to power a HVLP gun but I have no clue.
My question is ... would this compressor be adequate for both?
Colin
wollins is online now Find More Posts by wollins
Old Jan 21, 2012, 05:35 PM
Andy01 is offline
Find More Posts by Andy01
Joined Feb 2010
I am no expert, but recently gone through the same process.
My thoughts are that your linked compressor would be OK for airbrushing, but no good at all for anything bigger. Even for airbrushing a 1.5 gallon (6 litre) tank would mean that that compressor would run fairly often and they are NOISY, which may be irritating.
I started with a Iwata airbrush and a cheap $80 3cfm, 2HP, 24 litre (6 gallon) tank compressor (obviously any non-oil-free compressor needs a filter/oil & water trap). It worked fine for the airbrush, but as soon as I tried to use a small spray gun, I had problems. Even with the gun gagged back to a small pattern, bare minimum air flow and low pressure, the compressor ran continuously, and very soon started leaking oil from the crankcase cover. Even the small 1.5mm guns generally require around 7-12cfm to perform.
I took the leaking compressor back to the shop for a refund (it was 4 weeks old), and spent about $320 on a small 2.75HP, 7.3cfm, 36 litre (9 gallon) V-twin compressor. It is so much better, pumps up the tank much faster, probably a little quieter (although still noisy), and runs only intermittently with the spray gun on the same settings as before, so I would be able to broaden the spray pattern etc as required. Even it would be marginal for anything other than small spray guns I suspect. This was what I bought;
http://www.machineryhouse.com.au/C327
So, don't buy too cheap unless you only ever plan to use it for airbrushing.
Colin
Andy01 is offline Find More Posts by Andy01
Old Jan 25, 2012, 04:03 PM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
HP is the least important rating.
You need to look at the CFM (air volume) at a given pressure to make sure it will perform. If the compressor is too small, you can still paint, but you spray a bit, then wait for the compressor to catch up.
A DeVilbis GTi gravity feed gun requires 12.5 - 16.0 CFM at 30 psi at the inlet.
That is a good bit of air flow. A quick look at Sears shows there 1.6 - 1.9 HP portable compressors to be in the 6.3 - 7.2 CFM at 40 psi range.
Pinecone is offline Find More Posts by Pinecone
Old Jan 30, 2012, 10:34 PM
Leroy G is offline
Find More Posts by Leroy G
Leroy G.
Leroy G's Avatar
Coeur d' alene, Id.
Joined Jan 2010
The main compressor can be any size, you can use one of those twin tank oil less compressors and use a HVLP gravity automotive touch up/detail gun, most of them spray at 10 psi., or an air brush two stage that requires around 30 psi. for automotive type paints. I use the air brush and really like it. Leroy
Leroy G is offline Find More Posts by Leroy G
Old Jul 04, 2012, 01:51 PM
speleopower is offline
Find More Posts by speleopower
Hey Now
Cocoa Beach, Florida
Joined Feb 2004
iuiuhiuh
speleopower is offline Find More Posts by speleopower
Old Jul 04, 2012, 02:18 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
First, I'm not a fan of oil less compressors, at least for nothing bigger than a airbrush compressor. They tend to be noisier, and heat up twice as much creating a lot more water in the tank. I bought this one about 3 years ago, it runs almost everything I put at it, although the impact guns tend to drain it quick. Right now with the 25% off coupon and the sale, it would be right about 125.00. You would still need a good filter unit IMO for painting.
http://www.harborfreight.com/air-too...sor-67847.html
Underthetire is offline Find More Posts by Underthetire
Old Jul 05, 2012, 07:40 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I run a 3.5hp 13 gal oil less compressor. Like speleopower says it doesnt turn on very often. I also dont have any problems with moisture like the smaller compressors I used to use. I run a paasche air brush and a touch up hvlp. When it needs to recharge, I just wait a few minutes for the moisture to condense some, then get back to painting.
Edwin
edwin1 is offline Find More Posts by edwin1
Old Jul 06, 2012, 01:33 PM
Dcnlarry is offline
Find More Posts by Dcnlarry
Dcnlarry's Avatar
United States, NY, Poughkeepsie
Joined Mar 2012
Just a heads up, I found a 20 gallon, 1.8 HP compressor at Home Depot for $179.00 out the door. I have been looking around lately for a larger compressor that can handle my airbrushes and a larger gun (6.0 CFM HVLP) this compressor can do it all. It is pretty quiet for a larger style, guessing it runs at about 70 DBs, can't really measure it, but it is OK for my shop (others have indicated that it is noisy, however I did not find that to be the case, of course my hearing might not be what it used to be, YMMV. It takes about 10 mins. to fully charge the tank at 155 PSI, which is where the cutoff is set and holds very well, the regulator works good and is accurate. Everything comes with the compressor excluding a water filter/dryer, which I added. All the fittings, hose, water filter, etc and out the door, with tax. = $239.00 For what you get I don't think you can beat the deal. It is made by Husky and I believe made in China, however, all the parts and the tank look and feel quality. Hope this helps.
Dcnlarry is offline Find More Posts by Dcnlarry
Old Jul 09, 2012, 12:00 AM
bdshort is offline
Find More Posts by bdshort
United States, AK, Ketchikan
Joined Mar 2008
I've been thinking recently about purchasing an airbrush setup as well. I currently live in a condo, so having a compressor that is quiet is a big deal. It's either that or keep going through cans of Propel. Right now I'm just looking at a small setup for painting smaller parts, but may be wanting to paint entire smaller sized planes as well (50" span range or smaller), so I don't think I really need anything big.
bdshort is offline Find More Posts by bdshort
Old Jul 09, 2012, 06:22 AM
edwin1 is offline
Joined Sep 2003
My wife used air tanks, dont recall the gas she used. But had a spare always on hand. She used paasche and iwata (?sp) or something like that.
Edwin
Old Jul 09, 2012, 11:52 AM
bdshort is offline
Joined Mar 2008
Actually that's a good point - I have a pile of dive gear including two 100CF steel tanks, and access to an air compressor for free fills. I should just use those. So I guess I should look for a suitable adapter/regulator...
Old Jul 09, 2012, 08:17 PM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I have an old (40 years) sears. It is a 2 HP, 20 gallon tank but I don't remember the CFM rating. OH, it was made when 2 HP was 2 HP. The same motor today would be 3 to 5 HP. Mine draws 16 amps at 220 volts if that gives a clue???
Anyway, it will run a full size HVLP gun for a bit until you drain the tank and need to wait for it to catch up. I was able to paint the complete side of a Honda Civic on one "tank full" of air with a bit to spare.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Jul 10, 2012, 10:43 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
FWIW, I was in the market for a new compressor last year. Here's the thread: http://www.rcgroups.com/forums/showthread.php?t=1553539
Lots of good info.... I went the the Rolair. Made in the USA, VERY QUIET, Fills VERY fast.. After using it for about 6-8 months now I can say it was worth every penny.
rcav8r2 is offline Find More Posts by rcav8r2
Old Jul 11, 2012, 01:45 PM
wollins's Avatar
Toronto Canada
Joined Aug 2004
I'n seriously looking at that one as well ... will it run a HVLP gun though?
Colin
Old Jul 11, 2012, 02:54 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Colin
Can't say for sure, I just run an airbrush, palm nailer, brad nailer which it handles with ease. Give them a call....
http://www.rolair.net/contact/index.html
For Sale Miller Air Compressor and three Air Brushes Art Horne Aircraft - General - Miscellaneous (FS/W) 3 Nov 21, 2011 01:26 PM
For Sale Miller Air Compressor and 3 spray guns Art Horne Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2011 07:17 PM
