Old Oct 07, 2003, 09:05 AM
marke is offline
Find More Posts by marke
new york
Joined Sep 2003
cdrom motor with aluminum bell machined
can any one tell me if you can machine the bell out of aluminum to mount the n45 magnets or does the can have to made out of steel???? i have tried this and the performance dosent seem any better then the gray magnet matl. there is alot more magnetic cogging. but doest the metel effect the performance or is just cheeper to make them out of steel? thank you for any help. marke
marke is offline Find More Posts by marke
Old Oct 07, 2003, 09:45 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
The bell of the PJS motors is plastic with glued magnets... Maybe there is a iron ring under the glue, but if there is any iron it has to be very thin... I don't think so.
I am curious too about the real importance of a iron ring. In theory of course it is better, but how it affects the parameters, the efficiency etc.?
mmormota is offline Find More Posts by mmormota
Old Oct 07, 2003, 10:13 AM
marke is offline
new york
Joined Sep 2003
pictures
these are photos of the motor. i have not run this one yet. this is number 2 the first one looks the same except this armature hade more room to wind the 18 turns of 26 awg wire.
Old Oct 07, 2003, 10:16 AM
marke is offline
new york
Joined Sep 2003
here is the winding
Old Oct 07, 2003, 10:44 AM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
Beautiful, beautiful work. Did you make this?
In theory the iron should increase efficiency, thus power.
The iron ring to be most effective should probably be soft iron. At this scale though losses shouldn't be too large, so it should run well without.
Trizza is offline Find More Posts by Trizza
Old Oct 07, 2003, 10:51 AM
marke is offline
new york
Joined Sep 2003
thank you yes I did make this. The reason I did this was to allow more room for the 5x5x2 n45 magnets. I am using this in a micro heli. but i am not that impressed with the perfomance compared to the orig. gray ring style magnet . but ill try this one and let you know how it works. marke
Old Oct 07, 2003, 10:54 AM
norbique is offline
Find More Posts by norbique
norbique's Avatar
United States, HI, Honolulu
Joined Dec 2002
Hey Marke,
What did you do with the aluminum to look pink/purple?
Also what type of CD drive did this stator and bearings come from?
-norbert
norbique is offline Find More Posts by norbique
Old Oct 07, 2003, 10:57 AM
tclark is offline
Find More Posts by tclark
Bedford, MA
Joined Nov 2000
The iron in the rotor provides a high permeability return path to allow the magnetic flux to travel from the back side of a magnet to its neighbors. This helps to increase the magnetic field strength in the motor gap - you will get more cogging and a lower Kv, and better efficiency. You can get similar effects by using bigger and/or better magnets, but steel is cheap so it is a good option. The steel doesn't need to be very thick to be quite effective; a millimeter should be thick enough even with very good magnets. Your windings are beautifully made, from an efficiency standpoint you will get better performance if you cram more copper in there (there appears to be space available).
-Tracy
tclark is offline Find More Posts by tclark
Old Oct 07, 2003, 11:04 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Originally posted by Trizza
... In theory the iron should increase efficiency, thus power ...
No Trizza, in fact, efficiency will slightly decrease due to eddy current losses in the bell and increased fluxin the stator (higher eddy currents and hysteresis losses). But the motor can swing a bigger, more efficient prop thus increasing overall efficiency. Without steel the motor will probably not run at all.
The bell has to be steel: st37, st38 etc. Carbon, aluminium, wood, plastic will give a very high rpm and little torque. The iron will not give you more power.
@Marke
Lovely job
Use thicker wire or two (slightly thinner) wires in parallel to use up as much slot-space as you can, the way tclark explained.
When will you start producing in quantities? (Using a steel bell)
Met vriendelijke groet Ron van Sommeren
diy outrunner brushless e-motor discussion.
Electric fly-in & lrk meet, June 27th, 2004, Nijmegen, the Netherlands.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 07, 2003, 11:09 AM
corey is offline
Find More Posts by corey
corey's Avatar
Canada, MB, Winnipeg
Joined Oct 2001
How do I place an order!
corey is offline Find More Posts by corey
Old Oct 07, 2003, 11:20 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Ron: I understand your argument about needing steel however the PJS motor run quite well with high torque and use a plastic bell. Any idea as to why they work so well?
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Oct 07, 2003, 11:22 AM
Joined Feb 2001
Jim, I don't know how the PJS motors are build. Is the bell really plastic or plastic covered?
Old Oct 07, 2003, 12:07 PM
marke is offline
new york
Joined Sep 2003
finish on can
I do my own anodizing at home and the color is purple rit dye. as far as the iron ring i can try a strap around the out side of the aluminum but my concern is the gap made by the alum. may be to much to do any good. the other thing i could do is make a cut on the inside where the magnets are and place the ring inside. the metel i would use is called nickel/iron 50/50 this is what is used in torque motors for aircraft. I agree about the hysterisis. the iron will short out the flux. the first motor i made works and looks the same but dosent have the get up and go I would expect. as far as the windings the first motor was jammed full with 18 turns of 26awg. Thank you every one for the help Marke
Old Oct 07, 2003, 03:52 PM
Joined Feb 2001
Can you put up a picture of the inside of the bell? You only need steel (strips) between the magnets, not necesarrily behind the magnets.
Old Oct 07, 2003, 05:02 PM
Ænima is offline
Find More Posts by Ænima
Ænima's Avatar
London Heathrow, Great Britain (UK)
Joined Oct 2003
would you get the same effect if the magnets are touching??
Ænima is offline Find More Posts by Ænima
gws warbird with a cdrom motor? REVKEV6 Power Systems 23 Jan 14, 2005 03:41 PM
Axi like custom CDRom motor with axi radial mount and wobbly prop adapter Happy|Harry Aircraft - Electric - Airplanes (FS/W) 9 Oct 23, 2004 02:39 AM
Rave Homemade bell for CDROM motor Hogster Power Systems 19 Aug 26, 2004 07:55 AM
Question some questions with my home made cdrom motor rmeflyerkid Power Systems 4 Jun 26, 2004 07:32 PM
Foamie MiniMustang with CDROM Motor sr71fan Foamies (Kits) 9 Apr 06, 2004 04:33 PM
